Mini-96 World Challenge
#1441
#1442
Class- 2WD Open
Date- May 22, 2022
Location- Madison, WI
Race Time- 331.29
Fastest Lap- 3.93s
Chassis- Atomic MRT
Body- Abarth Fiat 500 Lexan
Wheelbase- 94mm
Tires- GL 17, Gecko Medium
Motor- 5600kv
Batteries- 360mah lipo
Front Springs- Stock
Rear Springs- Extra Hard
Gearing- Stock
Notes- Got a run in this weekend not my greatest but wanted to make sure I had an entry this month. Last month got busy at the last second and didn't have time. Found standing in the right place made a huge difference on this layout, was struggling to get under 5s until I stood off to the right more so I could see the sweeper better. Then I was pretty consistently in the 4s.
Date- May 22, 2022
Race Time- 331.29
Fastest Lap- 3.93s
Chassis- Atomic MRT
Wheelbase- 94mm
Motor- 5600kv
Gearing- Stock
#1443
Here is the forum: Salt Lake Mini-Z Club Forum but you might have better luck with Facebook https://www.facebook.com/groups/387369954777340/
#1444
Recently picked up a used Mini 96 and a used MR03. Having a lot of fun putting in laps when I can. Would love to run on a 50cm track some time!
27MAY22
Class-box stock
Date- May 22, 2022
Location-San Diego
Race Time- 426.2
Fastest Lap- 4.35
Chassis- Kyosho MR03
Body- McLaren P1 GTR
Wheelbase- 98MM
Tires- PN KS-M super soft slick, PN KS Radial super soft
Motor- stock
Batteries- Kyosho Speed House 800
Rear Spring- Stock
Gearing- 7T pinion
T-Plate- Stock
bearings- Stock
27MAY22
Class-box stock
Date- May 22, 2022
Location-San Diego
Race Time- 426.2
Fastest Lap- 4.35
Wheelbase- 98MM
Motor- stock
Rear Spring- Stock
Gearing- 7T pinion
T-Plate- Stock
bearings- Stock
#1445
Class-Box Stock
Date- May 13, 2022
Location-slc
Race Time- 736.48 (12m 16.47s)
Fastest Lap- 5.29
Chassis- RWD MR-03
Body- Mercedes-AMG GT3 No.47 24H Nurburgring 2018
Wheelbase- 98mm
Tires- PN KS MEDIUM Front, PN KS SUPER SOFT Rear
Motor- stock
Batteries- PN 900mah
Front Springs- stock
Rear Spring- stock
Gearing- stock
T-Plate- stock
bearings- stock
I didn't pull the track out as much as I'd have liked but had a blast when I did. Toward the end I was able to get several laps in without crashing into the wall. Swapping out the tires from stock made a world of difference.
This is a fun hobby and a great idea for an online race format. Thanks!
Date- May 13, 2022
Location-slc
Fastest Lap- 5.29
Chassis- RWD MR-03
Wheelbase- 98mm
Motor- stock
Rear Spring- stock
Gearing- stock
T-Plate- stock
bearings- stock
#1446
Class-Box Stock
Date-5/1/22
Location-Winston-Salem, NC
Race Time-265.7
Fastest Lap-3.36
Chassis-MR-03 ASF
Body-McLaren F1 LM
Wheelbase-98mm
Tires-K30LH fronts, Marka V1R10 rears
Motor-Stock
Batteries-TRP 747s
Front Springs-PN Red
T-Plate-Kyosho Carbon Med
Motor Mount-Stock MM
Dampener (If applicable)-None
Notes-No changes from previous month. Only a couple of runs with this car and 0.6 sec slower than April.
Date-5/1/22
Race Time-265.7
Fastest Lap-3.36
Chassis-MR-03 ASF
Body-McLaren F1 LM
Wheelbase-98mm
Motor-Stock
Batteries-TRP 747s
#1447
Class-Porsche Cup Class
Date-5/9/22
Race Time-260.9
Fastest Lap-3.16
Chassis-MR-03 EVO
Body-911 GT3
Wheelbase-90mm
Tires-K30Flat fronts, Marka V1R10 rears
Motor-ATM 3500
Batteries-Kyosho SpeedHouse 800s
Front Springs-Kyosho Stock
T-Plate-Kyosho FRP 0.6S
Motor Mount-Nexx Round RM
Dampener (If applicable)-PN G10 DDS and Kyosho Inner Tube Shock MZW442
Dampener Fluid (If applicable)-Ruby Lube on Shock
Gearing-PN 64p 13/53 Ball diff
Notes-No changes. Only a couple of runs. Challenging but fun to drive.
Date-5/9/22
Race Time-260.9
Fastest Lap-3.16
Chassis-MR-03 EVO
Body-911 GT3
Wheelbase-90mm
Motor-ATM 3500
#1448
Class-Stock GT 4100
Date-5/28/2022
Race Time-245.6
Fastest Lap-3.00
Chassis-MR-03EVO
Body-2010 Audi R8
Wheelbase-98mm
Tires-K30 radial fronts, Marka V1R10 rears
Motor-Kyosho 4100
Batteries-TRP 747s
Front Springs-PN Green
T-Plate-Kyosho FRP 5S
Motor Mount-Kyosho MZW309 MJ (LM)
Dampener (If applicable)-Kyosho MZW310 with PN dual shock
Gearing-64p 12/53 Kyosho Ball diff
Notes-My go to stock cars (PN70T F-430GT and 3500kv AArm 458) were ill handling and I couldn't get a clean run with either, so gave this backup car a try and came close (1.6 sec) to my best April time.
Date-5/28/2022
Race Time-245.6
Fastest Lap-3.00
Chassis-MR-03EVO
Body-2010 Audi R8
Wheelbase-98mm
Motor-Kyosho 4100
Batteries-TRP 747s
#1449
Class- 2wd Open
Date-5/31/2022
Location-Kenosha, WI
Race Time-294.5
Fastest Lap-3.42
Chassis- GLR-GT, Reflex 505 Brass chassis
Body-GL Ferrari 488 GT3
Wheelbase-98mm
Tires- PN KS-M Medium, Marka V1R05 rears
Motor- GL 3500vk
Batteries- Fantom 360mah lipo
Gearing- 64p 10/53 Ball diff
Cold bore this month, only two packs to get a time and this is what I got
Date-5/31/2022
Race Time-294.5
Fastest Lap-3.42
Wheelbase-98mm
Motor- GL 3500vk
#1450
Class-Box Stock
Date-5/31/22
Location- Kenosha, WI
Race Time-292.4
Fastest Lap-3.5
Chassis-MR-03 LM
Body- Sauber Mercedes
Wheelbase-102mm
Tires- PN Racing KS-M Medium fronts, PN Racing KS-M soft rears
Motor-Stock
Batteries- PN 750
Date-5/31/22
Race Time-292.4
Fastest Lap-3.5
Chassis-MR-03 LM
Wheelbase-102mm
Motor-Stock
Batteries- PN 750
#1451
4wd Open
Date-5/18/22
Location-Norcal
Race Time-272.79
Fastest Lap-3.29
Chassis-GLA
Body-Jomurema
Wheelbase-98mm
Tires-PN soft slick fronts, Marka 10 slick
Motor-Rocket 3500kv
Batteries-GL 2S
Front Springs- blue
Rear Spring blue
Motor Mount-NA
Dampener Fluid 15000
Date-5/18/22
Location-Norcal
Race Time-272.79
Fastest Lap-3.29
Chassis-GLA
Body-Jomurema
Wheelbase-98mm
Motor-Rocket 3500kv
Batteries-GL 2S
Front Springs- blue
Rear Spring blue
Motor Mount-NA
#1452
2wd open
Date-5/29/2022
Location- California
Race Time-278.50
Fastest Lap-3.20
Chassis-GLR GT
Body- Jomurema
Wheelbase-98mm
Tires- Unknown
Motor-GL 3500KV
Batteries- 2S lipo
After months of messing with the GLR GT it finally had a better run that the GLR. That being said the GLR has a lot more in it.
Date-5/29/2022
Race Time-278.50
Fastest Lap-3.20
Chassis-GLR GT
Body- Jomurema
Wheelbase-98mm
Tires- Unknown
Motor-GL 3500KV
Batteries- 2S lipo
#1453
Box Stock
Date-5/31/22
Race Time-297.59
Fastest Lap-3.32
Chassis-MR-030
Body- McLaren GT3
Wheelbase-98mm
Tires-
Rear PN soft radials
Front PN soft slick
Motor-Stock
Batteries- PN750
T plate PN 4
Front springs red
Stupidly waited till the last day to put in my Stock and Box stock runs. Only had time to run one box stock run and had some mistakes laps and traction roll.
Date-5/31/22
Race Time-297.59
Fastest Lap-3.32
Chassis-MR-030
Body- McLaren GT3
Wheelbase-98mm
Tires-
Front PN soft slick
Motor-Stock
Batteries- PN750
T plate PN 4
Front springs red
#1454
Class- Box Stock
Date- 05/31/2022
Location- Seattle, WA
Race Time- 413.1
Fastest Lap- 4.060
Chassis- MR03
Body- Mercedes AMG GT3
Wheelbase- 98mm
Tires- Kyosho 30 front, Kyosho 20 rear
Motor- stock
Batteries- eneloops
Front Springs- Kyosho red
T-Plate- stock
Motor Mount- stock
Dampener (If applicable)- N/A
Dampener Fluid (If applicable)- N/A
Gearing- Stock
Got the track setup tonight, first round here in case I don't make it to another run. I liked this layout, somehow wall hits felt less punishing
Date- 05/31/2022
Race Time- 413.1
Fastest Lap- 4.060
Chassis- MR03
Wheelbase- 98mm
Motor- stock
Batteries- eneloops
T-Plate- stock
Motor Mount- stock
Gearing- Stock
#1455
Stock
Date-5/29/2022
Race Time-284.37
Fastest Lap-3.09
Chassis-Pn 2.5
Body- Unknown
Wheelbase-98mm
Tires- R Marka 10. F PN soft slick
Motor-3500KV
Batteries-eneloops
Really having fun with this car and was turning some fast laps but made some errors and had some terrible laps including a 9.4 second lap. Hopefully I can put together some cleaner runs next month.
Date-5/29/2022
Race Time-284.37
Fastest Lap-3.09
Chassis-Pn 2.5
Body- Unknown
Wheelbase-98mm
Motor-3500KV
Batteries-eneloops
3035Likes
