Mini-96 World Challenge >
Like Tree3035Likes
Old 06-01-2022 | 04:07 AM
  #1456
Default May 2022 Results
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
We had 9 7 racers posting in 5 classes this month. Box Stock had the most entries.
Box Stock
1st - Traveler - 265.7/3.36s
2nd - TAMAK - 292.4/3.50s
3rd - PoorBoy - 297.6/3.32s
4th - Cdog4W - 413.1/4.06s
5th - Forja - 426.2/4.35s
6th - Octagonvague - 736.5/5.29s
Porsche Cup
1st - Traveler - 260.9/3.16s
Stock Class
1st - Traveler - 245.6/3.00s
2nd - PoorBoy - 284.4/3.09s
3rd - MiniZPlauen - 291.0/3.28s
Open 2WD
1st - PoorBoy 278.5/3.20s
2nd - TAMAK - 294.5/3.42s
3rd - PaulBarsamian - 316.3/3.80s
4th - TomtheGeek - 331.3/3.93s
Open 4WD
1st - PoorBoy - 272.8/3.29s
FTM goes to Traveler in his Stock car with a 3.00 fast lap!
Please check my tabulations and let me know if I made any mistakes or missed anyone.
Cheers,
Traveler2
Traveler2 is offline
Old 06-01-2022 | 04:11 AM
  #1457
Default June 2022 Layout
We are going with a new layout for June running clockwise.
Drive fast!
forja, Brutus279 and octagonvague like this.
Old 06-17-2022 | 11:43 AM
  #1458
Hey Guys, I'm back running this month, and this is a CHALLENGING layout Traveler2! I just received part of an AMain order of mini-z parts, and I got some low and super low profile 30* tires, so I slapped the super lows on and they made a HUGE difference with the twitchiness of the front end!!! I ran a quick 75 laps after about 30 warmup laps, and I was able to keep it off the walls better and had fewer complete stops needing reverse. I ran my fastest lap of 5.64 and my average lap was in the low 6s. I accidently hit the start/stop button while trying to get a screen shot so no actual #s. My Ipad I use LapTracker on is charging so I'll get some actual #s up tomorrow. I'm still very much a noob with Mini-Zs, and while I seriously doubt I'll ever get near the times Yall are able to, I'm having a blast trying to run the cleanest 75 laps I can! I'm half way through reading this entire post and learning A LOT, so THANK YOU ALL for the info and the time everyone has put into this AWESOME CHALLENGE!!!
Take Care and Drive Fast, Drew
Class- Box Stock
Date- 06/21/22
Location- Central Texas
Race Time- 492.4
Fastest Lap-5.08
Chassis- MR-03
Body- Jomurema
Wheelbase-98mm
Tires- Kyosho Super Low height 30 fronts/ PN-KS Radial Soft rears
Motor- stock
Batteries- PN 900mAh
Front Springs- Kyosho Red
T-Plate- Nexx Black Carbon #5
Motor Mount- MM
Dampener (If applicable)- factory rtr
Dampener Fluid (If applicable)- none
Gearing- stock gear diff/ 7t
Notes- Added super low height fronts, Carbon T plate, and PN aluminum T plate mount this month. This along with the king pin flip and polish has my mini-z handling quite well as it's my slow reflexes, old eyes, and lack of concentration that has my times where they are! I'll never be where a lot of you are in times, but it's fun trying, although sometimes frustrating!
6/25 Update
Bit faster time. I gained quite a bit of control with the T plate and S Low front tires. I'm able to get into the throttle in the straights much harder. Now if I can just keep focused for all 75 laps!
6/20 Update:
I got the T Plate and aluminum mount in and installed and it makes a HUGE difference in handling! I ran 75 laps and took almost a minute off my total time! And just like last time my butter fingers hit the start/stop button while getting a screen shot and erased my numbers! Damn it!!!
I am having a problem with one of the super low profile tires coming off the rim while sitting on the stand overnight! It is taped on Nexx Rim with PN narrow IIRC.
I'll keep on trying to get a screen shot LOL!
6/21 Update:
I finally got a screenshot! Not my best run with more stop/reverses than I was shooting for. But I'm getting cleaner with each run. I left the car on the track to see if the tire would come off, and in didn't but it did slide off about a mm. I tried flipping the tire around but it still popped off???
Anyway here's the #s
Poor_Boy, EMU and Traveler2 like this.
BoxxerBoyDrew is offline
Old 06-23-2022 | 06:48 AM
  #1459
Date-6/30/22
Location- California
Race Time-315.41
Fastest Lap-3.68
Chassis-MR-030
Body- McLaren GT3
Wheelbase-98mm
Tires-
Rear PN soft radials
Front PN soft slick
Motor-Stock
Batteries- Enelop
T plate PN 4
Front springs orange
Really wanted to get a clearer run but ran out of time.
Poor_Boy is offline
Old 06-23-2022 | 06:54 AM
  #1460
Stock
Date-6/29/2022
Race Time-309.42
Fastest Lap-3.57
Chassis-Pn 2.5
Body- Honda
Wheelbase-98mm
Tires- R Marka 10. F PN soft slick
Motor-3500KV
Batteries-eneloops
Only had time for one try so I used this car that is slower then my usual stock car but less prone to traction rolling and tried to keep it as smooth as possible.
(edit had time to run my fast car. So close to getting it done under 5:00 even with two traction rolls, Hopefully give it one more try tomorrow)
Poor_Boy is offline
Old 06-23-2022 | 11:24 AM
  #1461
2wd unlimited
Location-Norcal
Race Time-308.29 seconds
Fastest Lap-3.59
Chassis-GLR
Body-Jomurema
Wheelbase-98mm
Tires-PN soft slick fronts, Pn soft radial rears
Motor-GL 3500
Batteries-2S
Front Unknown
T-Plate NA
Dampener Fluid none
Gearing-Unknown
Poor_Boy is offline
Old 06-29-2022 | 05:25 PM
  #1462
forja's Avatar
Default MINI 96 World Challenge
Picked up an MRT this month and really enjoying the way it drives. This layout proved to be quite tricky for me to run consistent laps.
Class- 2WD Open
Date- 25 June 2022
Location- San Diego CA
Race Time- 384.7
Fastest Lap- 4.21s
Chassis- Atomic MRT
Body- Jomurema
Wheelbase- 98mm
Tires- Gekko soft slick front 8.5mm, soft radial rear 11mm
Motor- 3500kv
Batteries- 360mah 2S lipo
Front Springs- Stock
Rear Springs- Stock
Gearing- 24P 39S
Notes NA
Poor_Boy and tomthegeek like this.
forja is offline
Old 06-29-2022 | 05:34 PM
  #1463
forja's Avatar
Class-Box stock
Date-21JUN22
Location-San Diego
Race Time-492.2
Fastest Lap-5.02
Chassis-MR-03
Body-McLaren P1GTR
Wheelbase-98mm
Tires-PN KSM low pro super soft slick front 8.5mm PN KS super soft radial rear
Motor-stock
Batteries-PN 750
Front Springs-stock
T-Plate-stick
Motor Mount-stock
Dampener (If applicable)-N/A
Dampener Fluid (If applicable)-N/A
Gearing-7 tooth pinion
Notes-
Poor_Boy likes this.
forja is offline
Old 06-29-2022 | 05:36 PM
  #1464
forja's Avatar
Box Stock
Porsche Cup
Stock Class
Open 2WD
Open 4WD
Cheers,
Traveler2
The title states April results when this actually May results
forja is offline
Old 06-29-2022 | 06:30 PM
  #1465
tomthegeek's Avatar
Was putting in a session tonight with the MRT and broke a rear CVD. The Oring holding the spur gear on also snapped. Will try to fix it but may not be able to put in a run this month.
tomthegeek is offline
Old 06-30-2022 | 03:59 AM
  #1466
Good catch. Corrected. Thanks.
forja likes this.
Old 06-30-2022 | 04:30 AM
  #1467
Default June Box Stock
Class-Box Stock
Date-6/5/22
Location-Winston-Salem, NC
Race Time-299.7
Fastest Lap-3.71
Chassis-MR-03 ASF
Body-McLaren F1 LM
Wheelbase-98mm
Tires-K30LH fronts, Marka V1R10 rears
Motor-Stock
Batteries-TRP 747s
Front Springs-PN Red
T-Plate-Kyosho Carbon Med
Motor Mount-Stock MM
Dampener (If applicable)-None
Notes-No changes from previous month. Only a couple of runs with this car.
Old 06-30-2022 | 04:31 AM
  #1468
Default June Stock
Class-Stock GT 70T
Date-6/5/2022
Race Time-294.8
Fastest Lap-3.44
Chassis-MR-03 ASF
Body-Ferrari F-430 GT
Wheelbase-94mm
Tires-K30 radial fronts, Marka V1R10 rears
Motor-PN 70T
Batteries-TRP 747s
Front Springs-PN Purple
T-Plate-PN CF #4
Motor Mount-PN 94-98mm v2
Gearing-PN 64p 10/54 Ball diff
Notes-No changes this month, and only 2 runs.
EMU likes this.
Old 06-30-2022 | 12:45 PM
  #1469
Default June 2022 - box stock
Box stock
2022-06-05
Victoria, BC
RT 06:14.26
FL 04.32
Kyosho MR-03
Mclaren P1 GTR
WB 98mm
FT Gekko FM1
RT Gekko RS1
Kyosho OEM
Panasonic
Kyosho Red
Kyosho 6H
OEM friction
NA
7t / OEM gear diff
Spend most of the month away from home, could not run as much as I initiallyintended... Timing is from my last time on the track, June 05.
Brutus279 is offline
Old 06-30-2022 | 01:02 PM
  #1470
Originally Posted by BoxxerBoyDrew
Hey Guys, I'm back running this month, and this is a CHALLENGING layout Traveler2! I just received part of an AMain order of mini-z parts, and I got some low and super low profile 30* tires, so I slapped the super lows on and they made a HUGE difference with the twitchiness of the front end!!! I ran a quick 75 laps after about 30 warmup laps, and I was able to keep it off the walls better and had fewer complete stops needing reverse. I seriously doubt I'll ever get near the times Yall are able to, I'm having a blast trying to run the cleanest 75 laps I can! I'm half way through reading this entire post and learning A LOT, so THANK YOU ALL for the info and the time everyone has put into this AWESOME CHALLENGE!!!
Glad you are having fun and getting the car better. But WTH is going on with your tire? I've never had one that is taped on come off the rim while the car is sitting still. Could someone be messing with you?
And where in central TX are you? There is a track in Waco that does some Mini-Z racing.
