Mini-96 World Challenge
#2701
Roadrash, glad you are getting your 03 more to your liking! Turning laps is the biggest help for improving your times.
I am curious to see how the 04 will compete with the 03 in Box Stock. I had to put a 04 MM pod on my 03 Box Stock chassis, because I broke the clip on the top strap of the 03 pod pulling the motor to deep clean it. The lap times didn't change with the pod change, neither did the handling, but the improved steering and lower cg of the 04 will probably make the biggest difference.
I've been hinting to the wife the 04 Ready Set would make me a good birthday present next month!
#2702
#2705
Class- Box Stock
Date- 12/31/24
Location- Green Bay, Wi
Race Time- 5:59 359 sec
Fastest Lap- 4.08
Chassis- mr03
Body- Jomurema
Wheelbase- 98 mm
Tires- 30 shore radial front/ Rm2 Gekko rear
Motor- stock
Batteries- no name 1000 mah
Front Springs- stock
T-Plate-stock
Motor Mount-stock
Dampener (If applicable)-
Gearing- 7 tooth with stock spur
Notes-
Date- 12/31/24
Fastest Lap- 4.08
Chassis- mr03
Body- Jomurema
Wheelbase- 98 mm
Motor- stock
T-Plate-stock
Motor Mount-stock
Notes-
#2706
Class- Stock
Date- 12/33/24
Race Time- 5:44 344 sec
Fastest Lap- 4.02
Chassis- team associated sr27
Body- Jomurema
Wheelbase- 98 mm
Motor- stock
Batteries- no name 750 mah
T-Plate-stock
Motor Mount-stock
Notes-
Date- 12/33/24
Fastest Lap- 4.02
Body- Jomurema
Wheelbase- 98 mm
Motor- stock
T-Plate-stock
Motor Mount-stock
Notes-
#2707
Class- 2wd Open
Date- Dec 2024
Location- Sydney
Race Time- 4:23.511
Fastest Lap Time -3.162
Chassis- Reflex RX28SE
Body- Jomurema
Wheelbase- 98 mm
tyres- Marka 20 fronts and 10 rears
Motor- PN Racing 2500kv
Batteries- Reflex Racing Lipo
T-Plate-N/A
Motor Mount-stock
Gearing- 12 tooth with PN Gear Diff
Notes-
Date- Dec 2024
Location- Sydney
Race Time- 4:23.511
Body- Jomurema
Wheelbase- 98 mm
T-Plate-N/A
Motor Mount-stock
Notes-
#2708
Class- awd open
Date- 12-31-24
Location- Omaha NE
Race Time- 04:44.093
Fastest Lap- 2.819
Chassis- BZ5
Body- PN Porsche GT3
Wheelbase- 98
Tires- front(pn low soft slick) rear(Marka v1 10 slick)
Motor- EZRUN 6500KV (50%DR)
Batteries- 350mah 2cell
Front Springs- front(red) rear(white
T-Plate-
Motor Mount-
Dampener Fluid (If applicable)- 15k front and back
Gearing- stock
Notes- aluminum shocks front and back as well as aluminum uprights front and back. Pn machine cut 19mm wheels
EDIT. Will not let me post pics since I have not met the post minimum for new account
Date- 12-31-24
Location- Omaha NE
Fastest Lap- 2.819
Chassis- BZ5
Wheelbase- 98
T-Plate-
Motor Mount-
Gearing- stock
#2709
Class- Stock
Date- Dec 2024
Location- Sydney
Race Time- 4:30.965
Fastest Lap- 3.323
Chassis- Kyosho MR04 Evo2
Body- Jomurema
Wheelbase- 98 mm
Tires- Marka 20 fronts and 10 rears 14mm
Motor- TP 3500kv
Batteries- Kyosho AAA
T-Plate-carbon #5
Motor Mount-Nexx Racing
Gearing- 9 tooth with stock spur
Notes-
Date- Dec 2024
Location- Sydney
Race Time- 4:30.965
Fastest Lap- 3.323
Body- Jomurema
Wheelbase- 98 mm
Motor- TP 3500kv
T-Plate-carbon #5
Notes-
#2710
Class-Box Stock
Date- Dec 2024
Location- Sydney
Race Time- 4:45.593
Fastest Lap- 3.323
Chassis- Kyosho MR04 ready set
Body- Jomurema
Wheelbase- 98 mm
Motor- stock
T-Plate-carbon #5
Motor Mount-stock
Gearing- 7
Date- Dec 2024
Location- Sydney
Race Time- 4:45.593
Fastest Lap- 3.323
Body- Jomurema
Wheelbase- 98 mm
Motor- stock
T-Plate-carbon #5
Motor Mount-stock
Gearing- 7
#2711
Class- 4wd open
Date- Dec 2024
Location- Sydney
Race Time- 4:28.327
Fastest Lap- 3.051
Chassis- GL Racing GLA
Body- Jomurema
Wheelbase- 98 mm
Tires- Kyosho Radials 30 fronts and 20 rears
Motor- TP 3500kv
Batteries- GL lipo
T-Plate-carbon-N/A
Motor Mount-stock
Gearing- ?
Date- Dec 2024
Location- Sydney
Race Time- 4:28.327
Fastest Lap- 3.051
Body- Jomurema
Wheelbase- 98 mm
Motor- TP 3500kv
Batteries- GL lipo
T-Plate-carbon-N/A
Motor Mount-stock
Gearing- ?
#2712
I managed to get 6 classes run tonight. The times could have been better, but I'm battling the Flu and i get a bit dizzy. Anyway I hope all is well, and HAPPY NEW YEAR!!!
BOX STOCK
Date- 12/31/24
Location- Central Texas
Race Time-4:55.608 / 295.608
Fastest Lap-3.162
Chassis- MR03
Body- NSX
Wheelbase- 98mm
Tires- F- PN KSM Med / R- PN KSK 30* Radial
Wheels- F- PN+1 BBS Yellow / R- PN +1 BBS Black
Motor- Stock
Batteries-SpeedHouse
Front Springs- PN Purple
T-Plate- PN #3 Carbon
Motor Mount- Kyosho MM MR-04
Dampener (If applicable)- Kyosho Top Spring Shock
Dampener Fluid (If applicable)- 15k Grease
Gearing-7/44
Notes- NEEDS WORK! I just couldn't get it to run well tonight. Back end chattering, and had a tendency to hook around in the high speed 90*s.
BOX STOCK
Date- 12/31/24
Fastest Lap-3.162
Chassis- MR03
Body- NSX
Wheelbase- 98mm
Motor- Stock
Gearing-7/44
#2713
Class- Stock
Date- 12/31/24
Location-Central Texas
Race Time- 4:26.584 / 266.584
Fastest Lap- 2.987
Chassis- PN 2.5 / MR03
Body- Jomurema no lid
Wheelbase-98mm
Tires- F- PN KS Med LH / R- PN KSK 30* Slicks
Wheels- F- PN +2mm Dish blk / R- PN +2mm BBS Yellow
Motor-PN 3500Kv
Batteries- HiTec 750HV
Front Springs-PN White
T-Plate- PN #4 Black FiberGlass
Motor Mount- PN V3 94/98mm
Dampener (If applicable)- PN DDS ( Green top/ Lt. Purple bottom springs) PN Dual Shock (Purple front / Green Rear)
Gearing- 12/53 PN Ball Diff
Notes- BEST running car tonight! ON rails and could have been better with a clearer head!
Date- 12/31/24
Fastest Lap- 2.987
Wheelbase-98mm
Motor-PN 3500Kv
#2714
Class- PRO STOCK
Date- 12/31/24
Race Time- 4:33.653 / 273.653
Fastest Lap- 2.944
Chassis-MR04EVO
Body- Merc C9
Wheelbase-102mm
Tires-F- PN KSM Medium LH slicks/ R- Marka Soft Radials
Wheels- F- N+2mm 20mm PN BBS Yel / R- W+3mm 20mm PN +3mm 14spoke White
Motor-PN Anima 5500Kv
Batteries-SpeedHouse 800Hv
Front Springs-Green
T-Plate-Nexx #4 Carbon
Motor Mount-PN Multi Mount
Dampener (If applicable)- PN DDS (Green top/Green bottom springs) PN Dual Shock factory springs
Gearing-12/52 PN Ball Diff
Notes- Drove ok, but with better tweaking it would have been better.
Date- 12/31/24
Fastest Lap- 2.944
Chassis-MR04EVO
Body- Merc C9
Wheelbase-102mm
Front Springs-Green
#2715
Class-2WD OPEN
Date- 12/3124
Race Time- 4:27.530 / 267.530
Fastest Lap- 3.027
Chassis-MR04EVO
Body- Jomurema Green
Wheelbase-98mm
Tires-F- Kyo N LH Slicks 20* / R- PN KS-M Soft Radials
Wheels-F- PN N+1 19mm Dish White / R- Kyo W+1.5mm 20mm NSX white
Motor-Kyo Sensored 8500Kv
Batteries-HiTec 750HV
Front Springs-Kyo Orange
T-Plate-PN #4
Motor Mount- PN V4 94/98mm
Dampener (If applicable)- PN DDS ( Green top and Bottom Springs)
Gearing- 9/52 PN Ball Diff
Notes- The 8500kv is A LOT and I'm probably going to go with a PN Anima 5500kv to make it more controllable.
Date- 12/3124
Fastest Lap- 3.027
Chassis-MR04EVO
Wheelbase-98mm
T-Plate-PN #4
3035Likes
