Mini-96 World Challenge >
Like Tree3035Likes
Old 09-30-2025 | 11:01 PM
  #3301
Class- BOXSTOCK
Date- 09/30/2025
Location- Central Texas
Race Time- 334.254 / 5:34.254
Fastest Lap- 3.918
Chassis- MR04
Body- McLaren 12C
Wheelbase-98mm
Tires- F-PN KS Medium LH / R- Marka V1R10
Wheels- F- N +1mm 20mm PN BBS White / R- W +2mm 20mm 3D wheels Black
Motor- Kyo Stock
Batteries- Gens Ace 750HV
Front Springs- PN Red
T-Plate- PN Carbon Fiber #4
Motor Mount-Kyo Stock MM
Dampener (If applicable)- Kyo Spring shock (Red Spring)
Dampener Fluid (If applicable)- Kyo 15k grease
Gearing-7/44 Kyo Gear Diff-
Notes- MR-04 Ready Set with Reflex 0* Aluminum Knuckles. New KS Medium fronts (super glued side walls) New Marke V1R10. Car was very good but the rear would step out under power in turns 1,2, and 3. Being sick the last 3 weeks killed my runs! I waited till the last minute, but this was the best I could do! 12C is now put 100% together (lights, body pieces) now just a dusting of color.
On a side note I ran all these runs with Cham's new designed Tx wheel, and IT IS NICE!!!!!!!!! More to follow on it's own write up!
ekim628 likes this.
BoxxerBoyDrew is offline
  #3302
Class- STOCK
Date- 09/30/2025
Location-Central Texas
Race Time- 312.574 / 5:12.574
Fastest Lap- 3.789
Chassis- PN 2.5W/MR03EVO board/ 04 arms
Body-Jomurema Pink w/ Lexan roof and wing
Wheelbase-98mm
Tires-F-PN KS Soft / R- Marka V1R10
Wheels- F-PN N+1.5mm 19mm Flanged White 6 hole / R- PN W+2mm 20mm Yellow BBS
Motor-PN 3500Kv
Batteries- SpeedHouse 800HV
Front Springs-PN Purple
T-Plate-PN #3 Silver Carbon Fiber
Motor Mount-PN V3 94/98mm
Dampener (If applicable)- PN DDS ( Green top/ PN lt. purple X-Strenght bottom spring) PN Dual Spring Top Shock (Green Front/Purple Rear)
Gearing-13/53 PN Ball Diff
Notes- Car was ok, me not so much. I ran all 7 classes in 2 hours with about 30 laps of warm up for each class. By the 3rd class my rt arm was cramping.
  #3303
Class- PROSTOCK
Date- 09/30/2025
Race Time- 310.925 / 5:10.925
Fastest Lap- 3.697
Chassis- PN 2.5W/MR04EVO board/ 04 arms
Body- Jomurema Pink w/Lexan roof and wing
Wheelbase- 98mm
Tires-F- PN KSK 540 / R- PN KSK 2030
Wheels- F- 3D Disk Wheels +1mm 20mm Blue / R- 3D Disk wheels +2mm 20mm Blue
Motor-PN 5500Kv Anima Sensored
Batteries- Eneloop 850HV
Front Springs- Kyo Green
T-Plate-PN #4 Black Fiber Glass
Motor Mount-PN Multi Mount
Dampener (If applicable)- PN DDS ( Green top/ Green bottom spring) PN Dual Spring Top Shock (Silver Stock Springs)
Gearing-8/52 PN Ball Diff
Notes- Car pretty good. It could have been faster, but with not driving for weeks I went for steady over speed.
Old 09-30-2025 | 11:02 PM
  #3304
Class- OPEN 2WD
Date- 09/30/2025
Race Time- 303.004 / 5:03.004
Fastest Lap- 3.656
Chassis- GL GLR
Body- Jomurema White Lexan roof/wing
Wheelbase- 98mm
Tires-F- PN KS Medium LH (KS1138)/ R- Marka MZR-V1R05
Wheels- F- N+1mm 20mm 3D Disk wheels Blue / R- W+2mm 20mm 3D Disk wheels Black (no disk)
Motor- GL 3500kv
Batteries- GNB 350mAh 2S LiPO
Front Springs-Blue
T-Plate-N/A
Motor Mount-GL 98mm
Dampener (If applicable)- Short Center Shock (Blue Spring) / Yellow side springs
Dampener Fluid (If applicable)- 25K Atomic grease- Center / 15K Atomic grease- Sides
Gearing- 10/52 GL Ball Diff
Notes- Car was very good as usual, If I had time to run a second run tonight I could have broken into the sub 5 minute run, but I ran out of time. I might try tomorrow before I switch to CCW!
  #3305
Class- MX-5
Date- 09/30/2025
Race Time- 322.622 / 5:22.622
Fastest Lap- 3.840
Chassis- MR04EVO
Body- Kyosho MX-5
Wheelbase- 90mm
Tires-F- PN KS Medium LH (new KS1138) / R-PN KSM LH Soft
Wheels- F-PN N 0mm 19mm Blue 3D Disk wheels no disk / R- DXR Black carbon -1mm 20mm
Motor-PN Anima V4 3500Kv Sensored
Front Springs- PN Green
T-Plate-PN #3 Black Carbon Fiber
Motor Mount-Nexx 90/94mm RM
Dampener (If applicable)- PN DDS (Purple top disk/Green bottom spring)
Gearing-13/54 PN Ball Diff
Notes- Car was very good, but my arm was cramping most the run, so my times didn't show how well the car does on this layout! I'll try tomorrow before going CCW just for chits and giggles!
Old 09-30-2025 | 11:03 PM
  #3306
Class- PORSCHE
Date- 09/30/2025
Race Time- 318.573 / 5:18.573
Fastest Lap- 3.989
Chassis- MR04EVO
Body- Porsche 911 GT3 RSR
Wheelbase- 90mm
Tires-F- PN KS Medium LH (new KS1138) / R-Marka V1R10 half worn but good grip still
Wheels- F-PN N 0mm 19mm Black 3D Disk wheels #7 dsk / R- W 0mm 20mm Black 3D no dsk
T-Plate-Nexx #4 Black Carbon Fiber
Dampener (If applicable)- PN DDS (Purple top disk/Purple bottom spring)
Gearing-12/53 PN Ball Diff
Notes- Porsche ran EXTREAMLY WELL! I had 1 screw up on lap 58 that added 3+ seconds, but other than that a awesome run for me!!! If I pushed it any faster and I would ROLL! Old Porsche body is very top heavy. Hope to get a new white body 911 in soon!
  #3307
Class- NARROW
Date- 09/30/2025
Race Time- 333.539 / 5:33.539
Fastest Lap- 3.975
Chassis-MR03EVO
Body-Yaris
Wheelbase-90mm
Tires- F-PN KS Medium LH (KS1138) / R- PN KSK535 Soft
Wheels-F- 3D Disk N-0mm 19mm Blue #5 dsk / DXR N-0mm 20mm Gold 10spoke
Motor-PN 3500Kv
Front Springs-Kyo Orange (soft and short) on Inner Tube Shock Set dry
T-Plate-Nexx #4
Motor Mount-Nexx 90/94mm MM
Dampener (If applicable)- PN DDS Gold top and Bottom springs
Gearing- 12/53 PN Ball Diff
Notes- Car VERY good, Rt Arm was just worn out by this time, making many more mistakes than I should.
Old 10-01-2025 | 01:27 AM
  #3308
Originally Posted by joelisenat
Had a question, saw pictures on the Facepage group of people using tape on the side rails. Are many people using that? Or is it allowed? I don't remember anything in the rules specifically speaking about it. It would be a help I'm sure but I've never wanted to use it just because I like to change layouts and it seems like it would be a pain, but maybe it isn't too bad to be peeling that stuff off constantly?
Originally Posted by AM03GT
I also thought it wasn't allowed...
Hey Guys,
First off Sorry for the delayed response but I have been down for most of 3 weeks with covid. Also my laptop is still screwed up, so I leave it hooked up on the track, and I have a hard time with rctech on my phone (i'm not that phone savvy).
To answer your question, there was never a hard rule either way on tape. I really never considered it as I was worried about the sticky residue left on the walls since we move our tracks around so much. BUT after a close look at my walls after a few years of my wall banging, I've reconsidered it, and ordered a roll! After a bunch of searching and reading and seeing the large tracks using it in pics from all over the world, I understand most use it to save their walls, with the added benifit of them not being soo snaggy.
So until I'm told otherwise, meaning I missed it somewhere, I'm fine if ya want to tape ur walls.
I'm going to start with the corners, as I always see tiny red foam chunks in my bodies and on my chassis after a run. Then in a few key areas I am wearing the walls down. We'll see if the red and white striped tape screws with my eyes too much!!
Have Fun!!!
Old 10-01-2025 | 06:48 AM
  #3309
October CCW Layout
Have Fun!!!
ekim628 likes this.
Old 10-01-2025 | 08:20 AM
  #3310
Class-Open 2wd
Date-10/01/25
Location-Central Wisconsin
Race Time-7:18.988---438.988
Fastest Lap-5.2187
Chassis-Atomic MRZ-SF
Body-Jomura
Wheelbase-98mm
Tires-F-PN Mediums, R-Gekko Mediums
Motor-2500KV
Batteries-350mah 7.4
Front Springs-Atomic Green
T-Plate-
Motor Mount-Stock Atomic
Dampener (If applicable)-Atomic
Dampener Fluid (If applicable)-25000
Gearing-10/53
Notes,Better runs this month, pleased with the progress
ekim628 and BoxxerBoyDrew like this.
bj_rul is offline
Old 10-01-2025 | 08:49 AM
  #3311
No photos on this post as I can not post due to not reaching the limited post needed to post pictures. I have them loaded on the Facebook page.
Class- Boxstock
Date- 9/8/25
Location- Houston, TX USA
Race Time- 8:34.9201
Fast Lap- 5.500
Chassis- MR04
Body- McLaren 720S GT3 (Kyosho)
Wheelbase- 98mm
Tires- Kyosho 30° Super Low Height, Kyosho 20° Wide Radials
Motor- factory white cap 70t
Batteries- Speed House Mini Z 800HV
Front Springs- Boxstock Black
T-Plate- PN racing Carbon fiber #5
Motor Mount- factory Kyosho MM
Dampener- factory Kyosho
Dampener fluid- NA
Gearing- 7t pinion factory gear diff spur (Kyosho)
Class- Porsche Cup
Date- 9/5/25
Race Time- 8:52.380
Fast Lap- 6.230
Chassis- MR04
Body- Porsche 911 GT3RS (Kyosho)
Wheelbase- 90mm
T-Plate- Boxstock (Kyosho)
Motor Mount- factory Kyosho RM
Dampener fluid- NA
GrizzlyNateDog is offline
Old 10-01-2025 | 02:38 PM
  #3312
ekim628's Avatar
Pictures coming soon
Box Stock
Class- BOX STOCK
Date- 10/01/2025
Location- Lake Forest, CA
Race Time- 5:09:89 / 309.89
Fastest Lap- 3.69
Chassis- Kyosho MR03 Rwd
Body- Vett C8R
Wheelbase- 98mm
Tires- +1 PN KSK40/ +3 Marka 15 Radial
Wheels- Nexx 20mm/ Discs +1/ Reflex 20mm +3
Motor- Stock Silver Can
Batteries- Kyosho Speed House
T-Plate- PN #4 Carbon
Motor Mount- MM2
Dampener (If applicable)- No
Dampener Fluid (If applicable)- Tamiya AW grease on upper shock
Gearing- 7T Pinion (PN Pro Match) / Stock Differential (44T)
Note- Kingpin flip mod, AE black grease inside gear diff to slow down action. The car felt edgy with harder tires bc humidity floated around 60-75% which is highest this year so far. I didn't have time to get a solid run with softer tires due to time and humid conditions. I will have to bring my track indoors on these days. Marka tires have radial tread almost gone, this changed the chracter of the cornering. It becomes loose when car is pitched aggressively.
BoxxerBoyDrew likes this.
ekim628 is offline
Old 10-01-2025 | 02:39 PM
  #3313
ekim628's Avatar
Stock
Class- Stock AAA (PNWC SPEC)
Date- 10/1/2025
Race Time- 5:06.87 / 306.87
Fastest Lap- 3.59
Chassis- PN2.5 MR03 RWD
Body- Jomu
Wheelbase- 98mm
Tires- FR +1 PN KSK40 / RR +3 Marka 15 slicks
Wheels- Nexx / disc 20mm +1/ Reflex 20mm +3
Motor- PN 3500 kV
Batteries- Powerowl 1100 mAh
Front Springs- PN Soft Purple
T-Plate- PN Carbon #4
Motor Mount- Nexx LCG
Dampener (If applicable)- Nexx damper and dual spring shock
Dampener Fluid (If applicable)- Dry
Gearing- 16T Pinion 53 spur PNWC Spec, NEXX Light Weight Ball Diff
Notes: Fast and easy to drive. PN Carbon #4 gave the car some more initial steering.
ekim628 is offline
Old 10-02-2025 | 05:28 AM
  #3314
Default September 2025 Box Stock
Class-Box Stock
Date-9/12/2025
Location-Winston-Salem, NC
Race Time-306.469
Fastest Lap-3.825
Chassis-MR-03 FHSS
Body-2012 NSX
Wheelbase-98mm
Tires-PN KS Firm fronts, Marka V1R15 rears
Motor-Stock
Batteries-Carreras 850s
Front Springs-Kyosho Stock
T-Plate-Kyosho FRP 0.6H
Motor Mount-Stock MM
Dampener (If applicable)-None
Notes-I was only able to get about 10 tries in this month and my consistency was only 93.8% on this layout because bad laps seem to be more costly. Could probably find a couple of more seconds if I kept at it, but ran out of month.
Traveler2 is offline
Old 10-02-2025 | 05:29 AM
  #3315
Default September 2025 Porsche Cup
Class-Porsche Cup Class
Date-9/7/2025
Race Time-293.467
Fastest Lap-3.746
Chassis-MR-03 EVO
Body-911 GT3
Wheelbase-90mm
Tires-PN KS Soft on PN 19mm +0.5 fronts, Marka v1R10 on PN 19mm W0 rears (not pictured)
Motor-ATM 3500
Batteries-Amazon Basics 800s
T-Plate-GT55 +0.6 FRP #4
Motor Mount-Nexx Round RM
Dampener (If applicable)-PN G10 DDS and Kyosho Inner Tube Shock MZW442
Dampener Fluid (If applicable)-1300 Silicone Oil
Gearing-PN 64p 13/53 Ball diff
Notes-This car is super quick and fun, but a challenge to drive consistently. I only had three tries this month, but this was a pretty good run at 95.40% consistency.
