Mini-96 World Challenge
#1788
Class- Open 2wd
Date- 6/28/2023
Location- SoCal
Race Time- 334.167
Fastest Lap- 3.833
Chassis- Atomic MRZ SF
Body- SubRC Ferrari 458GT (Lexan)
Wheelbase- 98mm
Tires- 14mm PN Racing Super Soft Radials (rear), 9mm PN Racing Medium Slick (front)
Motor- Atomic Zenon 4500kv
Batteries- PN Racing 385mah LiPo
Front Springs- Medium
T-Plate- n/a
Motor Mount- Stock
Dampener (If applicable)- Medium spring
Dampener Fluid (If applicable)- n/a
Gearing- 53/7
Notes- First time posting to the challenge. These tight 30cm tracks lead to so many mistakes on my part. Hope to improve in the coming months. MRZ is also new and I am still dialing it in, but loving it so far.
Next month I will post for box stock and my pn2.5 chassis as well. Ran out of time.
Question - How can I post photos? Says I have not posted enough (first post) so I cant upload!
Date- 6/28/2023
Location- SoCal
Race Time- 334.167
Fastest Lap- 3.833
Wheelbase- 98mm
T-Plate- n/a
Motor Mount- Stock
Gearing- 53/7
#1789
Class - Box Stock
Date - 6/22/23
Location - Iowa
Race Time - 365.501
Fastest Lap - 4.025
Chassis - MR-03 MM
Body - McLaren 12C
Wheelbase - 98mm
Tires - K30LH / Marka V1R10
Motor - Stock
Batteries - Orion 750 SHO
Front Springs - Yellow
T-Plate - Kyosho Carbon Firm
Motor Mount - Stock
Dampener (If applicable) -
Dampener Fluid (If applicable) -
Gearing - 7T, stock diff
Notes -
Date - 6/22/23
Location - Iowa
Race Time - 365.501
Fastest Lap - 4.025
Chassis - MR-03 MM
Body - McLaren 12C
Wheelbase - 98mm
Motor - Stock
Motor Mount - Stock
Notes -
#1790
Gearing- 53/7
As for pictures, the system won't let you post any until you've reached 10 or 12 posts. Once you get that ability, you can edit your earlier posts and add the pics if you care to. There is also a FaceBook group that you can post them in if you'd like. But you don't have to worry about posting pics until you have the ability to do so...
#1792
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Another light month with 7 racers posting in only 3 classes this month. And welcome realwizer to the Challenge and chjosi back!
Box Stock
1st - Traveler2/Marwan Zabaneh - 282.2/3.48s
2nd - PoorBoy/David Krinard - 310.0/3.84s
3rd - Danjoy25/Dan Dylen Garcia - 358.5/4.24s
4th - Chjosi/None - 365.5/4.03s
Stock Class
1st - Traveler2/Marwan Zabaneh - 254.9/3.16s
2nd - PoorBoy/David Krinard - 291.4/3.53s
3rd - Danjoy25/Dan Dylen Garcia - 339.6/4.17s
4th - BoxxerBoxDrew - 388.0/4.38s
Open 2WD
1st - CRiXman/Cham Dass - 268.1/3.23s
2nd - PoorBoy/David Krinard - 296.4/3.41s
3rd - realwized/None - 334.2/3.83s
FTM goes to me in my Stock car with a 3.16 fast lap! Those RTRC rims/sidewalls are the ticket!
If anyone was late, please post up and I will update the results. Because I have some posting on RCTech and others on Facebook, I'm listing handle/name to more easily identify racers across the platforms. If anyone objects, please let me know. Also please check my tabulations and let me know if I made any mistakes or missed anyone.
Cheers,
Traveler2
Box Stock
Stock Class
Open 2WD
Cheers,
Traveler2
#1793
On a tight layout like this month I am only using full throttle on the straight away. It is much more about the shortest route around the track and a tight line between and in the corners. Going just a little wide in a corner will hurt your lap times. My fastest laps are usually when I feel like I am going the slowest.
#1794
Keep an eye on the bearings to make sure they are free spinning and nothing is adding friction to the drivetrain.
#1795
Welcome to the challenge! Learning to drive on the tight 30cm track made me a MUCH better driver on the larger tracks, so keep at it. I think you'll like it more with the slower box stock and stock cars too. I'd also recommend a larger pinion on your open 2wd. You might be getting too much wheel spin with the 7t and all that power.
Definitely have some spin outs on corners related to power. The car with the 4500 is a lot on this track, but its just so nice. So just need to manage it. I already have played with throttle speed and travel, messing with tires for the most grip (such as the 14mm), and swapped out the diff to the MC3. I even added the spoiler to my 483 body because I swear that helped with the rear traction.
#1796
Tires are also very important. I could never get on the pace with the Kyosho tires (I know others have made them work). If your track is new it takes months of laps before the traction comes up enough to turn really fast laps,
#1799
Is there a new layout this month? NOT trying to pester, as I am playing with the track designer from Zround and made a layout as close as I could to the Chicago Street Course Nascar ran last weekend, I'm just making sure I'm not missing it.
Thanks and Glad to see chjosi and WELCOME realwizer!!!
#1800
3035Likes
