Mini-96 World Challenge
#1816
Class- Box Stock
Date- 7/29/23
Location- Utah
Race Time- 376.46 (6:16.46)
Fastest Lap- 3.964
Chassis- Kyosho MR03 Readyset
Body- Mercedes AMG GT3
Wheelbase- 98mm
Tires- PN KS-M Medium slick front, Marka 5 rear
Motor- Stock
Batteries- Amazon Basics 800
Front Springs- Red (soft)
T-Plate- PN 4 carbon
Motor Mount- Stock MM
Dampener (If applicable)- N/A
Dampener Fluid (If applicable)- N/A
Gearing- Stock gear diff, 7T pinion
Notes- Happy with this result after getting the track out for the first time in 2 months
Date- 7/29/23
Location- Utah
Fastest Lap- 3.964
Wheelbase- 98mm
Motor- Stock
#1817
Class- Stock
Date- 7/29/23
Location- Utah
Race Time- 347.99 (5:47.99)
Fastest Lap- 3.736
Chassis- Kyosho MR03 Evo
Body- Jomurema
Wheelbase- 98mm
Motor- PN 3500
Batteries- Kyosho Speed house 800
Front Springs- Green
T-Plate- Running the gimble system
Motor Mount- PN v5
Gearing- PN gear diff, 16T pinion
Notes- This was my first run in any class under 6 minutes. Woot!
Date- 7/29/23
Location- Utah
Fastest Lap- 3.736
Body- Jomurema
Wheelbase- 98mm
Motor- PN 3500
Motor Mount- PN v5
#1819
Stock
Date-7/2023
Location- California
Race Time-249.94
Fastest Lap-3.04
Chassis-Pn 2.5
Body- F40
Wheelbase-990mm
Tires- R Marka 5
F PN KSM Med
Motor-3500KV
Batteries- Enloop
Never had a chance to get a good run with my faster stock cars this month.
Date-7/2023
Race Time-249.94
Fastest Lap-3.04
Chassis-Pn 2.5
Body- F40
Wheelbase-990mm
Tires- R Marka 5
F PN KSM Med
Motor-3500KV
Batteries- Enloop
#1821
Try as I could I couldn't get my MX-5 90mmRM to handle any better, so after installing the HeliCoils for the front clip screws I changed it back to a wide front end and 98mm for the McLaren 12C. I left the ride height the same as the MX-5, and I was getting traction rolls when I pushed for a faster than 3.5 second lap. I had only 2 needs for reverse, but a got hung up on the rails a few times which added at least 10 seconds to my total time! Anyway I'm shooting for a sub 3 second lap once I can get the traction rolls handled! The experts here are showing their skills with their SMOKIN LAPS and TIMES!!!
Class- Stock
Date-07/31/2023
Location- Central Texas
Race Time- 298.013 seconds/ 4:58.013 Minutes
Fastest Lap- 3.474 seconds
Chassis- MR-03
Body- McLaren 12C
Wheelbase- 98mm
Tires- F- N20mm +1mm PN BBS- PN KS-M low height medium / R- W20mm +2mm PN BBS - PN KS Radial soft
Motor- PN70
Batteries- Eneloop 800hv
T-Plate- PN #4 Carbon
Motor Mount- PN V3 94-98MM
Dampener (If applicable)- PN MR2061 Graphite Disk Damper- with Green bottom/Gold Top springs/PN Dual Center Spring Shock Green rear/Green front
Dampener Fluid (If applicable)- Dry
Gearing- 64pitch 10t pinion/53t spur PN Gear diff
Notes- White Body 12C, no window, lights(Waiting to figure out what colors I want to paint it). New KS-M tires have great grip. Steering DR at 86%. 0.4mm shims under/1mm shim above knuckle, #2 bearing holder with Axel in lowest position. Ride height is off! Higher in front than rear. Didn't check after rebuilding into 98mm! Duh Me!
Take Care and Stay Cool! Drew
Class- Stock
Date-07/31/2023
Chassis- MR-03
Body- McLaren 12C
Wheelbase- 98mm
Motor- PN70
#1822
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Another light month with only 6 racers posting. Because racing locally died recently, my goal was to run most of my 24 cars on the July layout and try to get a decent time with all of them. I got to run 18 of them (pics and results for most in FB group). And for the first time ever, I ran all 6 2WD classes this month since I now have a proper LiPo/brushless rig for open 2WD class. I was also happy to see that my times were progressively faster as the classes got faster, the only exception being my Pro Stock car that should have fallen in between my Stock and Open 2WD times, but was slower.
Box Stock
1st - Traveler2/Marwan Zabaneh - 245.5/3.11s
2nd - Danjoy25/Dan Dylen Garcia - 295.0/3.55s
3rd - LlamaRC/Doug Waite - 376.5/3.96s
Narrow Class
1st - Traveler2/Marwan Zabaneh - 242.3/3.07s
2nd - BoxxerBoyDrew/None - 349.9/3.94s
Porsche Cup Class
1st - Traveler2/Marwan Zabaneh - 231.4/2.84s
Stock Class
1st - Traveler2/Marwan Zabaneh - 221.6/2.81s
2nd - PoorBoy/David Krinard - 249.9/3.04s
3rd - CRiXman/Cham Dass - 253.9/3.12s
4th - sanny632/Nathaniel Holt - 269.9/3.20s
5th - BoxxerBoxDrew - 298.0/3.47s
6th - LlamaRC/Doug Waite - 348.0/3.74s
Pro Stock
1st - Traveler2/Marwan Zabaneh - 227.7/2.83s
2nd - PoorBoy/David Krinard - 245.6/2.93s
Open 2WD
1st - Traveler2/Marwan Zabaneh - 219.5/2.68s
2nd - CRiXman/Cham Dass - 231.7/2.82s
3rd - PoorBoy/David Krinard - 232.6/2.84s
FTM goes to me in my Open 2WD car with a 2.68 fast lap!
If anyone was late, please post up and I will update the results. Because I have some posting on RCTech and others on Facebook, I'm listing handle/name to more easily identify racers across the platforms. If anyone objects, please let me know. Also please check my tabulations and let me know if I made any mistakes or missed anyone.
Cheers,
Traveler2
Box Stock
Narrow Class
Porsche Cup Class
Stock Class
Pro Stock
Open 2WD
Cheers,
Traveler2
#1824
Class- 2wd box stock
Date- 7/31/23
Location- Sydney
RaceTime- 4:55.034
Fastest Lap- 3.548
Chassis- mr03
Body- Jomurema
Wheelbase- 98mm
Tires- Kyosho 30/20 Radials
Motor- stock
Batteries- Kyosho AAA
Front Springs- stock
T-Plate- stock
Motor Mount- Stock
Dampener Fluid (If applicable)- N/a
Gearing- Cross-linking flip
Date- 7/31/23
Location- Sydney
RaceTime- 4:55.034
Fastest Lap- 3.548
Chassis- mr03
Body- Jomurema
Wheelbase- 98mm
Motor- stock
T-Plate- stock
Motor Mount- Stock
#1826
Date- 8-3-23
Location- NC
Race Time- 7:08.630
Fastest Lap- 4.660
Chassis- mr03
Body- Mclaren 12c
Wheelbase- 98
Tires- front pn ks medium, rear kyosho radial 20
Motor- stock
Batteries- energizer 800mah
T-Plate- fiberglass 3
Motor Mount- mm
Gearing- 7t
Notes- first time running 30cm track, got some work to do.
not allowed to post pics as I'm new
Date- 8-3-23
Location- NC
Race Time- 7:08.630
Fastest Lap- 4.660
Chassis- mr03
Body- Mclaren 12c
Wheelbase- 98
Motor- stock
Motor Mount- mm
Gearing- 7t
#1827
Class- awd open
Date- 8-3-23
Location- NC
Race Time- 7:10.470
Fastest Lap- 4.920
Chassis- ma020
Body-nsx gt500 castrol
Wheelbase-94mm
Tires- front pn medium, rear kyosho radial 20
Motor- kyosho xspeed
Batteries- thunderbolt 900 mah
T-Plate- n/a
Motor Mount- stock plastic
Gearing-stock
Notes- new to 30cm track, going to take some time getting use to this.
cant post pics as I'm new.
Date- 8-3-23
Location- NC
Race Time- 7:10.470
Fastest Lap- 4.920
Chassis- ma020
Wheelbase-94mm
T-Plate- n/a
Gearing-stock
#1828
Class- stock narrow
Date- 8-3-23
Location- NC
Race Time-7:01.540
Fastest Lap-4.750
Chassis-mr03n
Body-Nissan s13
Wheelbase-90mm
Tires-front pn radial medium, rear gecko medium
Motor-stock
Batteries- thunderbolt 900mah
Front Springs- orange
T-Plate-pn carbon 3
Motor Mount-rm plastic
Gearing- 7t
Notes-first timer on 30cm
Date- 8-3-23
Location- NC
Race Time-7:01.540
Fastest Lap-4.750
Chassis-mr03n
Body-Nissan s13
Wheelbase-90mm
Motor-stock
T-Plate-pn carbon 3
Gearing- 7t
#1829
Class- Box Stock
Date- 7/29/23
Location- Utah
Fastest Lap- 3.964
Wheelbase- 98mm
Motor- Stock
Date- 7/29/23
Location- Utah
Fastest Lap- 3.964
Wheelbase- 98mm
Motor- Stock
3035Likes
