Associated Reflex 14B/14T >
Like Tree231Likes
Old 11-25-2018 | 02:52 AM
  #46
Just for future reference. The Losi Mini 8 REAR springs fit perfectly for anyone thinking of trying out different springs. Rears only though. Going to try them out tomorrow and see how they do, will keep you boys updated!
snoopone is offline
Old 11-25-2018 | 08:03 AM
  #47
Cain's Avatar
Tech Legend
Originally Posted by sal the salmon
also i think all my of hinge pins on the outer A arms are bent? They hinge, but not freely. And i tried to press one out from the access hole in the A arm with no luck. Kinda stumped on that.
It could be that the molding on the a-arm is snug around the hingepin. we see this even in race kits. A nice hole reamer will open that right on up so the pin can drop right on through, or, as you use the vehicle it will free up. Still check to see if the hingepin is bent of course.
For those looking for a servo option, the D135F is the metal gear version of the D115F. I haven't really notice gear strippage issues with the D115F, we in general just got the D135Fs here as an upgrade on the LC Racing kits. Spektrum also has a servo that may work, though not sure its any better than the Batan ones from what we have seen.
I am hopeful this takes off to support the class and AE makes a kit version that includes sway bars and some other upgrades. A nice servo mount that would allow you to use bigger servos would be cool.
Cain is offline
Old 11-25-2018 | 08:17 AM
  #48
i took a small L allen wrnech and pressed on the access whole to the point where the wrench started to bend and got no movement. is there maybe another techniique for removing them im looking over? i did remove the 3mm set screws. Im refering to the pins on the wheel end of the a arm
sal the salmon is offline
Old 11-25-2018 | 08:25 AM
  #49
if i were to upgrade my ESC and motor while i rebuild (to go with my new radio im going to get) what would you recomend? I saw the hobbywing that was posted here in a LHS but it was a 60 amp version? Is that motor posted the same as
https://www.google.com/search?biw=1635&bih=871&tbm=shop&ei=Q8z6W7CQI8LG0P EPr6ecqAw&q=4500+kv+28mm&oq=4500+kv+28mm&gs_l=psy-ab.3...6824.10496.0.10970.14.13.1.0.0.0.90.959.13. 13.0....0...1c.1.64.psy-ab..0.9.667...0j0i13k1j33i299k1.0.OEuhaneYNkE#spd= 446063066634694645
when i google for 2838 brushless i see lots of motors that look the same but im not sure what my best option actually is.
or should i be thinking one of these
http://casterracingmi.com/index.php?...roduct_id=1784
Old 11-25-2018 | 10:46 AM
  #50
Cain's Avatar
Tech Legend
This is the one that the Reedy basically looks like for ESC:
Hobbywing Quicrun 30 Amp Brushless ESC
Except now you can hook it up to a programmer card and tune it.
The 60 Amp unit I think you are talking about is this one:
Hobbywing Quicrun 10BL60 Sensored 60 Amp ESC
Looks like the quicrun version of the xr10 juststock esc and should work quite well too. May give you more options as it has the option of running a sensored motor if one fits in the vehicle.
As for motors, the LC Racing kits I would get in here we had them all equipped with the tenshock motor. It works quite well. The stock LC motor though looked like it worked fine too for the one guy who had one, no issues on heat in buggy mode (LC Racings SCTs and Truggies are longer)
Cain is offline
Old 11-25-2018 | 05:08 PM
  #51
jg6743's Avatar
anyone seen if diffs will work on m8?
jg6743 is offline
Old 11-26-2018 | 07:12 AM
  #52
Billy Kelly's Avatar
Been following thread since it was started. The Reflex is still on my list of possible. I wouldn’t expect much from Associated for it. Considering how long the mini8 was around and Losi didn’t fix any of the known issues. Instead created others by turning the original into 2 other vehicles.
If there is a class using it. Do what you can to promote it. It’s far to regional to expect Associated to see it as a clas for them to get involved supporting.
Pterosaur likes this.
Billy Kelly is offline
Old 11-26-2018 | 05:26 PM
  #53
rumor has it losi is considering an update? that would make three comp ready 1/14th scales (LC, ASSC, LOSI). Thats not a bad start to a class.
Old 11-26-2018 | 05:44 PM
  #54
3 would be a great way to get a class going. As for Losi doing an update. Haven’t read anything, other then they have discontinued the buggy. There were plenty of owners suggesting to Losi to offer it as a kit.
As for a full class. I don’t know if it would ever spread past a local thing. Not that theres any thing wrong with that. l I’m still relatively new to the racing side of the hobby( only on road so far). And while I’ve read a lot of good things about 1/14 scale. During the 6 years I owned the mini8 I only ever met 2-3 others in person. And like me, at that time none had been to a track.
Old 11-26-2018 | 05:54 PM
  #55
also after my teardown everything was fine execpt it seems my spur gear is out of round and the truck wont drive. its like it gets to the tigher part of the spur gear and then makes a sound like its stripping something. but the spur gear isnt getting stuck, its just tight to the point where the diffs must be slipping?
whats the easiest way to get the center diff out of the truck, id like to only remove whats needed. i didnt take the diff covers off until i had almost all the suspension tore down last time.
thanks.
Old 11-26-2018 | 05:55 PM
  #56
in the mini 8 thread here just a few days ago a losi designed hopped in and asked what sort of updates or changes the losi 8 drivers would like to be made for the platform. its not a news anncounment by any means, but to me it suggests they are at least considering it.
Old 11-26-2018 | 06:13 PM
  #57
Anybody know if the spur/pinions are .5mod?
vines is offline
Old 11-26-2018 | 06:20 PM
  #58
I missed the part about him being with TLR. Even still the buggy was around since 2011. These were not new suggestions. My point was that the racing side of the hobby is too small for the brands to commit to turning the Reflex into a full on race vehicle. It’s a RTR basher, that has racing potential. Hopefully Associated gives it a real chance to sell.
Old 11-26-2018 | 08:58 PM
  #59
ok so i figured out how to get the diff out without taking apart the suspension. (front and back diff covers, ESC mount, and lift up the a arms). So i took the 52 pin spur off (the rear bearing plastic was mushroomed around the bearing i had to pick off some plastic to get the bearing off. I installed the other gear that came with it to the diff, checked that it was nice and smooth (its smooth but it takes a decent firm pressure to spin it, perhaps to muc of the 5k fluid?), but when i went to reinstall it there is no way it fits.... like the 70t doesnt fit in the diff cover at all. what am i missing?
sucks to be a noob sometimes.
Old 11-26-2018 | 09:38 PM
  #60
update. im a noob. installed the chasis plate part, instaleld the diff. tested downstairs. no more nasty chirping sounds and the truck seems to be running smooth. will do a real test tomorrow on some tarmac.
