Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 03-19-2022 | 06:56 PM
  #3166
Here's my 2nd run. Found a nice dusty parking lot. She feels quicker here than at home. Also, forgive the crash. Distracted and driving with one hand. Don't drive distracted.
Still the same setup. 23-turn motor, stock ESC, 20t pinion, 68t spur.
ramp4ge is offline
Old 03-22-2022 | 07:54 AM
  #3167
Picked up a TT02r kit and a complete Yeah Racing aluminum kit and built a driveway monster.
Hobbywing Max10 esc and 4000kv brushless.
CptKaos is offline
Old 03-22-2022 | 08:00 AM
  #3168
Yeah Racing aluminum kit.
IndyRC_Racer, garnt and Gyosho like this.
CptKaos is offline
Old 03-23-2022 | 10:36 AM
  #3169
Originally Posted by fyrstormer
The main purpose of submerging a motor during a wet break-in is to subject the motor to significant drag, so the motor will have to work extremely hard for an extended period of time. The significant drag limits the motor's speed, which reduces the magnetic flux inside the can. The reduced magnetic flux is unable to generate as much inductive resistance in the armature coils as it normally would if the motor were spinning freely. The lower resistance allows the battery to push more amperage through the motor, and because that amperage is being pushed through a very tiny contact area between the brand-new brushes and the commutator, the contacting surfaces of the brushes get extremely hot and start to disintegrate. This accelerates the break-in process by an order of magnitude -- but it can also destroy soft brushes in a matter of seconds, as I and many other people have discovered over the years. A wet break-in is only useful (or safe) for motors with extremely hard brushes that would take an extremely long time to break-in without the continuous drag of running underwater. For brushed motors with softer brushes, a few full-throttle accelerations will put enough load on the motor to break-in the brushes, and then the commutator can be cleaned with electronics cleaner spray.
Regarding brush debris: Submerging the motor in water allows brush debris to be washed away instantly by the churning water inside the motor, whereas applying a few drops of water directly to the brushes just causes the debris to form a grinding paste that stays on the brushes. That's why the brushes broke-in so quickly for you. If it works, it works, but there's a significant risk of the brushes being damaged by so much abrasive material in such a small area.
(source for magnetic flux explanation: John Rob Holmes of Holmes Hobbies LLC)
All is correct, However as soon as the grinding paste accumulated it was washed away with 99% Isopropanol Alcohol to prevent that from happening. I broke the brushes in in about 2 minutes. 90% of the brushes were left with a smooth finish on both the brushes and comm. And this is the smoothest most crisp brushed motor I think I have ever ran.
The one I wore in by a few full throttle runs destroyed the comm. It was toast even after cleaning it off. Chunks of brush missing and comm scored to hell.
I'm extremely familiar with motors and electronics, I used to repair Telecom Infrastructure Boards from across the US and most of the world. The company I worked for also had a DJI drone repair department.
I can swap motors out and compare the two back to back in the same TT02. Whenever I get around to it lol.
TurboThirdGen is offline
Old 03-23-2022 | 01:03 PM
  #3170
bd007's Avatar
Where can I buy this part set? I want to replace the arms with Type S or SR kind. Or where can I find a Type S kit with reasonable price?
bd007 is offline
Old 03-23-2022 | 02:51 PM
  #3171
DirkW's Avatar
I've seen the Type SR (tuned up Type S) offered for 166€ in Germany (a bargain, considering that the normal Type S costs 150€). Plus about 20-40€ outside EU shipping shipping though...
DirkW is offline
Old 03-24-2022 | 05:04 PM
  #3172
Default Outdrive Upgrades
I'm about to build my 2nd tt-02r, and I'm wondering if cv joints/harder cups, etc. are available. Can someone tell me what the "hot" setup is and a source?
Many thanks
Electric Ned is offline
Old 03-25-2022 | 07:22 AM
  #3173
Hi guys,
Just have a quick question. Are the YeahRacing shocks 50mm the correct ones for the TT02? They also have 55mm but I am not sure which one is the right one.
Thank you,
lnc0321 is offline
Old 03-25-2022 | 09:01 AM
  #3174
Many thanks
The Tamiya universal option (53792) are going to be the nicest, but they are costlier and it appears mostly out-of-stock, in the US at least. The Yeah Racing universals are decent, available, and not quite as costly. The part number is YEA-TT02-015. You'll need to use their drive cups as well for the diff, which I think is YEA-TATT-017, but I would double check.
Originally Posted by lnc0321
Hi guys,
Thank you,
Yes, the 50mm are the ones to go with for TT02. I would recommend using the Tamiya o-rings. You'll likely have to sand down the plastic shaft guide a bit to keep it from binding.
TurboThirdGen likes this.
bentouttashape is offline
Old 03-25-2022 | 09:23 AM
  #3175
IndyRC_Racer's Avatar
You can find most of these parts directly at TamiyaUSA.com. Here is a link...
https://www.tamiyausa.com/search/?q=54634
Here are specific parts numbers and links...
54632 - carbon front damper stay (https://www.tamiyausa.com/shop/optio...-stay-front-3/)
54633 - carbon rear damper stay (https://www.tamiyausa.com/shop/optio...per-stay-rear/)
54634 - type s suspension mount set (https://www.tamiyausa.com/shop/optio...sus-mount-set/)
54636 - type s front mount (https://www.tamiyausa.com/shop/optio...eel-sus-mount/)
54637 - type s rear mount (https://www.tamiyausa.com/shop/optio...l-sus-mount-2/)
54638 - rebound stopper (for droop) - https://www.tamiyausa.com/shop/optio...bound-stopper/
Stock parts for the TT-02 Type S kit #58600 that are Fiberglass Reinforced Plastic (FRP) (https://www.tamiyausa.com/shop/110-4...s-chassis-kit/)
​​​​​​4305646 - front damper stay (for kit #58600) - https://www.tamiyausa.com/shop/7-dig...er-stay-58600/
4305647 - rear damper stay (for kit #58600) - https://www.tamiyausa.com/shop/7-dig...er-stay-58600/
I am currently in the process of rebuilding/upgrading my TT-02D Type-S kit and I have been able to find most of the parts I needed through TamiyaUSA.com Amazon, ebay, or various online stores. Some parts can be difficult to find so also consider looking at aftermarket companies such as Yeah Racing that offer decent/affordable upgrade parts of the TT-02. Here are some links
https://www.yeahracing.com/rc-car-pa...de-hopup-parts
https://www.yeahracing.com/rc-car-pa...e-hop-up-parts
https://www.yeahracing.com/yeah-raci...t-s04-00106044
If you can find/buy a TT-02 Type S kit, here are some links so you can compare the differences (note these kits are discontinued)
#58600 - TT-02 Type-S - https://www.tamiyausa.com/shop/110-4...s-chassis-kit/
#47301 - TT-02D Type-S - https://www.tamiyausa.com/shop/110-4...it/drift-spec/
#47439 - TT-02 Type-SR - https://www.tamiyausa.com/shop/110-4...sis-kit/tt-02/
If you are looking for some reviews and builds of Tamiya kits, check out THERCRACER.com. Here are some links you might find useful.
https://www.thercracer.com/2018/08/5...ld-review.html
https://www.thercracer.com/2015/09/t...build-and.html
https://www.thercracer.com/search?q=tt02
IndyRC_Racer is offline
Old 03-25-2022 | 10:38 AM
  #3176
Thank you
lnc0321 is offline
Old 03-25-2022 | 11:02 AM
  #3177
Thank you
I used the Yeah Racing combo listed. The drive cups are a little on the soft side. Some bashing on 4000kv brushless and 3s has indented some of them where the drive pin meets the cup. Still holding up fine though for almost a year of hard bashing. I've broken the universals, But not the cups.
Old 03-25-2022 | 12:21 PM
  #3178
I appreciate your help all.
I guess I'll have to go with Yeah by default. I've never been satisfied with the materials they use, but in the past I've had some luck hardening other manufacturers parts. Depending on the steel they use I might get lucky.
Old 03-25-2022 | 01:32 PM
  #3179
Guess I quoted the wrong username LOL. Yea just keep an eye out for the Tamiya stuff. It pops up on fleabay from time to time with decent prices. When that happens I usually buy extras.
Old 03-25-2022 | 08:06 PM
  #3180
Just finishing up the VTA Yeah Racing especial tonight.
MD, IndyRC_Racer and TurboThirdGen like this.
