Tamiya TA05 Touring Sedan
#6320
Originally Posted by savageguy
Ok....
The track surface is ashault. The Track Temperatue was around 50 celius.
My setup is -2 camber allround 0 toe front and 2 rear. 500# shock oil and Tamiya yellow springs. Tyres are GRP 35 allround.
And im Running 19 turn
#6321
Originally Posted by Core Creations
At least the brace parts are...the part # escapes me right now.
#6322
Originally Posted by ttso
Try rear damper incline 2 holes more than front first. Also, extend the front suspension forward so u get more weight on rear.
Thanks I will try that this weekend.
#6323
#6324
i wanna tryout some drifting with my ta-05 and was curious if anyone had a good suggestions on setups.
my current setup is:
* trf dampers with 3 hole piston shafts, 40 weight oil, and yellow springs (kit locations)
* LW reversible suspension with 46mm swingshafts up front (steel) and 48mm aluminum swingshafts in the rear
* 19x1 team orion element v2 motor
* ko propo vfs-1
* 105 spur gear and 45 pinion gear
* 2 degree front camber and 1 degree rear camber
* ko propo vfs-1
#6325
Ok....
The track surface is asphalt. The Track Temperature was around 50 celsius.
My setup is -2 camber all round 0 toe front and 2 rear. 500# shock oil and Tamiya yellow springs. Tyres are GRP 35 all round.
And I'm Running 19 turn
#6326
* ko propo vfs-1
* ko propo vfs-1
#6327
Suspended
In my rides softer springs are easier for me to control, although when i show people my setup they ALWAYS have something to say about it.. I feel that it is much easier and should be done by alot of people.
#6328
Regional Moderator
Originally Posted by mangobanana
how much in comparison is it to buy from champ rather than your lhs
On the small parts and replacement parts,(springs, parts tree replacement parts, etc) the lhs seems to be very well priced compared to champ, especially if you factor in the shipping and handling.
But, when you get into the hop up area, there is no comparison. Where $55+s/h will get you the carbon chassis here, that same amount will get you all the carbon pieces at champ. $50+s/h will get you the Tamiya motor mount here, but that same amount will get you the motor mount and a full set of alloy A blocks for the suspension.
So if your getting small stuff, go with the lhs. It'll be cheaper and inspire your lhs to keep stocking parts for the car. But on the bigger stuff,(anything above...say $20) definitely go with rc champ. You'll get it cheaper, and faster than a lhs can special order it.
Whatever you do, do whats best for you. Don't let anybody guilt you into over spending with that "support your lhs" stuff. If you save money on the big stuff, it'll leave more money in your pocket to spend on stuff from the lhs like bodies, tires, paint, repair/replacement parts, etc...
Then you get your big stuff AND some small stuff to go with it, and the lhs will still get their support. So every body is happy.
#6329
Has anyone here heard of a new variant called the TA05R package?
Any idea what parts it may come with?
Regards to all .
Regards to all .
#6330
proceed5,
From the pictures, it looks like the TA-05R will be just like your TA-05 except yours has more carbon fibre bits and more blue parts.
