Hot Bodies Cyclone
#6451
Super Moderator
Originally Posted by pinggoy
hi guys.. just got my electronics for my cyclone (gtb and 13.5)
and while im installing them . i notice that the electronic side is so heavy than my bettery side(gp3300) by adding weight on it i probably need more than 40g ..so would that make my car heavy and run sluggish.
here is electronics
ko propo 2343 servo
amb (stick on the back of my servo)
spektrum sr3000 (spektrum capacitor)
gtb
13.5 motor
and iam using a 3300gp batteries. (will use for practice)
if anybody knows the weight of each of those electronics and the battery i would appreciate if you give me the weights. since i dont have any scale....
thanx guys.. will be testing it tom.
here is electronics
ko propo 2343 servo
gtb
13.5 motor
i added 1 oz in front of the battery and 3/4 oz in the rear of the battery (3800's)
#6452
thanx i would probably buy a scale.so weight my electronics. my micro spektrum receiver is comming (80$ nip thanx to jason at rc revolution) hopefully it will take out a bit of my weight.and hopefuly will buy a low profile servo.. i will be using 3300 for practice.since i got alot of them new. and its not worth selling them for cheap.
#6453
Super Moderator
#6457
All my batteries, from 3300 to 4200 weigh considerably more than any combination of electrics I can come up with.
3300-387 grams
3800-409 grams
4200-430 grams
Novak GTB 87 grams
3.5 motor 186 grams
Spectrum 5 grams
Futabo 9550 with transponder 60 grams
Total 338 grams
Novak GTX 49 grams
Checkpoint 8 single 175 grams
Spectrum receiver 5 grams
Total 289 grams
Dave
3300-387 grams
3800-409 grams
4200-430 grams
Novak GTB 87 grams
3.5 motor 186 grams
Spectrum 5 grams
Total 338 grams
Novak GTX 49 grams
Total 289 grams
Dave
#6459
Just got my new HB Cyclone, the one i bought from Schreff in Bethlehem, PA. Wow! What a car- well maintained and very clean. Its perfect and in mint shape, like new...cant wait to run it. I just hope the diffs hold up. Will test it against my T2'007. I have driven both Cyclones and T2's this past year, and both cars are great. THe Cyclone is much easier to set up, simpler. It just works, quicker, and has deadly steering and corner speed. The T2 you have to work a bit more to get it to work, but once you have a good set up, it can also handle great...the T2'007 is a bit easier to set up, and T2's in general will not have diff issues, nor weak CVD's or rear ballstuds that snap...Let's see how it does against the '007.
#6461
The Cyclone is a great car. This is a general question. What MM shim would you run under the arm mounts. I am running 2mm now. Need more traction at Socal.
#6462
hi,
WCE cyclone-just started the build...
Is it still recomended that you sand the cf bottom deck to allow the belt more room... its awfully close...but has it been altered from factory... (just before reaching the front diff...) as seen on the hara tips...
Is the diff screw less likely to snap than previous versions...?
also, when building the diff before its put into the car... should it be tighten so it is completly impossible to move the gear when holding both outdrives...? (even if ALOT of force is exerted...)
:edit: sorry missed abit,
If your running a ball diff at the front, i asshume you have to use the direct shaft rather than the one for way...? (what happens when oneway layshaft and 'pully's?' are used with a spool diff in lol
thanks alot guys...
thanks alot guys...
#6463
#6464
Originally Posted by Besercoe
I am new to the cyclone, however on the 415 i never liked the feel of the raised arm mounts. I tried raising the arms mounts like as in the Moore WC setup at the reedy race of Asia, and the car just felt numb, I think i prefer to keep em on the deck and play with shock oils and springs instead.
Thanks for the info!!! I have a few different set-up from Hara and he always run about 1-2 mm shims. Like I mentioned I have 2mm shims in there now. I will try 1mm and see how that runs.
