Xray T3 2012
#2671
quick question, i would like to know if im reading this xray setup sheets correctly, when he has checked off in the boxes next to the wheelbase setting 2(x), 1, 0(x) can someone explain what these setting are and where do they go, ive included the actual setup sheet so you have a better idea what i mean. Thanks for any help. The problem im having here is why is the 0(x) checked off is that a shim or spacer?
#2672
I ended up using the 2mm chassis & 2mm top deck. With the 1.6mm top deck car had too much steering and was more difficult to drive.
When I compared lap times between the 2.5 mm and 2 mm chassis (both using 2mm top deck) lap times were exactly the same. Only difference is that the car is easier to drive.
#2673
#2675
I don't understand why it has a '0' box at all, but if the 2mm is ticked, then a 2mm spacer is in front of the rear wishbones, if the 1mm box is ticked then a 1mm spacer is in front of the wishbone.
You then put put whatever spacers were'nt used at the back of the wishbone.
The rear uses a total of 3mm of spacers, the front 1mm.
So if 2mm is indicated on the rear wishbones, a 1mm spacer is fitted at the back of the wishbone.
#2676
If you look closely the arrows from those check boxes point to the spacers in front of the wishbones at the front and the back of the car.
#2677
I have the new servo mount 306220 can you use the new servo brace together or is anyone doing that now.
#2678
What is the best set up sheet to use for asphalt with a 225 back straight temps about 80 -90 deg. Any tips..... Thanks new to onroad love it.
Running a Revtech 17.5 with orion vortex r10 2-3. Gearing 47 and 100. Final drive 4.04. Should I go up with my final drive. I see people running up to 6.0 or 7.0 FDR.
#2680
Hey guys one of my hex bolts that holds the gear diff housing together is stripped any ideas how to get this out ...everything i have tried is making it worse ....am i screwed (no pun intended lol) or does someone know of a solution.
#2681
http://www.sears.com/shc/s/search=sc...e=CAT_REC_PRED
#2682
Anyone having problems breaking rear belts running mod
I have broke 2 within the last month is this normal
