Like Tree1Likes
Xray T3 2012
Old 05-21-2012, 02:58 AM
  #2521
alecladanga's Avatar
hi guys
anybody could point me to a good set up sheet for the following conditions: low -medium traction, asphalt, 40 feet straight, indoor, 13.5T boosted?
thanks in advance.
alecladanga is offline
Old 05-21-2012, 03:11 AM
  #2522
Default Dogbone wear
Anyone ever experienced with the wear on the rear dogbone as shown in the attached picture?
Kit: T3 2012
Rear Gear Diff with stock Alu outdrive
Dogbone: 50mm
Rear Toe: Inboard 3 Degree Toe in
I never find this problem before on any other previous xray kit. It is obvious that the 'ball' of the dogbone rubs against the inner wall of the Alu outdrive. The option spring steel gear outdrive is slotted, can changing the spring steel one improve the problem?
Thanks very much!
klth is offline
Old 05-21-2012, 05:07 AM
  #2523
nerdling's Avatar
Kit: T3 2012
Dogbone: 50mm
Thanks very much!
Some debris caught in the out drive?
nerdling is offline
Old 05-21-2012, 05:39 AM
  #2524
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Originally Posted by aceinthesky
what is the best combo for stock racing 17.5 blinky with motor timing. i have the viper 17.5 and viper vtx10 esc, is there something better than this. i also have a tekin rs esc that i'm not using right now. thanks.
The viper does have a better BEC that is adjustable. The tekin BEC can brown out your rx when running high voltage servos. This usually happens with spektrum radios and tekin esc's along with the high voltage servos that are popular now.
rdlkgliders is offline
Old 05-21-2012, 08:45 AM
  #2525
Skiddins's Avatar
Originally Posted by alecladanga
hi guys
thanks in advance.
Slightly larger track, but might be of use;
http://piez0r.com/Skiddins/Xray%20Se...%29-4-5-12.pdf
Skiddins is offline
Old 05-21-2012, 10:36 AM
  #2526
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Originally Posted by Skiddins
Link is not working for me.
Jamison R is offline
Old 05-21-2012, 10:57 AM
  #2527
Skiddins's Avatar
Original link should now be fixed
Skiddins is offline
Old 05-21-2012, 09:07 PM
  #2528
I think it is very unlikely.
I guess the dogbone is too angled.
I cant see any problem in the front, im using gear diff, Alu outdrive, 52mm bone, 1.5 degree Outboard Toe out.
klth is offline
Old 05-21-2012, 10:27 PM
  #2529
Thank you very much!
Old 05-22-2012, 01:59 AM
  #2530
Kit: T3 2012
Dogbone: 50mm
Thanks very much!
Dont have my t3 2012 kit anymore so I could be wrong but isnt the rear meant to be the 52mm bone? Could it not be far enough in the outdrive and wearing due to slop?
Simon
Team_Krusty is offline
Old 05-22-2012, 02:30 AM
  #2531
Simon
ya the kit comes with 52mm Alu rear bone
i remember i saw some where else saying the bone would cause binding with the outdrive if the rear camber is above 1.5. I always run 1.5 or above camber so thats the reason i run 50mm bone
klth is offline
Old 05-22-2012, 02:43 AM
  #2532
I always run 2 deg camber and dont remember having any problems. Try swapping back to the 52mm and just check for any binding. I dont know if this will fix your problem but that wear seems unusual.
Simon
Old 05-22-2012, 05:19 AM
  #2533
Trader Rating: 38 (100%+)
Anyone know when RC America is supposed to get their next shipment of T3s?
Also why would RCA charge $19 shipping for 4 small parts to my LHS. It makes already expensive parts VERY expensive. Hopefully they don't charge shipping on each individual shipment since they didn't send everything together.
or8ital is offline
Old 05-22-2012, 06:54 AM
  #2534
M-Technic's Avatar
Trader Rating: 15 (100%+)
I believe they are getting a shipment in this week... next week at the latest.
Their shipping is very reasonable. Maybe the hobby shop had it upgraded to second day air or something?
M-Technic is offline
Old 05-22-2012, 07:43 AM
  #2535
Nope. FedEx ground. The LHS couldn't explain it.
or8ital is offline
