Like Tree1Likes
Xray T3 2012
Old 11-03-2014, 06:57 AM
  #4171
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
I got a question on what you guys are seeing when you mate up your pinion to your spur.
For the USGT class I went ahead and used a setup that called for a 96T spur and a 49T pinion. as I was working in general on rebuilding the vehicle I had the top deck off, and I noticed that the spur that was on the vehicle (Robinson Racing) didn't have the holes in it to reach through and reach the motor screw that woudl be closest to the spur gear side.
No sweat, changed over to an xray spur gear but then noticed the hole was not big enough to fit the screw threw?
this made me wonder, if I can't get the screw threw the hole to get to the motor, how are people doing this when they take th emotor completely out the car? Also the angle even with a ball driver was very extreme to reach. I ended up going to a 2.5mm cap screw to get a better angle and better chance of not stripping the screw.
Anyway any tips on this? i didn't notice this last year with the VTA versions, but I was using different spur gear size so maybe that is why.
Cain is offline
Old 11-03-2014, 06:58 AM
  #4172
Tech Legend
Cain's Avatar
Cain is offline
Old 11-03-2014, 07:59 AM
  #4173
dwestlund's Avatar
I've dremelled out a little on my Core-RC spurs to get the access to the screw. It works well enough for now. Some spurs/pinion combos do require me to take the rear wheel off.
dwestlund is offline
Old 11-03-2014, 08:12 AM
  #4174
Tech Legend
Cain's Avatar
thanks for the info. One thing looking at the issue made me wonder if people were only tightening 1 screw, the one they can reach and using the other as more of a "guide" screw.
Cain is offline
Old 11-03-2014, 11:42 AM
  #4175
Mr Weasel's Avatar
Hi, this frustrates me too.
I set the gear mesh and tighten the front motor screw. Then lift out the spur from the bulkhead and tighten the rear motor screw.
It's pretty fiddly with belts etc but works ok. It's not a quick change to add a few teeth to the pinion
Mr Weasel is offline
Old 11-03-2014, 11:56 AM
  #4176
Tech Legend
Cain's Avatar
yeah I can see how calling it "good" and just going with the gearing can come up if you run at a place that doesn't have much time between heats. when looking at the vehicle I was thinking maybe to use less screws that hold on the top deck to make the change faster.
Cain is offline
Old 11-06-2014, 08:16 PM
  #4177
Brokin Racing's Avatar
Trader Rating: 74 (100%+)
Apart from taking the top deck off & that's only to make things easier, I don't have any problems with spurs (48p) in 21.5. Using 68/36
I do use a body reamer at times on the spur to make putting a screw thru it easier
Find the T3'12 easy to drive & is still competitive against current cars
Brokin Racing is offline
Old 11-07-2014, 06:42 AM
  #4178
Tech Legend
Cain's Avatar
its definitely still a good car. hopefully will get to really get some time in with it this winter.
Cain is offline
Old 11-14-2014, 08:38 AM
  #4179
Trader Rating: 57 (100%+)
Im having Loose corner entry problems with my T3-12, can anyone shed some light? USVTA 5mm front 5.25mm rear, 2mm fr droop 3mm r. 3.0fr spring-400 oil, 2.6 r spring-350 oil. 1000wt gear diff rear, fr one way.
Race19s is offline
Old 11-14-2014, 08:43 AM
  #4180
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
Put the spool back in or a gear diff to see if helps any. Also you can try a shorter link in the rear.
R3VoLuTiOn is offline
Old 11-14-2014, 08:44 AM
  #4181
worse with the spool/diff in fr
Race19s is offline
Old 11-14-2014, 08:45 AM
  #4182
I have the shortest upper link possible
Race19s is offline
Old 11-14-2014, 09:05 AM
  #4183
R3VoLuTiOn's Avatar
what are your roll centres + shims, upper link shims, and how long are you saucing?
Old 11-14-2014, 09:20 AM
  #4184
liljohn1064's Avatar
Trader Rating: 17 (100%+)
How is your weight bias front to rear? Are you on power or off power? Do you notice it getting better on or off throttle?
liljohn1064 is offline
Old 11-14-2014, 09:51 AM
  #4185
daleburr's Avatar
Put the spool back in the front, reduce rear droop by 0.5mm, and thicken the rear diff up to 2000wt.
daleburr is offline
