Like Tree1Likes
Xray T3 2012
Old 01-08-2012, 04:42 PM
  #1171
Regional Moderator
CarbonJoe's Avatar
Make sure you sand the slots in the chassis that the tape passes through. Otherwise, the sharp edges of the CF will cut through the tape.
CarbonJoe is offline
  #1172
haywood's Avatar
Trader Rating: 49 (100%+)
Originally Posted by RobS
The top tape is probably the best tape I have used. Never had an issue with battery movement running 17.5 boosted and modified. One piece of tape front to back, and one piece through the battery slots going left to right and it won't move.
I use the Top orange tape! Looks cool too!
haywood is offline
Old 01-08-2012, 06:05 PM
  #1173
Originally Posted by CraigM
Why do you think link length has an impact on roll centre? It doesn't, read up on how roll centre is calculated and you'll see why
Dear all
Had a chance to try some set-up combinations yesterday. The best result / lap time came from using the longest FRONT camber link which improved mid-corner steering a lot. Harder FRONT spring was also required or the car pushed during high speed to U-turn entry.
Steering response also improved a bit when adding bump steer to 3mm.
On-power steering still push and no improvement.
yokfans is offline
Old 01-08-2012, 06:10 PM
  #1174
Suspended
Trader Rating: 35 (91%+)
Hi all ran my car today for the 2 time and had a traction issue.I would b running and half way thru a race about the 3 min mark the car would gt loose any ideas on what would cause this?. Any help would b appreciated.I am running the box setup.
j dogg is offline
Old 01-08-2012, 07:40 PM
  #1175
Trader Rating: 23 (100%+)
Sounds like your front tires are overheating. Likely have to adjust your setup a little.
pcar951 is offline
Old 01-08-2012, 07:57 PM
  #1176
Suspended
What would u recommend trying?
j dogg is offline
Old 01-08-2012, 08:17 PM
  #1177
There's a ton of things you can do all the way from saucing a little more (longer) on the fronts and turning down your dual rate, ackerman, front roll center. Basically, I've controlled front tire temps by adding front grip and not letting the front tires slip so much (friction makes heat). Or you can work on losening the rear of the car overall to get better rotation without excessive steering input.
pcar951 is offline
Old 01-08-2012, 08:29 PM
  #1178
Meradin's Avatar
Trader Rating: 19 (100%+)
Originally Posted by RC MARKET
A+ & CSO Released upped bulkhead
A+ lower 1 mm
CSO lower 3mm
Does this mean these are lower than the stock clamps?
Meradin is offline
Old 01-08-2012, 08:33 PM
  #1179
Suspended
OK.ill try soaking them longer.I like a lot of steering. When I turn my dual rate down I loose time in the tighter sections. Thanks for ur input.
j dogg is offline
Old 01-08-2012, 08:47 PM
  #1180
pchroma24's Avatar
Trader Rating: 83 (100%+)
+1
pchroma24 is offline
Old 01-08-2012, 09:50 PM
  #1181
artwork's Avatar
Trader Rating: 88 (100%+)
I have spent a lot of time with the T3 2012 over the past few weeks and I can tell you that it is one of the best cars I have ever run ( I have owned and run over 30 touring cars). It is great to work on and the car really works on the track. If you are considering a new touring car this car should be it...
The changes from the 2011 to the 2012 are very significant, and it shows on the track.
I have yet to run it outside, but inside on the carpet has been a great experience.
Looks like I will be buying a second T3 2012 here soon
I know I have been a hater, but running this car has really changed my view on the Xray platform. Looks like Xray really got it right with this car.
artwork is offline
Old 01-08-2012, 11:56 PM
  #1182
RC MARKET's Avatar
yes !
RC MARKET is offline
Old 01-09-2012, 12:04 AM
  #1183
Benzaah's Avatar
Trader Rating: 24 (96%+)
This is the best tape you will find Full Stop.
http://www.nexusracing.com/product_i...products_id=49
Benzaah is offline
Old 01-09-2012, 03:20 AM
  #1184
Skiddins's Avatar
Originally Posted by yokfans
Dear all
I was told to stand shocks up more to prevent push through a corner.
It makes the tyres bite more through the corner. If grip comes up and the car starts to hook, start to lay them back down.
It worked for me.
Skiddins
Skiddins is offline
Old 01-09-2012, 07:53 AM
  #1185
Meradin's Avatar
yes !
Wow, 3mm lower than the stock clamps. How does the change the cars handling?
Meradin is offline
