EPIC "D3" Duo 3
#391
6.3 FDR
48 boost
10000 end rpm
3000-4000 start
8 turbo
delay .3
ramp 2
motor timing 2nd notch on + side
I'm pretty sure its not the settings as I used the same settings with another D3 for the rest of the weekend and it was fine. When my motor blew I had literally just put the car down on the track and did one lap. Never was free revved either.
48 boost
10000 end rpm
3000-4000 start
8 turbo
delay .3
ramp 2
#392
6.3 FDR
48 boost
10000 end rpm
3000-4000 start
8 turbo
delay .3
ramp 2
48 boost
10000 end rpm
3000-4000 start
8 turbo
delay .3
ramp 2
#393
I bought a Trinity Duo3 17.5 Been running it on an indoor carpet oval track in an EDM oval car-sorry this isnt a on road car but there seemed to be alot of good knowledge in this forum so I had to ask. It is a non boosted esc(Tekin RS Pro-Blinky Mode) class. I want to to bump the timing up on the can but not sure how much to go and exactly how to go about it. On the endbell is a 0 and on the can is a + with spaced marks to the left of that. Right now with the motor at 0 (as it appears) my gearing is correct and my temps are great but looking for a little more speed. Thanks
#394
#395
#398
Has anyone tested different rotors in 17.5 tc spec (no boost)? If so which rotor and fdr. thanks
#400
I just picked up a used D3 13.5 and when I got it I spun the motor by hand and noticed that it was pretty noisy, sounded like a rattle, certainly didn't sound smooth. Once installed I ran the car and it was immediately noticeable the noise it made, the car made good speed but the noise was concerning. Is this typical of this 13.5 or is there something wrong here? I have a D3 17.5 and it's whisper quiet so I'm curious as to why this motor would be this noisy.
#401
#402
Team EAM
EA
#403
EA,
which rotor do you recommend for 17.5 non-timing in TC? and what do you consider as to how the rotor is properly shimmed.
Any info would be appreciated.
thanks
thanks
#404
Anyone that has a good setup for EPIC D3 13,5 motor with LRP Stock Spec V2?
#405
Has anyone who has used the Duo2 and moved to the D3 found you need to change your normal gearing (FDR) much ?
Depends on the track as to gearing I know, but on a back to back using the Duo2 at the same track was there much if any difference ?
I run a Tekin RSPro. normal settings (latest Vegas software)
.02 Turbo delay
50 Boost
16 turbo
3 steps
2500 rpm start
10001 rpm end
no motor timing at all.
FDR approx 7.12 on a moderate complex track with 20-25 metre straight
This is on the Duo2, average temp is 65 Deg C (not sure what that is in F), normaly they say don't breach 80 Deg C so im well within that.
Would the D3 see this change much, if at all ?
cheers for any help
.02 Turbo delay
50 Boost
16 turbo
3 steps
2500 rpm start
10001 rpm end
cheers for any help
