EPIC "D3" Duo 3
Old 03-14-2011, 07:17 AM
  #376
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by piper48
Just picked up a D3 17.5 but haven't ran it yet. I was wondering if these motors are built for Torque or RPM?
I'd say a combination of both...
M-Technic is offline
Old 03-14-2011, 02:36 PM
  #377
Default How does the D3 compare to a lrp X12 13.5 using a Tekin ESC
Just looking for people who have run them to give me there thoughts please
FLAT OUT is offline
Old 03-14-2011, 02:47 PM
  #378
bagged69chevy's Avatar
Trader Rating: 22 (100%+)
Id say they have tons or torque, so your able to gear them a lot lower to get the top end out of them, without loosing the bottom end.
bagged69chevy is offline
Old 03-14-2011, 03:56 PM
  #379
Grenade10's Avatar
Trader Rating: 40 (100%+)
Purchased a new 17.5 D3 for racing at our up coming carpet race, and am not able to adjust the timing or did not want to damage it in getting it to move.
Any tricks or instructions????
Grenade10 is offline
Old 03-14-2011, 05:07 PM
  #380
Team EAM
Trader Rating: 79 (100%+)
Loosen the 3 long screws that come in from the pinion end. If those are to tight it will lock the timing ring down. If that dont work lightly tap the ring with a screw driver and it will free it up.
EA
EAMotorsports is offline
Old 03-14-2011, 05:23 PM
  #381
Grenade10's Avatar
EA
Thanks EA,
I had only done the 3 on the sensor side. Motor was teched for a BRL race with paint on the long screws, so did not give that a try.
Old 03-15-2011, 08:51 AM
  #382
JayBee's Avatar
Trader Rating: 31 (100%+)
What's the stock rotor that comes in the 17.5 & 13.5 motors; and is there a smaller one (what mm is it?) used in 1s applications?
JayBee is offline
Old 03-15-2011, 09:13 AM
  #383
theisgroup's Avatar
the stock is a 12.3 broad powerband rotor.
there are a total of 6 rotors. they are rated at high rpm, hi torque, and broad powerband and then 2 sizes. 12.3 and 12.5
i tried the 12.3 high rpm rotor and did not really like it. more testing is needed. i spoke to EA at the snowbirds and he has done some testing with the rotors. not sure if he found a better combination. i think most of the stock 1/12 guys were running the stock rotor
someone posted a chart about a week or 2 ago
theisgroup is offline
Old 03-15-2011, 09:25 AM
  #384
JayBee's Avatar
Thanks Yangsta!!
JayBee is offline
Old 03-15-2011, 09:33 AM
  #385
theisgroup's Avatar
Originally Posted by JayBee
Thanks Yangsta!!
np J of the B. i have a pdf of the rotors if you are interested. just shoot me your email
Old 03-15-2011, 03:29 PM
  #386
Trader Rating: 20 (100%+)
Jes purchased a D3 17.5 for my TC and cant seem to find a starting setup for my RS.
Medium sized asphalt track
track temps about 110-120
FDR 6.44
can someone point me in the right direction
goots is offline
Old 03-15-2011, 04:13 PM
  #387
RobS's Avatar
Been running a D3 21.5 in a VTA for ages without an issue. Finally switched my Rubber TC to the 17.5 D3 this weekend and detonated a rotor on its 2nd run. Anybody else have this kind of problem?
RobS is offline
Old 03-15-2011, 07:59 PM
  #388
Bonadona's Avatar
Trader Rating: 27 (100%+)
I had the same issue with mine and after trying what EA said still no luck. I took it apart to check it out and noticed the aluminim semi-circle slot the sensor board rotates in was very roughly cut and would not allow the feamle end of the sensor board to move freely. Just a little clean up with a hand file and smooth as butter.
Bonadona is offline
Old 03-16-2011, 07:09 AM
  #389
M-Technic's Avatar
Nope.
What was your gearing/ESC settings?
Old 03-16-2011, 07:15 AM
  #390
FDR 6.44
i run on a tight/small track and use 42 timing, 10 turbo, 2 ramp, 3000-11000 rpm, throttle profile 5 and fdr 6.0 or 6.21 (one 64p tooth)
Brian Bosley is offline
