EPIC "D3" Duo 3
#421
Can someone tell me where or how on their site I can send my motor back to EPIC/Trinity to have them take a look at my 13.5? I have looked on the site and clicked "Support" but it only shows Support for the nitro engines.
My issue is that the motor is very noisy and was told that the bearings may not be seated properly (EA's observation). I tried what he suggested but with no success.
Any help would be appreciated.
Eric
Eric
#422
Eric
Eric
#423
Eric
Eric
#424
Eric
Eric
I check the bearings and re-greased them and they were perfectly smooth.
So I took a look inside the stator where the rotor sits and noticed that there was something inside against one of the walls of the stator and the rotor was rubbing / touching it when it rotated... only touching it very slightly.
I took a flashlight to it and what it appeared to be was some resin / glue that had leaked into the inside of the stator and set hard - I assume this is the same resin/glue that was used to build the stator (ide never run the motor hot) or had the motor apart before
so I took a scapel and cut away at the material until there was very little left and the rotor spun without touching it.
Now the motor runs super smoooth
hopefully this picture should describe it better. What I must add though, is that these motors are AMAZINGLY good.
#425
Sorry if this has been asked before, but on the D3, approximately how many degrees of timing does each notch represent?
#427
It might be worth checking the following. When I got my 13.5 it was fine for a run and then it got progressively noisy and started sounding like a tractor with a noticable drag brake sensation.
Dane I'll just keep my $10
M-Technic Thanks for the number!
#429
Does anyone know where/if I can buy these in the UK?
#432
hi mate try here i know he has them in stock to http://www.rr-rc.com/ourshop/cat_190...ss-Motors.html
great motors i love them
Ginge
Ginge
#433
UK STOCK
DMS have them in stock 10.5 and 13.5 due soon
#435
rollout and timing for 1/12th and WGT
Just got an Epic duo3 10.5 plan to run in my 1/12th 1s and 1s WGT looking for rollout and timing for the said motor.
