Tamiya TRF417
#931
I am having the same issue with the Tamiya High-Torque Servo Saver. My car was running fine until I couldn't figure out why it wanted to pull one side after mildly hitting a corner (indoor carpet). I rechecked my camber, tweak and found no issue. Later I observed that my servo save has some play at the center.
I'll rebuild the servo saver and pinch the spring and see if that helps.
Thanks for the tip.
Thanks for the tip.
#932
#935
oil WT
Is there a performance difference with the two?
Has anyone tried out the 3racing gear diff? I have heard it suits the 416/417 and with almost half the price. not sure about quality though
#936
Don't use the 3R unless you like snapping belts and stripping the internal gears!
c'mon Ed the carbon c-hubs are about twice the size they were when we were snapping them like twigs with the original 416. I think I only broke one the whole time I ran the X, so feel free to hit as much stuff as you like with them
1000wt is popular because lighter oil leaks out of the spec R diff. People run much lighter (e.g. MM400 shock oil) in other diffs.
I've also heard you can use the xray NT1 big oring on the spec R to stop the leaking through the gasket. Haven't tried that tho
The plastic hubs are a lot more durable, but also more inconsistent, IMO. Switching for the carbon reinforced ones will give a bit sharper steering, although more prone to breaking. Personally, I no longer bother running the plastics, and just run the risk of breaking a c-hub... does teach you not too try and hit as much stuff (not that I have mind! )
#937
Cheers, so am I to understand that you have 2 gear diffs i.l.o. spool to front and gear diff to rear?
#938
#939
hi guys, just thought I'd share something. I am waiting on some alloy C hubs for my car, but I also discovered I had a few sets of evo4 C hubs in my old 415MS box from years ago. I paired them up against the 417/TA05IFS hubs, the are different, not as much distance for the knuckle to fit in, so I took about a 1mm or so maybe a touch more out of the hub with a small file, put the flanges in and the knuckle fits perfectly. Only difference is, now I didnt fit the small 0.7mm spacer between the top of the knuckle and the top flange, I put it on the top king pin to stop the screw going in too far and jamming up the CVD, also I thing that keep the roll centre the same. I'll take a pic later. very easy.
The Evo4 Hubs are 4 degrees, made from the less brittle plastic, but are very beefy, lots of extra material on them compared with the TA05IFS/417 C hubs. And Once fitted, I had one modded evo4 hub on one side and one stock 417/TA05IFS hub on the other, I dare say the evo 4 hub has less flex, due to the more rigid/beefy design. another good thing, No stuffing around fitting that spacer in between the knuckle and the flange while fitting the top king pin screw, and they are cheap!
I think I'd rather use them than alloy
#940
The first pic is a modded evo4 hub, left(in the pic), the middle is a stock evo4 hub and the right(in the pic) hub is a stock 417 hub.
The second pic is, top(furthest away) is modded evo4, middle is stock evo4 and closest(bottom) is a stock 417 hub.
the third pic is a stock 417 on the left, modded evo4 on the right.
The fourth pic is the modded Evo 4 hub on my 417.
The thickness of the top section of a stock evo4 hub is 3.95mm, to make the knuckle fit, with flanges (no spacer) you need to take it down to 3.25mm. so 0.7mm. To allow space for the 0.7mm spacer as per kit, you'd have to take out more, but I have fitted that spacer onto the top kingpin screw, to clear the CVD and I'm pretty sure it gives factory height/roll centre.
I know most people prob dont want to stuff around modding stuff. But for those who do, its easy, maybe 5 mins per hub. evo4 hubs are like $3.50 and with alloy knuckles, should be pretty strong. I also fitted some .2mm spacers between the hub on the outer suspension pins, between the c hub and the arms. just reduced some play, yet no binding.
Cheers, Jack
Cheers, Jack
#941
Arrowmax released option parts for TRF416/417 ...
#942
Cheers, Jack
Cheers, Jack
What about the "nose" at the steering knuckle when you go to maximum steering angle. does it match the C-Hub the same way as it matches the original? I other words do you gain the same steering?
Greetings Rainer
#943
Have you screwed the steering knucle also EvoIV style? or the original style?
Greetings Rainer
Greetings Rainer
regarding the screws, it the same as the 417, except for the 0.7mm spacer, which now goes on the top kingpin screw rather than on top of the knuckle, between the flange.
hope this helps
#944
Spur and pinion
Does anyone know the min and max number of teeth you can run on the 417 (ie spur + pinion)? I think the minimum may be 103, also does anyone know the largest spur you can fit on the car, all these questions are 48dp specific
