Tamiya TRF417
#1083
Hello all
Would anyone advise what kind of settings can provide more on-power steering? My car is experiencing on-power push but off-power steering is very good.
Thanks.
Thanks.
#1085
The Evicerator
#1091
Any feed back on the new ball diff ? how many run before rebuild it ?
is the diff protection ok now ?
My 416 diff ball was going crappy quickly
#1092
My diff is still butter smooth after 4 race meets and 20 packs of practice. I took some extra time sanding both sides of the diff rings. Used stealth grease on the balls (stock) and the Tamiya anti-wear on the thrust. All I can think is the smooth surface and micro scratches allows you to run the diff loose but not slip. Btw, I run 17.5.
#1093
R/C Tech Elite Member
I was able to run 416 diffs in mod for at least 4-6 racedays before rebuilding. Just like Electro said, taking a little extra time building the diff will make it last a lot longer. I would recommend the Tamiya 3mm ceramic balls, they should last through a few diff rebuilds without needing replacing and are smoother than the stock steel balls. The Tamiya 3mm carbide balls will generally build a smoother diff, but will need to be replaced with each rebuild.
#1095
