Like Tree4Likes
Tamiya TRF417
Old 04-13-2011, 08:57 PM
  #1231
TryHard's Avatar
Originally Posted by BCDK
Hi.
It is easy to see the difference between the springs as they have different turns. Smooth springs have many turns and hard springs have lees turns. I have made a list with the HPI and Tamiya springs. I have alse added block settings and gearing. See attachment.
It is in Danish, but "Omdrejninger" means turns. Use it if you want.
wonder where the block settings came from... http://www.thard.co.uk/viewforum.php?f=49
No biggie
TryHard is offline
Old 04-13-2011, 08:59 PM
  #1232
TryHard's Avatar
Originally Posted by Qatmix
There were some pics of Mark and co's car with a White gear diff so I assume they were testing it a TITC
Asked Kio, and he said, similar performance, but no leak...
Syn, I think the puppy is safe!
TryHard is offline
Old 04-13-2011, 09:05 PM
  #1233
syndr0me's Avatar
Trader Rating: 32 (100%+)
Haha, man, I love my dogs, they would have been safe no matter what. But that's good news about the diff, I'm OVER these spec-r pieces of *ish.
syndr0me is offline
Old 04-14-2011, 09:02 AM
  #1234
Tron's Avatar
Trader Rating: 17 (100%+)
Thank goodness, I am running that POS Spec-R and am tempted to mod up an NT1.
Tron is offline
Old 04-15-2011, 02:45 AM
  #1235
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
If you spend a little time with some fine sandpaper and use AE green slime on O rings. The spec-r diff works good with no leaks.
Jamison R is offline
Old 04-15-2011, 04:59 AM
  #1236
kentech's Avatar
Posted some info on the Gear Diff Unit II and the other new TRF Series relases yesterday:
http://kentech.blogs.se/
kentech is offline
Old 04-15-2011, 06:11 PM
  #1237
2-Bad's Avatar
Trader Rating: 24 (100%+)
The HPI Blue springs will be hard to find nowdays... I made a request from Japan and they said;
"1 x Hot Bodies Blue Shock Spring (1 pair) - Part # 6542 has
been out of stock in the maker and the back in stock dose not
fix yet either"
@ kentech,
Do you have any pic's of the new diff?
2-Bad is offline
Old 04-15-2011, 10:36 PM
  #1238
Smile
We have the blue springs, it's the silvers that are tricky to find
stitchy is offline
Old 04-16-2011, 01:55 AM
  #1239
the new geardiff can be put on a 416 x ?
Manson is offline
Old 04-16-2011, 02:31 AM
  #1240
chrisk's Avatar
can somebody help me out with part numbers for the blue alloy screws 3x6 and 3x8 please
i ordered some but they have a flange on them
i got 84107 and 84108
what number are they without the flange????
thanks if anybody can help
chrisk is offline
Old 04-16-2011, 02:56 AM
  #1241
entitymugenmtx's Avatar
Trader Rating: 85 (100%+)
3x6 53771 3x8 53772
entitymugenmtx is offline
Old 04-16-2011, 04:17 AM
  #1242
chrisk's Avatar
thanks but i am after the button head, not countersunk.
i want them for the top deck
chrisk is offline
Old 04-16-2011, 08:40 AM
  #1243
http://cgi.ebay.com/Tamiya-3-x-6mm-R...item20b89502f0
http://cgi.ebay.com/Tamiya-3-x-8mm-R...item20b822b69a
Old 04-16-2011, 09:30 AM
  #1244
you cannot get them tight enough i found , then if you do they round off whan you want to get them loose
sidecarphil1 is offline
Old 04-16-2011, 09:49 AM
  #1245
Hello all,
I recently got my TRF 417 (first tamiya) and so far so good.
Been testing alot with the setup but got a few questions.
The track im running has low grip currently
1. Rear grip problem, on throttle the rear is very loose.
2. Any advice to get more steering in the car?
I've uploaded a setup sheet of my current setup.
http://www.gerwingood.nl/RC/TRF417_16-04-2011.pdf
Thanks all, if need more info just ask.
GerwinGood is offline
