Like Tree4Likes
Tamiya TRF417
Old 12-17-2011, 07:42 AM
  #2431
Craig W's Avatar
Originally Posted by RC MARKET
TRF Damper X-Ring
whats the price on these
Craig W is offline
Old 12-17-2011, 07:49 AM
  #2432
TryHard's Avatar
Originally Posted by hotdognobun
Any tips on building gear unit? just dont want any future leaks! Has anyone used anti grease instead of oil?
The Tam diff is pretty leak free, most of the issues result from stripped gears if the mesh is out, and the shims cone.
Have a look at these tips from Jilles, and also look on youtube for his video.
For the shim issue, I've just replaced the standard shims with 1x 0.3mm thick shim, and also kept the outer diameter to the same size as the pin, to stop the outer regions coning.
HiH
Ed
TryHard is offline
Old 12-17-2011, 10:30 AM
  #2433
Trader Rating: 38 (95%+)
have mine for sale
zaraz is offline
Old 12-17-2011, 11:03 AM
  #2434
RC MARKET's Avatar
http://rcmarket.com.hk/product_info....0t3s9ead7s7qq7
RC MARKET is offline
Old 12-18-2011, 07:42 AM
  #2435
while building the 417x I noticed the hole on the bottom deck battery holder in the middle, with the trf etched on it, lines up with the top deck where the belt tensioner screws in, so to make the chassis stiffer could you not run a post there and screw the top and bottom deck together in the middle as well, do you think it would be better, I am thinking less flex for carpet, any toughts on this or will not work, or cause a difference
zaraz is offline
Old 12-18-2011, 11:52 AM
  #2436
That would stiffen the chassis a bit more, although who knows what the resulting effect will be on the handling. I stiffened mine at the front with a shaft from the steering bridge. I only tried it for one session and was indifferent to the results, but I will try it again.
Qatmix is offline
Old 12-18-2011, 11:58 AM
  #2437
Blueman Austria's Avatar
Hy!
Are the new X Orings supplied in the new X kit? Anybody tried it yet? are they a direct replacement for the standard blue o-Rings?
Greetings Rainer
Blueman Austria is offline
Old 12-18-2011, 12:31 PM
  #2438
no you get the regular clear o rings, you do not get the blue ones, but they are a direct fit
zaraz is offline
Old 12-18-2011, 05:31 PM
  #2439
hotdognobun's Avatar
Trader Rating: 32 (100%+)
Default x ring
just installed 70 x rings with TRF VG 45weight oil and the movement seems slow so i guess when using thick oil use x ring 50 and 70 when using 35 or below? i will let you guys know! As for leaks well i still recvomend green slime!
hotdognobun is offline
Old 12-19-2011, 02:54 AM
  #2440
Suspended
Trader Rating: 69 (100%+)
Posted on TamiyaUSA website for the X-Ring:
These Damper X-rings have X-shaped cross-sections and offer increased oil sealing effect compared to standard O-rings with circular cross-sections. Made from special silicone material, these X-rings also maintain their shape, and therefore their sealing ability, for a longer period of time. This makes them ideal for use with Aeration Dampers such as Item 42198 Buggy HL Aeration Damper Set and Item 54028 Buggy Aeration Oil Filled Damper Set. Item 42214 is designed for use with silicone damper oil while Item 42215 is for mineral based damper oil.
http://www.tamiyausa.com/product/ite...oduct-id=42215
eComet is offline
Old 12-19-2011, 03:05 AM
  #2441
Yup, Lee Martin (TRF buggy driver) says the X-rings are only for buggy shocks.
I have never had a leaky TC TRF shock in all the years I've ran them.
Qatmix is offline
Old 12-19-2011, 03:25 AM
  #2442
Pro10noob's Avatar
Don't want to bust anyone bubble but Kyosho has them X shocks ring for a while now.
Clear sillicone and work like a charm
regards Roy
Pro10noob is offline
Old 12-19-2011, 06:04 AM
  #2443
That explains it but why is it being advertized by rcmarket here? anyways i still went ahead and i just fitted with the 50 and it feels thebsame as a regular blue o ring!
Old 12-19-2011, 03:05 PM
  #2444
regards Roy
Do you comment on the X shaped O-ring also?
HaHa
Ed
eded1 is offline
Old 12-19-2011, 03:22 PM
  #2445
Pro10noob's Avatar
Naaaaaaaaaahhhhhhh
Just saying that the X-type shock rings are nothing new
Spec-R uses them X-rings now to get the gear diff leakage free and it works
Tamiya is comming out with them for the shocks but some one else beat them to it
They do work great and hold there own longer then the normal O-rings from what i have noticed.
Now we have to wait till they bring them out for there own gear diff.
Mine VII diff isn't leaking but hey, they need to work on something new 2 get something great even better
regards Roy
