Team Associated TC6 Thread >
Like Tree20Likes
Old 10-13-2012, 03:34 PM
  #7636
Default Tow in problem
Hi guys sorry to boder you but i am stuck. I need a 3 tow in on the rear but i cannot find the correct plastic. Is there a way i can measure them to get the result as they seem all the same for me.... Thanks in advance
Teamcastagna is offline
Old 10-13-2012, 05:24 PM
  #7637
tmaxx26power's Avatar
Trader Rating: 39 (100%+)
Measure the thickness of the shims with a caliper.
tmaxx26power is offline
Old 10-13-2012, 08:35 PM
  #7638
bozzplayer's Avatar
Trader Rating: 17 (100%+)
Hi guys, I'm am new to associated tc, coming from racing tamiya and Xray tc, I've opt to try something new, so i ordered the new tc6.1wc and was hoping for any tips on the build and anything anyone can recommend for the car, i race on indoor 70'x50' Carpet Track with Heated Floor
bozzplayer is offline
Old 10-14-2012, 02:27 AM
  #7639
wtcc's Avatar
No real need for tuning parts or build tips. Maybe get four M3x3 grubscrews to reduce slop in the hubs and the ReflexRacing shock bladders for an easier/better shock build and zero rebound adjustment.
For the setup start with the Keven Herbert carpet setup as starting point.
wtcc is offline
Old 10-14-2012, 03:39 AM
  #7640
With wtcc. I really like the Shock bladders from RSD, makes your shocks smooth.
Just be sure that the suspension (without the shocks on the car) is moving freely. But I guess that's also what you did on your previous cars.
dennisV is offline
Old 10-14-2012, 04:29 AM
  #7641
bertottius's Avatar
Trader Rating: 28 (100%+)
I use the IRS TC shocks on my tc6 and they're awesome. The stock shocks are OK too. Just make sure the suspension arms are free and don't bind.
bertottius is offline
Old 10-14-2012, 09:05 AM
  #7642
wtcc's Avatar
I knew it! That is where Umino get his ideas from!
http://ets.redrc.net/wp-content/gall...-uminojuho.jpg
By the way: Interesting to see a Yokomo Spool in a Team Driver car.
http://ets.redrc.net/wp-content/gall...juhotc61-5.jpg
wtcc is offline
Old 10-14-2012, 10:24 AM
  #7643
Francis M.'s Avatar
Looks like team ae found something good. Keven and juho are near the top in big international races. Any one else notice juho runnind dcj for the rear?
Francis M. is offline
Old 10-14-2012, 05:44 PM
  #7644
Originally Posted by Team Grid RC
The instructions shows you how to strap the battery to chassis using strapping tape. If you strap it directly, the battery will prevent the chassis from flexing freely.
Give this try since it will allow you chassis to flex under the battery. It floats the battery slightly above the chassis.
http://www.rctech.net/forum/11071986-post29.html
Nice tip! Is this more beneficial when running on asphalt or is it good for carpet too?
jha07 is offline
Old 10-14-2012, 09:30 PM
  #7645
bozzplayer's Avatar
Thank for your recommendations guys
Old 10-14-2012, 10:38 PM
  #7646
hanzo3's Avatar
Trader Rating: 55 (100%+)
When does wc edition come out? Or is it already out?
hanzo3 is offline
Old 10-15-2012, 12:54 AM
  #7647
evochick's Avatar
my WC chassis was waiting for me in the post box when i got home from work today,
yep its narrow, i have no idea how i am going to fit my wiring, I can move the receiver back no problem, but when i move the ESC back i have no where to put the capacitor ???
suggestion anyone, ( yes i know i have to shorten all my cables so it isnt as messy, i just havnt got around to it yet)
Beth.
evochick is offline
Old 10-15-2012, 01:41 AM
  #7648
Beth.
my first one would be to tell me where you got the chassis from ? i havent been able to find one yet 8)
ed
Edwin Pibal is offline
  #7649
i tried this setup on carpet last weekend with good results, low/med grip carpet
http://www.petitrc.com/reglages/asso...nt20111113.pdf
changes from that is 6 droop in the front, 5 rear, 4deg caster, mazda speed6 body, flipped topdeck
Bappe is offline
Old 10-15-2012, 01:46 AM
  #7650
Losiho's Avatar
Beth.
Beth -
Suggestion - possibly mount the receiver on top of the servo and rotate the HW ESC 90 degrees from how you have it positioned currently on your old chassis.
(This is the reason why I'm hesitant to change chassis. Why do manufacturers make big a$$ ESCs these days, with equally big power caps ? My favourite ESC was the LRP QC3 - small, efficient, no cap, mounts anywhere)
Hint for Associated - we would have more room for electronics with a forward mounted steering servo.....
Losiho is offline
