Team Associated TC6 Thread
#7786
TC6.1 quality??
Hey guys,
I'm trying to decide between an Xray T4 & TC6.1 wc.
I’ve' previously raced the original TC6 and although I was very happy with its performance, I wasn't overly satisfied with the quality for various reasons.
So my question for those who had the first tc6 kits is weather associated has improved their fit/finish and quality of their plastics/carbon/aluminium etc.??
Maybe it was because I picked up the first batch of tc6's but mine came with a bent chassis, bulk heads without threads and missing screws. I'm pretty sure these issues were isolated to the first batch but I just need some reassurance here.
Cheers..
Cheers..
#7788
Does the tc6.1 ft kit come with wheels?
#7789
Hey guys,
Cheers..
Cheers..
The TC6.1 does not come with any wheels.
Jason Hunt
#7790
New TC6.1 ft purchased
Just bought a TC6.1 ft. Could pass on the sale price. Just a few questions. Placing a order for a few needed items.
1. What is a good body?
2. What is a good lower priced esc, maybe something like HW? What spec esc is needed for touring
3. What pinions are needed for 17.5 racing?
4. Anything I need to order to start with?
I will be running a Revtech 17.5 and savox servo.
I have raced off road 2 & 4wd sct for a few years with my decked out Kyosho and SCTE. Not trying to cheap out on my esc, just want to make sure I like before sinking a ton in electronics. Thought I would give touring a try.
#7791
Trader Rating: 102 (100%+)
2. Try a Hobbywing Juststock or Extreme Stock, very good for the price.
3. pinions - depend on spur gear which you will have to change when building the kit. try anything from 90 to 100 tooth spur then go from there on pinioin. Gearchart.com is your friend.
4. order spurs, maybe a few spare, shims, Chubs, steering knuckles, and arms..
car is pretty solid doesnt break much.
#7792
There were some mistakes with the Hebert IIC setup sheets I posted earlier. They have now been revised in the original post and are listed below.
Keven Hebert - IIC - Super Stock 13.5
Keven Hebert - IIC - Modified
#7794
Hey guys,
Cheers..
Cheers..
#7795
Hey guys,
Cheers..
Cheers..
Is the quality and fit/finish better than that of the Xray? I don't believe it is, but I have owned about a half dozen Xray touring cars over the years and none of them handle like the TC6.1.
When I put my TC6.1 down on the track for the first time this year after a long off road season and a two year absence from on road, I could easily say within 2 laps that it was the best touring car I have ever driven. When I first ran a T3'11 a couple of years ago, it was awful out of the box and even after a number of changes it never really did get to the level I wanted it to.
My only two complaints about the TC6.1:
1) The hex of the flat head screws are a little small making the 2mm hex wrench a tight fit (aftermarket screws are cheap).
2) The turnbuckle eyelets are fairly tight when installed even with some plier squeezing efforts (they do loosen up with time).
My unbiased opinion? Buy the TC6.1, you will not be disappointed. I cannot guarantee the same for the T4.
-Kane
#7796
1. What is a good body? According to online posted setup sheets the Mazda 6 LW and the LTC-R LW are the most popular. I started with the regular weight versions for durability but am now moving to the light weight.
2. What is a good lower priced esc, maybe something like HW? What spec esc is needed for touring Cant say for sure as I've only used one brand. The LRP SXX Stock Spec ESC. I've liked it alot.
3. What pinions are needed for 17.5 racing? If you stay with the stock 48P 87t spur gear then the largest pinion you can fit (according to the gear chart in the manual) will be a 28t for a fdr of 6.21. I think that is way to high for 17.5 and like something in the 4-4.5fdr range for smaller tracks. Use the gear chart for non-timing stock brushless in the manual to decide what spur and pinion to use in 48p. Myself I currently use a 64p 96t spur with a 46t pinion for a fdr of 4.17.
4. Anything I need to order to start with? Tires, I just tried some Sorex 28r and really like them. Also consider what setup you are going to start with and order the oils, springs, and any other parts you need to complete the build. But the stock car and setup do work really well.
#7797
1. try a LTC-R or Mazdaspeed 6
I will be parking lot racing and a small concrete track. What spurs or fdr should I try to achieve?
#7798
#7800
I like the idea of using the 48p pinions, as I have a set from 15-28. But I will buy what is needed.
