Team Associated TC6 Thread >
Like Tree20Likes
Old 03-09-2012, 06:28 AM
  #6136
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default actual part number?
Hey guys what is the actual part number for the spool/diff upgrades from Team Associated? Or are there aftermarket ones that are comparable?
Daryl
BlackStarRacing is offline
Old 03-09-2012, 06:35 AM
  #6137
evochick's Avatar
Front Spool is 31339
gear diff is 31344
the rear gear diff kit comes with the outdrives so you dont have to buy them seperatly,
Beth.
evochick is offline
Old 03-09-2012, 07:02 AM
  #6138
Default Thank you Beth!!!
gear diff is 31344
Beth.
Thank you also for the added tip! lol i would have both them! lol
Daryl
Old 03-09-2012, 07:47 AM
  #6139
Rodrigo360's Avatar
Thumbs up
Originally Posted by f1o7x9
thanks for the update on spring rates. Can I use the tamiya springs on the Tc6
I'm using Red Tamiya's on rear end.
Rodrigo360 is offline
Old 03-09-2012, 09:31 AM
  #6140
Rick Hohwart's Avatar
TC6.1 spares should now be in stock except for caster clocks (yes..i need them too ) which should be in early next week.
Rick Hohwart is offline
Old 03-09-2012, 06:25 PM
  #6141
[Important] spares support for the 6.1 is awful. Releasing a car when castor blocks aren't in spares baggies is a crime. Knuckles, rear hubs... Where the heck are they?
very disappointing and a big fail.
MarcusKeeler is offline
Old 03-10-2012, 12:21 AM
  #6142
Well its better that The parts is slightly delayed, and The problems are fixed when released.
The sloop in The hubs out of The box is awful!
Bappe is offline
Old 03-10-2012, 01:00 AM
  #6143
Trader Rating: 38 (100%+)
Is that indeed the case?
or8ital is offline
Old 03-10-2012, 07:17 AM
  #6144
Finally getting my TC6 out to the track today! Last time out a few guys helped me out with getting it setup, but since i was late getting there i didn't get to race. Looking forward to having a good time.
jonu is offline
Old 03-10-2012, 09:41 AM
  #6145
Tried tamiya springs today, medium grip carpet, sorex 28 tires and 17.5 boosted
tamiya red rear and blue front worked really well, car feels very planted and carries alot of cornerspeed, and is a little less aggressive than with associated springs (green back, silver front)
also tried yokomo springs, blue rear and pink front, they require a total different driving style compared to eg assoc. springs, didnt work for me at all
how does rsd springs compare? are they as progressive as yokomo springs? very tempted do buy them and try, but if they are like yokomo i`ll pass
Bappe is offline
Old 03-10-2012, 11:46 AM
  #6146
nmdesertracer's Avatar
Trader Rating: 59 (100%+)
I had to shim my front c-hubs to get the slop out. Not to good for a brand new kit.
nmdesertracer is offline
Old 03-10-2012, 12:35 PM
  #6147
I hope so since they seems to be delayed for so long time!
But The sloop can be removed by shim The hubs and drill a 2.5 hole in The hubs and secure them with a set screw so not a big problem!
Bappe is offline
Old 03-10-2012, 05:13 PM
  #6148
geeunit1014's Avatar
Trader Rating: 14 (100%+)
RSD springs are not as progressive as Yokomo. I have been running RSD 15.5 front, AE silver rear on carpet for both 17.5 blinky and mod. Gives a very easy to drive car that carries speed well
geeunit1014 is offline
Old 03-10-2012, 05:24 PM
  #6149
cwoods34's Avatar
Typically, more coils means a less progressive (more linear) feel. As the spring is compressed, the distance between coils decreases at a lesser rate compared to a spring with very few coils.
I also like AE silver on the rear for some layouts, with 16.5 or 15.5 fronts! Feels a bit better coming out of the turns . When we run more open or flowing layouts I like 15.5 front/13.5 rear!
cwoods34 is offline
Old 03-10-2012, 06:00 PM
  #6150
If im not mistaken, its the other way around, more coils is more progressive. A "real" progressive spring is wound with many coils top and/or bottom (the soft initial part), and less coils in the middle (the stiff part).
