Team Associated TC6 Thread
#6167
#6168
99% of the time you will want to leave these in the standard position. When i lowered these i found that the overall grip was improved because youre lowering the diffs them selfs and you are making the dog bones sit at a different angle. Also as you lower these the car will become more twitchy.
This is what i noticed other people may want to step in and correct me if im wrong.
Jason
Jason
#6169
TC6.1 Factory Team Kits
We at ACER Racing are now selling TC6.1 Factory Team Kits for only $359.99, and we also have a full line of ceramic bearings also available for sale. Check them out!
#6170
I tested for a few races the b cam, however not with diff, it was with spool at front, and ball diff rear, feels good, but not too much, so much better the A cam, even if you´re a loose belt setting....
#6171
Can I use the caster blocks from my old tc6 on my Tc6.1
#6174
So basically I need to throw the B CAM away. Because it secession no purpose. Man that's so hard to believe .
#6175
Absolutely not, i´m not saying that the b cam doesn´t work!. To me is hard to believe that you ask about things that you can test in base on your track conditions.......
#6176
#6177
We cool bro, You are right I do need to test it out I was just looking for the general answer so I know what I need to expect when I first test it out. I'm still new to touring cars and amazed at how even the smallest adjustment makes such a big difference. I noticed that none of the curent setup sheets for the team drivers never use it and i just wanted to know why.
#6178
On tighter asphalt tracks, Ive found the RSD 15.5 front and AE Silver rear make a very nice combo. They seem to compliment each other very well and result in a car that is well balanced, but doesn't sacrifice response and initial turn-in for mid-corner steering.
#6180
I would assume they are fixing the molding issue that resulted in air pockets in every c hub I have seen that broke. After I went through 4 in one day from brushing boards I put the old 6 c's and haven't broke one yet.
