Team Associated TC6 Thread >
Like Tree20Likes
Old 03-02-2012, 12:50 PM
  #6016
i went with both the set screw and glue in the hole, the suspension feels way better now! cant wait to try out the car again, i really liked it!
regaqrding spares i havent found any store that has any 6.1 parts in stock, is everyone upgrading their old car or has associated turned really bad with producing enough spares?
Bappe is offline
Old 03-02-2012, 12:52 PM
  #6017
Try making a shim/washer out of scrap body lexan.
red7fifty is offline
Old 03-02-2012, 02:47 PM
  #6018
Big Features's Avatar
Believe AE is working out the injection molding kinks with TT. They will not release spares that are just as faulty.
Mike
Big Features is offline
Old 03-02-2012, 02:50 PM
  #6019
sounds good!
will old tc6 c hub and steering hub fit on the 6.1? still want some spares in my box if i crash, rarely break stuff, but still good to have some spares in the box!
Bappe is offline
Old 03-02-2012, 02:52 PM
  #6020
Originally Posted by Bappe
sounds good!
Yes, the "C" hubs will fit. If you use the old steering knuckles, you'll need to use the old bearings, crush tubes, and axles.
Mike
Old 03-02-2012, 02:53 PM
  #6021
The Evicerator
Originally Posted by masterhit
I used Hotbodies thin PN 72044. It gives you a few more options for shimming at the hex that way. IIRC a 1mm shim puts you at stock hex width.
It is close at the C-hub but I did not have to grind once shimmed under the hex pin.
I spent last practice abusing them with a boosted 5.5 on carpet and no issues.
Mike Slaughter
Thanks for the info!
Steve Weiss is offline
  #6022
thanks for the fast reply!
"old" c hubs ordered
Bappe is offline
Old 03-03-2012, 11:03 AM
  #6023
I used to drive the Xray T32011. now going to TC6.1. so I have allot of Spare parts of the T32011
Will the Zeppin Racing spur gears (for xray )work on the TC6.1?
hycinth is offline
Old 03-03-2012, 02:25 PM
  #6024
Trader Rating: 38 (100%+)
I went to setup my 6.1 today for the first time and I am having trouble getting 5mm ride height in the front. With the reflex racing springs I can only get 5.8mm. I switched back to the ASC springs and can get 4.7 (which gives me very little room for adjusting for tweak). Is this normal?
Things I have checked so far:
- Backed the droop screws all the way out
- Shock upper collar all the way up
- Length of the shock is as short as I can make it
- Spring collar all the way down
Running the stock kit settings.
or8ital is offline
Old 03-03-2012, 02:46 PM
  #6025
What tires? The shocks are long for sure, but even with Tamiya shocks which are 1-2mm longer in the cap, I can still get down to 5mm on kit springs with Sweep qts32. With VTA tires I could see an issue. I haven't mounted the RSD springs yet.
-Mike
grippgoat is offline
Old 03-03-2012, 02:51 PM
  #6026
-Mike
Solaris tires. Talked to a buddy and he said he can get to zero right height so I must have something not right. Hmmmmm
or8ital is offline
Old 03-03-2012, 03:20 PM
  #6027
Trader Rating: 14 (100%+)
Make sure you have the correct spring retainers.
Joe Maxey is offline
  #6028
Hello, when building my 6.1 last week I noticed 2 issues, and was curious too see if anyone else has seen this. 1. The shock collars have not resistance at all. Yes I put the o-ring in. 2. The front belt does not mesh well with the spool or diff in front. Doesn't matter how tight or loose I set the belt. You can spin the tires on a stand slowly and watch the belt skip on the spool. Thanks
discodom is offline
Old 03-03-2012, 03:39 PM
  #6029
Does the kit come with more than one type?
or8ital is offline
Old 03-03-2012, 03:45 PM
  #6030
It comes with one type.
Just add 2mm washer on shock shaft.
Just bettwen spring retainer and ballcup.
M.Abramowicz is offline
