Hot Bodies TCX
Old 10-09-2011, 08:48 PM
  #3751
Velocitygt's Avatar
Check the link
Velocitygt is offline
Old 10-10-2011, 08:11 AM
  #3752
Jonnydb's Avatar
Hi, guys where can i find the capricorn gear diff ?
thanks!
Jonnydb is offline
Old 10-10-2011, 12:54 PM
  #3753
AGNO's Avatar
Tested the Smokem chassis , very good, very fast car and very easy control under all conditions, tested also some optionals parts Jet Racing, really really excellent construction, recommended .
Hot Bodies TCX-foto0180.jpg Hot Bodies TCX-foto0182.jpg Hot Bodies TCX-foto0183.jpg
AGNO is offline
Old 10-10-2011, 12:59 PM
  #3754
jag88's Avatar
Attachment 818826 Attachment 818827 Attachment 818828
Where did you get the Jet parts ?
Have you tried the Smokem chassis on carpet ?
Thanks.
jag88 is offline
Old 10-10-2011, 01:10 PM
  #3755
AGNO's Avatar
Thanks.
Here http://www.jethobby.com/index.html contact by email.
Still on the carpet I have not tested, but works well on asphalt with low and high adherence.
AGNO is offline
Old 10-10-2011, 01:49 PM
  #3756
k_bojar's Avatar
Trader Rating: 30 (100%+)
I'm really curious about the split/detatched FR suspension pin holders...how exactly to they attached to the chassis? do you need to drill new holes? or do they fit in the existing whole in the chassis (2 holes for the standard FR bridge, and 2 holes for the FF 'mod' bridge)
k_bojar is offline
Old 10-10-2011, 01:56 PM
  #3757
k_bojar's Avatar
what Jet parts do you have on your car?? WHen I went to the link, the only TCX parts were HPI-brand optional parts - nothing from Jet
what am i missing??
k_bojar is offline
Old 10-10-2011, 03:08 PM
  #3758
AGNO's Avatar
Fix in the existing hole for FR or RF pivot, not possible mounting in FF or RF position.
AGNO is offline
Old 10-10-2011, 03:13 PM
  #3759
AGNO's Avatar
[QUOTE=k_ TCX parts were HPI-brand optional parts - nothing from Jet
what am i missing?? [/QUOTE]
Click on the yellow logo Jet racing at the top left
AGNO is offline
Old 10-10-2011, 05:51 PM
  #3760
eceer's Avatar
Default Jet Hobbys
here is a direct link to the tcx parts http://jethobby.com/_Jet%20Racing/CY...X%20Parts.html as Agno mentioned purchasing is made via email. I found it a painless process.
I got my order yesterday with a few sweet looking goodies. Looking forward to trying them out on the weekend
eceer is offline
Old 10-11-2011, 05:52 AM
  #3761
k_bojar's Avatar
Cool...Yeah, i meant the FR and RF positions...
What I meant about the FR, was using the mod that allowed the FF block to be used in the FR position
Sweet, I'll have to see about getting a few of those parts
k_bojar is offline
Old 10-11-2011, 05:53 AM
  #3762
k_bojar's Avatar
thanks! I figured I missed something on that page
k_bojar is offline
Old 10-11-2011, 06:08 AM
  #3763
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Will the new split suspension block for fr and rf fit on the older cyclone?
Hard to tell from the photo if it uses same mounting position.
Jamie
J.Gonzalez is offline
Old 10-11-2011, 08:27 AM
  #3764
k_bojar's Avatar
Jamie
i believe it would depend if your chassis has the extra holes drilled in for the 'mod' that allows you to use the FF/RR blocks on the FR/RF positions...the exotek chassis i have on my TC could use them, but that's because it has the extra holes already drilled in (i tried circling the holes in yellow)
If not, you'd have to drill holes in the chassis to use them
Attached Thumbnails Hot Bodies TCX-exotektcchassis.jpg   Hot Bodies TCX-exotektcchassis2.jpg
k_bojar is offline
Old 10-12-2011, 09:52 AM
  #3765
yumlailai's Avatar
If someone has Hara's IIC 17.5 setup, will you be able to share?
thank you
yumlailai is offline
