Hot Bodies TCX
#3781
#3782
Hi AGNO,
Nicely prepared car. Good job.
I also have the smokem chassis but have not managed to test it yet.
I chose to install the original HB narrow chassis first to use as a bench mark.
Stock wide chassis was pretty good to be fair.
This is my latest installation:
few more photos & info here:
JD RACING BLOG
JD RACING BLOG
#3783
new hubs
Hi,
Ive been using the new front and rear hubs for a while now!! Ive just checked my rear toe and its 3 degrees on the left and 2.5 degrees on the right. I thought they had solved this problem with the new ones..... has anyone else found this????
#3784
I'm using, and I checked the toe, 3 degrees left and right perfect
#3785
Im looking for a purple Screw set, any idea?
#3786
#3788
mine measure 2.5 degress with a 3 degree rear block. I guess I should be happy that they're both the same !
#3789
Trader Rating: 102 (100%+)
lipo chassis
who has the lipo chassis in stock? in the U.S.
thanks
thanks
#3790
#3791
Hi guys, what's about your experience with 0° FF block intead of 2,5° on carpet racing?
I wanna know drivers' feelings about that.
#3793
Thanks Art!
Ran the car with std blocks, i felt it little aggressive. With 0 is totally different, it seems she wanna go to sleep.
Gonna try +1 FR block with std FF block and see what happens but i will try 1.5 in std FR block.
Thank you!
Other drivers?
Thank you!
Other drivers?
#3795
FF 1.5 + std FR block is a good compromise on asphalt and moquette.
Sometimes I had to put FF 1.5 + FR 1.5 on moquette (to get a car less aggressive) and sometimes on asphalt I put FF 2.0 + std FR to have a car more aggressive.
In very tight track (moquette) I used Hara set up with FF 2.0 + std FR , the car is aggressive but it's necessary to get fast speed corner.
Hope this will help.
Ciao!
Ciao!
