Hot Bodies TCX
#3766
#3767
Zero rebound
Hi,
I race on very high grip carpet and it was recommended to me to try zero rebound!! To do this i will have to drill a hole in the shock cap but i was wondering what affect this would have on the car, will it reduce the cars overall traction?
#3768
narrow chassis installed
Tested the Smokem chassis , very good, very fast car and very easy control under all conditions, tested also some optionals parts Jet Racing, really really excellent construction, recommended .
Attachment 818826 Attachment 818827 Attachment 818828
Nicely prepared car. Good job.
I also have the smokem chassis but have not managed to test it yet.
I chose to install the original HB narrow chassis first to use as a bench mark.
Stock wide chassis was pretty good to be fair.
This is my latest installation:
few more photos & info here:
JD RACING BLOG
#3769
here you go...
#3770
Do you happen to know what diffs he ran front and rear ?
Thanks.
Thanks.
#3771
Hi AGNO,
JD RACING BLOG
JD RACING BLOG
#3773
IIC winning setup
hello all
I read the winning setup setup of hara (IIC).
"..Prototype longer steering crank used.." what it means?
He used new steering blocks 3 holes without shims?
Strangely he did not use the solution FR to enlarge the supports of the arms,
always been used by HB champions when they run on carpet
Please somebody have any photos of the car?
#3774
#3775
#3776
hello all
For the FR block, he had +0.5 on his stock car.
Thanks,
#3777
gear diff in front
Hi,
Has anyone had trouble with the driveshaft blades breaking easily when you use a gear diff in the front?? If so are there any solutions to this??
#3778
#3779
http://www.spec-r.com/default/index....roducts_id=241
#3780
Spec-R blades, very low price and very durable.
