Hot Bodies TCX
#3017
Why do people use Xray blocks, Tamiya blocks, xyz blocks, etc? I mean, why don't you just buy the actual Hot Bodies blocks? I know the stock ones are brittle, but then why not just buy the Hot Bodies aluminum ones? It never made sense to me why people would go with another companies parts and "try to make it fit" when the OEM manufacturer has alternatives (to the brittle ones) which would be a DIRECT fit? I guess I just don't want to "bastardize" my Hot Bodies car with parts meant for other cars (aftermarket parts not included). It's almost like those people who put BMW badges on their Hondas...
#3018
#3020
Trader Rating: 102 (100%+)
just light humor
but seriously I went thru at least 10 steering knuckles and 8 Chubs before changing the parts. Now I haven't broken one part in the past 3 months.
not fun when I wait all week to race then not finish one qual.
#3021
I put the aluminum steering knuckles (C-hubs) and have no problem
#3022
I could be wrong, but i definitely need more testing.
#3023
Guys,
Im using 44mm CVD's on my TCX, with front Spec-R gear diff without any problem.
I use 500.000 up front, but i would like to try out solid front.
I have a spare gear diff and i dont have access right now to 46mm CVD's of any brand so ... any tip in how to block the front diff to make it solid ?. I was thinking on using some of my doughter silicone glue from school inside diff lol ... would work ?
thanks,
thanks,
#3024
because alum bends and can break other parts connected to it, like a pricey bellcrank. Xray blocks are stronger, but will still act like a fuse. Every car has at least one weak link point, no reason no to cross use parts that fit and either improve performance or reliability.
I hear you on this one... I can't begin to tell you how many knuckles/hubs I've broken... But the Al has worked great.
#3025
The main reason for tamiya or xray knuckles is they let the ackerman change to be a bit more desirable. Aside from the fact that we should not hit stuff it is particularly easy to brake that the plastic used for HB hubs, and most other brands are stronger. I also do not run hb arms on my car, but then again the only hb things i have are the awesome shocks and bulkheads / layshaft / steering rack, the rest is a bit of a mish mosh.
#3027
Be careful with using of tamiya knuckles. The overall front track width is going to be changed and the scrub radius is also changed.
Thanks.
Thanks.
#3028
Yessir, xray ones are where it's at.
#3029
