Hot Bodies TCX
#2252
Parts needed
Can anyone help me out? Do you know who carries the following? Seems OOS at a few of the places I shop at.
1.0 mm spacers/washers
1.5 and 1.0 pivot blocks
part 73507 - steering knuckles
part 73513 - body post
Not a need but a want as well is the top deck screws in purple M3x5mm
Thanks.
Thanks.
#2253
I'm looking for some setup help for my TCX on a medium to high grip tight indoor carpet track running boosted 13.5. The main problem is a hesitation in turning in; the car seems particularly prone to washing out in the the chicane at the end of the straight. I use kit setup, except the front shocks are in one hole in the tower, the front springs are HPI pinks and I'm using 3 hole 1.1 mm pistons and 45 Wt Associated oil all round. The tyres are Sorex XG-28JB carpet rubber tyres. During a race meeting I tend to reduce the front droop very slightly and increase the rear droop by an equal amount, but the problem remains. I'm going to try going from a Mazdaspeed 6 to an LTC-R in the hope of getting more turn in, but I'm sure that the bodyshell can't be my only problem (+ a Mazdaspeed 6 should work pretty much anywhere), so I'd be happy to hear any advice. In particular I'd be interested to hear about the front toe-block - the standard kit supplied part is 2.5 degrees but I've seen lots of carpet setups using a 1.5 degree front block. Would switching to a 1.5 degree front block help turn in?
Thanks in advance
Alexander
Thanks in advance
Alexander
#2254
TITC 2011
Congrats Andy at TITC 2011!
#2255
Thanks in advance
Alexander
Thanks in advance
Alexander
Just a suggestion.
Steven
#2256
Thanks - so move the front inner camber link to the outer hole (number 1 on the setup sheet) and keep the rears in hole number 2? Also is that still with 2 mm shims under the inner ballstuds?
#2257
Yeah i run 2mm all round, my car never lacks steering anywhere, if anything i suffer from a little oversteer from time to time, but minor changes elesewhere help.
#2259
The new king of TITC!
Congratulations Andy
#2261
#2262
Use the drive shafts HPI 88914 PRO-D,are steel, indestructible,are used without modification.
#2263
Trader Rating: 102 (100%+)
Go a few pages back and there is a lot of options to resolve the problem. Do a search for bones, Cvd, Yokomo
#2264
#2265
Could somebody could ensure if have someone from Japan which bring a Kawada SV-10 to race in 13.5 class, please?
Best regards
Best regards
