Like Tree2991Likes
1/12 forum
Old 01-21-2011 | 08:45 PM
  #35341
Daniel W's Avatar
Hey I`m currently using the LRP SXX TC SPEC V1 in my Associated 12R5.1
When I was using IB 5000mah 4.8v nimh batteries(cells)I had know trouble but since moving to LIPO 3.7v. I`ve had to add a 6.6volt LIFE reciever battery pack 200mah or the speedo would just shut down due to low voltage over a 8 minute run Mod it uses around 50mah from fully charged.
And when using a LIFE theres no need to use any voltage regulators
Hope this helps
Cheers Daniel
Daniel W is offline
Old 01-21-2011 | 11:37 PM
  #35342
Originally Posted by t4m1y4niac
i'm new in 12th scale, planning to use LRP SXX TC Spec speedo..should i use extra battery for receiver?
can give me info what brand and type the battery is?
thanks.
All the LRP speedos have a 6v output as standard so no need for a reciever pack
sidecarphil1 is offline
Old 01-22-2011 | 02:57 AM
  #35343
t4m1y4niac's Avatar
thank youuu
t4m1y4niac is offline
Old 01-22-2011 | 07:23 AM
  #35344
BCbud's Avatar
I do not use LRP but do all of them have a 6v BEC with a 1 cell, 3.7v input? That would mean that they all have a built in voltage booster, I don't think they do but I could be wrong.
BCbud is offline
Old 01-22-2011 | 08:07 AM
  #35345
oldrcr's Avatar
Default 17.5 no timing rollout
okay, so what kind of rollout has anyone run with 17.5 no timing?
I realize that it will vary from track to track, but just trying to get a starting point.
oldrcr is offline
Old 01-22-2011 | 08:11 AM
  #35346
Yes the LRP SXX and SXX stock specs have built in boosters
TAKEN FROM LRP.COM
TwinBEC: A true BEC revolution! Constant 6V/3A output with 3.0V to 7.4V batteries. No receiver battery with 1S LiPo needed.
Old 01-22-2011 | 09:09 AM
  #35347
BCbud's Avatar
TAKEN FROM LRP.COM
I knew that 1 or 2 of the newer ones did but the statment was all of them do and the older ones do not.
BCbud is offline
Old 01-22-2011 | 09:59 AM
  #35348
The track I was running has a 30m straight, and is fairly technical. Ran the car with 82mm rollout, and 45 deg advance (on the end bell). Worked rather well.
Shawn.
Shawn68z is offline
Old 01-22-2011 | 10:28 AM
  #35349
oldrcr's Avatar
Shawn.
Thanks for the reply. We are currently running 13.5 with no timing and are running around 82.
I suppose different motors will also be different. 1s rotors too.
I did find a post where some were running over 100 for rollout. So, I guess I am still fishing for what others have found. Try to include what motor as part of the info.
oldrcr is offline
Old 01-22-2011 | 10:38 AM
  #35350
pmes's Avatar
AFAIK his point was the 6V boost didn't last him 8 minutes so he got the receiver pack.
pmes is offline
Old 01-22-2011 | 12:54 PM
  #35351
BrodieMan's Avatar
Originally Posted by chris moore
Yes if the asphalt is smooth enough it can be done very easily. Its best if you can lay down some type of sugar water or soda to help with the grip.
Thanks Chris, I want to push the classes that are reasonably inexpensive to get into at a competitive level such as RCGT. I know they are tricky to setup but I think 1/12 would be a good class for a new club, plus if we get an indoor carpet track next winter we might have an established 1/12 class.
BrodieMan is offline
Old 01-22-2011 | 04:12 PM
  #35352
Default quick question
anyone know where i can get some 1 cell rotors?
artoftatt2 is offline
Old 01-23-2011 | 03:13 AM
  #35353
Speed passion are making 1s motors so i guess they are making rotors too
Old 01-23-2011 | 04:16 AM
  #35354
Whats the difference?
Dragonfire is offline
Old 01-23-2011 | 08:40 AM
  #35355
What kind of rollout are you guys using for 17.5 open
