Schumacher Corner
its the stiff top deck (not to be confused with the 2.5 mm carpet top deck)
A quick question..I have been running the kit top deck in stock class but have broken 3 top decks..I have the flex top deck but just looking at it do not know where you would use it ( would tweak the car very easily)Is the stiff top deck the Go?
R/C Tech Elite Member
The "stiff" top deck basically feels just like the stock top deck on the track, but doesn't hold tweak as easilly. I don't run anything else for asphalt and rubber tire carpet.
Thanks Randy....another question..the car is bloody heavy..(Light bulkheads should arrive next couple of days)running brushless and Lipos do you add weight to battery side of the car?
Super Moderator
with the core rc pack shifted all the way to the side make it flush with the chassis i only had to add about 2 1/2 ounces depending on what brushless esc/motor combo you are using
Was the 2 1/2 ounces to make the car balanced or was it enough to make legal weight? I have to had close to 100 grams or 3.5 ounces to make legal weight with the core pack and brushless.
Super Moderator
I'm running brushless with NiMH packs, steel screws on 75% of the car, and stock bulkheads and I'm underweight, not sure how everyone seems to be overweight.
hold off on the dremel, I have some of the older Silver Arrows in 3x6 Part # sib-3006
Actually they're Hard nickel
and the TIR all i have is 3x6 countersunk
ive never had a problem of being under weight
very funny lol
It's a problem I've had for years now.
