Schumacher Corner
Super Moderator
R/C Tech Elite Member
cool Shawn asked if i wanated to race, so you'll see me in ultra novice, and if there isnt a class i'm making it
Super Moderator
you'll see brave next season, i'm sticking to my 13.5 novice, i'm to scared to go fast, these are to expensive lol i am trying to convince Shawn that we need to race the Birds this spring cause i've wanted to run there since i was a kid
Yes the first and so far only thing i have gotten from randy is 2 practice packs directly that he had left over. And because he was honest an said they were practice only not good enough to push on a shop i took them as they were. Lately i have started running bl and lipo. But have i been in my Lhs asking them to stock Randy's stuff your answer is yes also. please dont try to make me look like I'm wrong here. I'm stating a very good suggestion that you are foolish to disagree with i said to maybe ask to contact the LHS to promote the product
so is it the tamiya 414 pulley or the 415 pulley that i want, i have a 414 and reamed out the center, but the screw holes don't line up, do i enlarge those as well??
Super Moderator
Right, i know all the talk in this thread at the moment is on the Mi3, but i have something semi-schumacher related.
Well, i bought some schuey XVS cells not long back, built them up and i have only just got round to charging them.
Now all 3 packs got to about 500mah-ish and then cut off (using an orion advantage) so i thought weird.
Put the multimeter accross each cell and some of them weren't reading anything. Tried discharging them and charging them again and 2 packs charged up to about 3300/3400mah but the other pack (with 2 cells at considerabley less voltage than the others) just keeps cutting off saying 'check battery' (or something along those lines)
There isn't any signs of blown cells, they were bought new. I have built many packs of cells in the past so i don't think i damaged them with the iron. Any idea what it could be?
Has anyone tried the Speed Passion 13.5 Brushless motor from Schumacher yet ?
I practiced today on the 2004 worlds track and my car was super good! I will get a setup sheet sent over to Schumacher USA during the week for them to post
The major differences in the setup was using Mi2EC arms and added a 3rd hole on the steering block (middle of the stock holes).
on a serious note YES IT WAS
Put the multimeter across each cell and some of them weren't reading anything. Tried discharging them and charging them again and 2 packs charged up to about 3300/3400mah but the other pack (with 2 cells at considerably less voltage than the others) just keeps cutting off saying 'check battery' (or something along those lines)
has any one actually over driven a front heavy duty oneway? i tried the 415 one way pulley the black one and when i reemed it out it was into the screw holes and there was slop so it wouldnt spin true any idea's?
