Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 08-04-2007, 10:13 PM
  #21031
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Customworksking
Hello Randy good job with the tq and win ...I am looking at your ROAR Nats setup sheet u didn't list what track rod u used also did u use the alum rear hubs with the insert if so what 1 from the looks of it it would be 1.5deg..How do u feel this setup will work on low bite carpet 19t rubber..in the driver notes u run a 414 front drive pully can u tell me more about why..I also now see u used the med width/short steering plate i assume it is the 2nd plate but u didn't check it thanks for your help I will be running it soon and I want to know how to interpret the set-up sheets!
I used the stock rear hubs on the car. I think the steering rod is in the notes, but I used the short length medium width rod mounted 2 holes forward on the mount. Should be a descent starting setup for carpet I'd think.
Randy Caster is offline
Old 08-05-2007, 06:35 AM
  #21032
Customworksking's Avatar
Trader Rating: 74 (100%+)
Wink
thanks ...where can I get the 414 pulley ?
Customworksking is offline
Old 08-05-2007, 11:47 AM
  #21033
Wink 414
is it a tamiya 414 pulley
Old 08-05-2007, 12:48 PM
  #21034
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Yes it is. You can probably get it from SppedtechRC
Jon Kerr is offline
Old 08-05-2007, 02:56 PM
  #21035
so can i over drive my one way one my ec? its the heavy duty version?
also im racing on aphsalt so would this much steering help or hinder my car.
just sounded like something fun to play with.
cheers
aus jd 2703 is offline
Old 08-05-2007, 05:11 PM
  #21036
cheers
Im sure you can make the pulley fit. It really just depends on the track, I havent used my 1-way yet as the spool gives me plenty of steering with the overdrive..
Old 08-05-2007, 05:26 PM
  #21037
do you find with spool and over drive you eat drive shafts?
just im not a good driver yet and have destroyed a spool (old types) and about 3 driveshafts so im always worried bout driveshafts
im onlyruniing stock
cheers
Old 08-05-2007, 05:43 PM
  #21038
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
cheers
i ran the overdrive in the front today( 35t tamiya) and it was pretty good!!
Marcos.J is offline
Old 08-05-2007, 06:21 PM
  #21039
is this it?
http://www.speedtechrc.com/store/ebp...nid=246&id=442
is there a cheaper way?
also did u use a diff one way or spool?
cheers
Old 08-05-2007, 06:39 PM
  #21040
Super Moderator
Marcos.J's Avatar
is this it?
cheers
this one , i used the Mi3 spool
http://www.speedtechrc.com/store/ebp...id=268&id=1667
Marcos.J is offline
Old 08-05-2007, 07:41 PM
  #21041
thanks marcos ill chase one up for a try.
Old 08-05-2007, 08:43 PM
  #21042
JayBee's Avatar
Trader Rating: 31 (100%+)
Schumacher MI3's dominate today in three classes on our big outdoor track in preparation for the BIGGEST race up here in the Northwest- THE 2007 SUMMER SIZZLER!!
19T Sedan- Brett Sisley (Schuie wheel)
27T Sedan- Randy Taylor (Owner of High Velocity)
13.5 Brushless- Ritchie Reynolds (Schuie wheel)
I was mid-pack with a 5th place finish in the 13.5 A Main; my 19T car was good too but broke a front arm in the 3rd heat and didn't feel like fixin' it. Running 2 cars today was WAYY too much work! I don't have a snowballs' chance in hell keepin' up with 3 classes next week in the SIZZLER!
JayBee is offline
Old 08-05-2007, 08:49 PM
  #21043
corallyman's Avatar
Trader Rating: 101 (100%+)
You can do it Jaybee. Is there triple A mains? Hey you'll only be up 9 Times. Don't forget to corner 9 times as well.
Steve
corallyman is offline
Old 08-05-2007, 09:11 PM
  #21044
skypilot's Avatar
Trader Rating: 14 (100%+)
you gonna make it this year steve, we missed you last year.
skypilot is offline
Old 08-05-2007, 09:22 PM
  #21045
JayBee's Avatar
Steve
I'm not even gonna make an attempt
JayBee is offline
