Schumacher Corner
#6031
Oneway setup
Front,
Trf Shock 3 hole piston 40 wt.
Ae blue spring
Carpet tower inner upper camber position
Outer shock tower hole/ outer arm hole.
63mm shock length
1 degree camber
4 degree Block carrier.
Arm mounted in back position
Droop 5mm
Middle holes on steering rack.
Oneway diff.
Stock swaybar
5mm ride height
Rear
Carpet tower
TRF shock 3 hole piston 40 wt.
63.5 mm shock length
2nd to outer hole on tower for shock/2nd hole from out on arm fro shock.
Upper middle for camber link on tower
Farthest hole out on rear upright.
1.5 degree toe.
4.5mm droop
Middle arm mounting.
5mm ride height
Sorry guys couldnt fill out the pdf sheet.Something is wrong with the puter.Harsh could you fill one out for me?
Ae blue spring
63mm shock length
1 degree camber
Droop 5mm
Oneway diff.
Stock swaybar
5mm ride height
Rear
Carpet tower
1.5 degree toe.
4.5mm droop
5mm ride height
#6033
Man today was a good day for my Mi2.Car was very fast and although qualifying was a little rough,and the car the car was good enough to win,its was me who couldnt keep it together.Lead the A main for quite a bit and a mistake and a wrong choice in tires for the main would leave me a very close second.Oh well,I cant complain.I am actually really happy it was good.Will see how it does in Modesto tomorrow.
#6034
Originally posted by HarshGuy
Mo, your car looked good, hook us up with the setup
#6036
Originally posted by xxxkat
And still no speedworld win..
Racer X- Did any of those changes help the car out some? Rich had some killer motor in the main. See you next weekend.
#6039
Tech Legend
Trader Rating: 51 (100%+)
Has it been easy to get MI2 parts? My Pro 4 has been a total pain in the rear to get parts and I'm starting to get a little pissed about it. Next car I buy I want to get parts easily. I don't mind ordering them but it would be nice if they were in stock.
#6041
wyd- parts are out there for the car as the car gets more and more popular. If ordering isn't a problem (if your LHS doesn't stock the car) you can order directly from Schumacher. The guys there are friendly and race the car as well so if you have a set up question when you place your order they can help you out. There is also a ton of set up help on this thread. Everyone is sharing set up advice so no matter what type of track you race on....there's a good basic set up on here for you to start with.
xxxkat- It's more than past due but if I keep trying it will happen sooner or later You're still coming up for the Speedworld cup right?
#6044
Thanks Art!
The car was a pleasure to drive on Saturday,too bad it was to a second place finish when I should have handled buisness and won! Talk about choking.
Round 2 at Modesto Hobbies went well again.Didnt have the tire thing down in the first round.But in the second round I set new TQ by over a whole lap.Also set the fastest lap time in expert stock.Whose says shaft cars out accelerate belt cars!That was an intense battle between Jim Rose and I for about 4 minutes and I was still able to Tq.In the 3rd round I got taken out in the first lap which allowed Jim to set a new Tq by 3 tenths of second. Had to go home before the mains but all in all,for its first outing,the car was really good.Thanks Schumacher!
#6045
Originally posted by STLNLST
what about my car... These Quantum 2's suck. I saw four lrp's go to crap today with mine being one of them. I'm putting the keyence back in for next weekend. MI2 was rocking today. Next weekend should be great with everyone coming out.
