Xray T1
#1966
I do the outside 3/4's as the outside edge is miles stiffer than the inside edge and its the outside that provides the grip and the inside chunks to easily if you TQ it! I also have some development bits on my car our distributor had made up but we aint sure if they are gonna release them yet. Rick
#1967
Hummm, I see....
What are they in respect to the new developments? Can you give us a few ideas???
#1968
My car has a IR of 1.77 now but i dont know if Hudy or xray are aware of these parts or if the distributor has just had them made as a trial for the UK only, so noine of you go pestering your distributers or hudy for them as you will not be able to get them!.
Rick
X-ray team driver
Rick
X-ray team driver
#1969
Rick your setup looks nice. I may try the caster settings you have. I love the way my car feels, and I love hearing from the fast guys.....wow that thing is really flying out there.
also rick what did or do you think of the setup I posted??
I would agree if you are slapping the chassis go stiffer. As for traction rolling I guess that would also depend on other things also. I'm running purple springs with 60-50 wt oil and the car is on rails.
#1970
rick draper the set up you posted is it for carpet or asphalt as it is very close to what i have on my car and i'm running on carpet. as you said this car with this set up rotate through the corners very quick cheers, mike
#1971
Yup the setup is sweet, it rotates far harder than any other car i have ever driven. It is so fast through fast chicanes as well. Duration is amazing with the 1.77 IR as the belts can be ran soooooooooo loose its untrue! Rick
#1972
Thanks Jeff,
I wonder... you mentioned closing a hole in the rear shock...would opening holes in the front/lighter oil do the same thing?
#1973
Thistle, I'm not sure what you'd want to do with front shocks to help with your problem. I'm not sure they'd really effect it that much. The reason I said to close a hole in the rear shocks, is that it would increase pack (slow down rebound) and would help to hold the rear of the chassis down.
I've never had a problem with my car lifting a tire (not that I can remember!), so I don't know from experience what to do. Just keep trying stuff, and let us know what works.
#1974
If one of the back wheels was lifting on my car i would look at thefront as the problem as its probably roaling 2 much, try a stiffer spring ond go one hole in on the tower on the front, or just try one hole in to start with.
Rick
X-ray team driver.
Rick
X-ray team driver.
#1975
Rick: Those pulleys are either an Xray part or RW. I've seen a few peeps with them on now so I think they should be going in to production, will know more after the weekend.
//Stu
(fellow Xray/Centre.Point team driver)
//Stu
#1976
The new pulleys are an RW racing part.
//Stu
//Stu
#1977
So do you have them yet m8? They are amazing. Rick
#1978
what pullies, and where can we get them? lol
although i have to say my xray rolls very freely, more so than the schui's and losi's at my track (although the TC3 still rules in that department).
also anyone know a way to shim up the axles? since mine have some movement to them, around 1-2 degrees worth, which i know isnt much, but for mod on carpet, i would prefer not to have it.
#1979
While we are asking questions.If all my shocks are at the exact length each,Then why are the rear droop srews not even touching the chassis @ full extention of the shocks.It has got to be something I have done or I would have heard or read something about it by now.Nothing in TSN or here.Someone whith any ideas.
#1980
Thanks Guys, I'll keep this in mind. It'll be a little while before I'm able to do some track testing with the car again. (The on-road season in Manitoba won't start until January.) I had noticed this problem while at "Oktoberfast" and never did get it tuned out.
