Like Tree3Likes
Xray T1
Old 10-17-2002, 08:43 AM
  #1966
I do the outside 3/4's as the outside edge is miles stiffer than the inside edge and its the outside that provides the grip and the inside chunks to easily if you TQ it! I also have some development bits on my car our distributor had made up but we aint sure if they are gonna release them yet. Rick
Rick Draper is offline
Old 10-17-2002, 08:51 AM
  #1967
GregH's Avatar
Hummm, I see....
What are they in respect to the new developments? Can you give us a few ideas???
GregH is offline
Old 10-17-2002, 10:07 AM
  #1968
My car has a IR of 1.77 now but i dont know if Hudy or xray are aware of these parts or if the distributor has just had them made as a trial for the UK only, so noine of you go pestering your distributers or hudy for them as you will not be able to get them!.
Rick
X-ray team driver
Old 10-17-2002, 11:44 AM
  #1969
Rick your setup looks nice. I may try the caster settings you have. I love the way my car feels, and I love hearing from the fast guys.....wow that thing is really flying out there.
also rick what did or do you think of the setup I posted??
I would agree if you are slapping the chassis go stiffer. As for traction rolling I guess that would also depend on other things also. I'm running purple springs with 60-50 wt oil and the car is on rails.
jesse370 is offline
Old 10-17-2002, 12:26 PM
  #1970
mike5009's Avatar
rick draper the set up you posted is it for carpet or asphalt as it is very close to what i have on my car and i'm running on carpet. as you said this car with this set up rotate through the corners very quick cheers, mike
mike5009 is offline
Old 10-17-2002, 01:00 PM
  #1971
Yup the setup is sweet, it rotates far harder than any other car i have ever driven. It is so fast through fast chicanes as well. Duration is amazing with the 1.77 IR as the belts can be ran soooooooooo loose its untrue! Rick
Old 10-17-2002, 08:16 PM
  #1972
Thistle's Avatar
Thanks Jeff,
I wonder... you mentioned closing a hole in the rear shock...would opening holes in the front/lighter oil do the same thing?
Thistle is offline
Old 10-17-2002, 11:42 PM
  #1973
Thistle, I'm not sure what you'd want to do with front shocks to help with your problem. I'm not sure they'd really effect it that much. The reason I said to close a hole in the rear shocks, is that it would increase pack (slow down rebound) and would help to hold the rear of the chassis down.
I've never had a problem with my car lifting a tire (not that I can remember!), so I don't know from experience what to do. Just keep trying stuff, and let us know what works.
JeffC is offline
Old 10-18-2002, 03:48 AM
  #1974
If one of the back wheels was lifting on my car i would look at thefront as the problem as its probably roaling 2 much, try a stiffer spring ond go one hole in on the tower on the front, or just try one hole in to start with.
Rick
X-ray team driver.
Old 10-18-2002, 10:27 AM
  #1975
Rick: Those pulleys are either an Xray part or RW. I've seen a few peeps with them on now so I think they should be going in to production, will know more after the weekend.
//Stu
(fellow Xray/Centre.Point team driver)
Ragman is offline
Old 10-20-2002, 02:42 PM
  #1976
The new pulleys are an RW racing part.
//Stu
Ragman is offline
Old 10-20-2002, 02:50 PM
  #1977
So do you have them yet m8? They are amazing. Rick
Old 10-20-2002, 04:06 PM
  #1978
stormperson's Avatar
what pullies, and where can we get them? lol
although i have to say my xray rolls very freely, more so than the schui's and losi's at my track (although the TC3 still rules in that department).
also anyone know a way to shim up the axles? since mine have some movement to them, around 1-2 degrees worth, which i know isnt much, but for mod on carpet, i would prefer not to have it.
stormperson is offline
Old 10-20-2002, 06:32 PM
  #1979
littledog's Avatar
While we are asking questions.If all my shocks are at the exact length each,Then why are the rear droop srews not even touching the chassis @ full extention of the shocks.It has got to be something I have done or I would have heard or read something about it by now.Nothing in TSN or here.Someone whith any ideas.
littledog is offline
Old 10-20-2002, 06:45 PM
  #1980
Thistle's Avatar
Thanks Guys, I'll keep this in mind. It'll be a little while before I'm able to do some track testing with the car again. (The on-road season in Manitoba won't start until January.) I had noticed this problem while at "Oktoberfast" and never did get it tuned out.
Thistle is offline
