Tamiya TRF415
#3811
They are prototype outdrives for the TRF415...Steen is a TRF driver...remember it
#3812
Regional Moderator
OK guys,
Looking through the past 20 pages and trying to get this car setup for carpet (haven't received it yet, bought it used and should be here by Friday)
Is there something special I need to do to get this to work with foams. The pages previous don't give me a clear picture... (26mm up front and 28mm in the rear)
And also,
Should I get the LW set for carpet? Is it a must?
Thanks, and glad to be part of the family!!
And also,
#3814
THE NEW SET UP SHEET415
DOES SOMEONE HAVE THE NEW SET UP SHEET 415 LIGHT WEIGHT EDITION,THANKS FOR ANSWERING......
BE THE FORCE BE WITH YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#3815
Re: THE NEW SET UP SHEET415
and it's: "May the Force be with You."
Star Wars Fans mark your calanders: SEPT.21.. Stars Wars Trilogy out on DVD.
#3816
Dragonfire: speedtechrc.com
#3817
Re: Re: THE NEW SET UP SHEET415
Originally posted by rc-zombies
pls unlock your CAPS lock..
#3818
Hi, i was wondering just out of curiosity how many teeth are there on the spur gear which comes with 415 and what dp it is
Chazz
Chazz
#3819
64 DP, 102T
#3820
Originally posted by kansasracer
OK guys,
And also,
OK guys,
And also,
I was running 19 turn with Jaco 28mm tires (purple/orange in front and purple in the rear). Besides adding kickup for my next run the onlyt change I will be making is using different compound tires (double pink/orange in the front and double pink in the rear as these tires are better suited to modified than the compounds I was using).
As far as the LW suspension, I bought it but am hesitant to use it. According to Tamiya the LW suspension was designed to be used with long, flowing tracks and not tight tracks. Since my local track is very tight, I will only try the LW suspension once I feel I have fully dialed in the stock on so I can compare the difference.
#3821
Chazz
Chazz
Chazz
#3822
yup
#3823
One more question would a kimbrough 48dp 96tooth spur gear work on a the 415
Chazz
Chazz
#3824
yup (again )
