Tamiya TRF415
#3796
my evo3 was pretty planted bt kept grip rolling in the a-final.
the grip came up to much
#3797
Originally posted by trf racer
you had da 415 with lw suspension and low friction belts?
i had da evo3 with red shell and peak t-shirt on.i was sitting behind u.remember
Coming down again this week?
I've got the spool in this time out, mainly to make the car a bit easier to drive. Hopefully I'll also be in a slightly nicer heat (and not one where back markers pretty much dleiberatly ram you off the track...)
#3798
lol.its always like dat there.
i qualified 6th in the a-final,made a bad start and caught colin up in 3rd then the grip rolling started bt i think i finished 6th overall.
#3799
i was using a one way with cs22.
cnt come this thursday bt will be there nxt week with the evo3 and evo4
#3800
wot heat were u in?i think i was ion heat 5.
that was bad.
i had one competitive person to race against and da rest were like rookies.no lie
that was bad.
#3801
Just finished reading page 126, about the block spacers. those prototypes on DK team looked awsome. they even have a lip to lock the block somewhat in place.
Can't remember who said it but, I read that the Pro4 susp. block shims will work. However, I don't know what they look like. If anyone has a quick pic could you post it, otherwise, I will go get one somewhere else and then post it.
Also, does anyone have pics of the Squat shims?
Cheerz
Cheerz
#3802
Originally posted by TryHard
hey s2,
It seems to me, to give the car more on power steering, not sure if that's caus eof the inboard toe, reduced wheelbase or the narrower front end... but I'm sure some-one on here can help with that.
On a side note, after the talk about bending suspension blocks, had a look at mine today whilst cleaning the car (again... It's a disease I have, I can't have my 415 looking dirty.... ) and I've noticed that my rear B block has a bit on a bend on it guess it must have bent on a heavy hit at some point.. I did wonder why the car seems to pull right under v.hard acceleration, I checked tweak, shock lengths droop, etc, and it still did it, I wonder if this may be the cause... ahh well.
Guess I'll have to a have a look into getting some Alu spacers made up instead, hopefully avoiding this problem.
Regards
Ed
hey s2,
Regards
Ed
It doesn't take much of a hit to bend them. I know from personal experience
#3803
Does anyone know what the white outdrives are from (see Pic)? Are these from the 414? Mmmmm...Awsome block spacer...drooling...
http://www.rctech.net/forum/attachme...postid=1094791
#3804
is the spacer sunk into the block (machined?) or is it just a lip to help keep it in place?
#3806
It is a lip.
#3807
#3808
Cheerz
Cheerz
one other thing you guys can try is the EVO4 sus blocks..if you are putting more than a 1mm spacer under them.. I have gone this route and have yet to have any problems
-Dave
#3809
Originally posted by Evo_Uk
any other infor from this 'reliable source' ....
#3810
