Like Tree3Likes
Tamiya TRF415
Old 04-11-2004 | 12:30 PM
  #1756
Originally posted by trf racer
have you tried
harder springs/anti roll bars/less toe/higher roll center?
opposite at the front.try white springs at back and blue at front.
does this car have as much understeer as the evo3 sl?
TBH my Evo 3 feels far more alive and agile than my 415 although i would say once i have the 415 setup as well sorted as the evo is it will be far faster. Rick
Rick Draper is offline
Old 04-11-2004 | 01:28 PM
  #1757
V12's Avatar
V12
Rick
so what is faster for you currently? EVO3?
I have to say the EVO3 is working pretty good for me. Did win all of the last four 27T stock races including today with the EVO.
I´m watching the 415 but I´m waiting until price drops.
V12 is offline
Old 04-11-2004 | 04:50 PM
  #1758
Hebiki's Avatar
Default Spool Report Part II
Originally posted by JRRobiso
Do you know where can I purchase a spool for my 415. Does Steve (SpeedTechRC) carry them?
Yes, steve will be carrying them. once i give my report to steve, im sure he'll order a whole bunch.
Originally posted by tamiyarcracer
Chris glad you liked the spool. Give Steve any constructive feedback, you can think of. So We can make it the best we can.
Tell me how did you get to be one of the prototype testers???
You think Ian will be able to get one?? ;-)
As for the top shaft. I noticed on Dan's that the pully farthest from the spur slipped inside the bulkhead a little, and left a witness mark from rubbing.I was thinking I would make a spacer to fit between the pulley / spur gear mount, and the bearings
mr troy.. my only suggestion is to anodize it blue! like i said before, the spool worked great. i checked my car last night, no wear anywhere, even after hitting the boards at socal.
i was lucky enough to be at the right place at the right time, and steve asked me to prototype. ill run this coming sunday at a parking lot race and let you know. my set up (like rod's) pushed a bit at socal, but it was like a bat out of hell coming out. car felt good overall. ill yank it after next sun and hand it over to ian to prototype, steve didnt have enough to give to me and ian. so we have to share
btw mine(center pulley) is tucked inside (bulkhead) also. i have pictures. will post soon.
Originally posted by jeffreylin
Chris, I had that problem too when I first built the car and I had to rebuild the center. You have to play with the placements of the pully and the spur gear holder a little so the spur gear holder won't touch the bulkhead.
jeff, too late the bulkhead has already lost its blue anodization. oh well. i had to sand it down anyways to make room for the two center pulleys.
overall, the car's drivetrain is set up great right now. its reedy race ready!
Hebiki is offline
Old 04-11-2004 | 04:57 PM
  #1759
Hebiki's Avatar
Default Photo
Picture of center pulley tucked into bulkhead
Hebiki is offline
Old 04-11-2004 | 08:03 PM
  #1760
tamiyarcracer's Avatar
Default Re: Photo
Chris you did that differently than I had thought. I was thinking of putting the pulleys back to back. Can you send me a pic of the car, straight down from the top? Want to see how the belt looks to the front.
By the way still haven't built mine yet, as it is undergoing a transformation. I hope it will be something people want to look at down there at Reedy.
As for the Blue anodizing. I could, but the black coating is a a heat treating process that is availible to me. If it were anodized, I'm not sure it would be as durable.
tamiyarcracer is offline
Old 04-11-2004 | 08:30 PM
  #1761
cHckbOY5's Avatar
trf 415 on sale at ultimate hobbies
cHckbOY5 is offline
Old 04-11-2004 | 08:51 PM
  #1762
Turbonium's Avatar
Originally posted by V12
Just heard today Yok SD outdrives will work for a 415 frontdiff. Anyone tried this?
the SD diffs are off center... wont work for the 415, i dont think. what have been playing with is the rear set from the older belt car. it is centered... i found the 6x11 bearing i was looking for, and when they get here if my idea works, ill be sure to post pix on here.... :crossing fingers:
Turbonium is offline
Old 04-11-2004 | 09:52 PM
  #1763
eeyan's Avatar
Default Re: Re: Spool Report
Dohh... Troy... thanks for thinking of me... hehehe, don't worry, the proto spool is in good hands with Chris on the throttle. He'll surely be testing the durability side of it... j/k Hebiki....
eeyan is offline
Old 04-12-2004 | 12:59 AM
  #1764
Default TRF SETUP & SRPING RATE
I will receive TRF 415 in next week so I have couple of question about car:
Where I can found good TRF 415 setup(s) for "low" grip indoor / outdoor track?
What are Tamiya spring rate ( in lbs )
Thanks Jani
jani s is offline
Old 04-12-2004 | 03:22 AM
  #1765
V12's Avatar
V12
That´s what I heard yesterday the SD diffs are working. But I have no 415 yet for trying.
Maybe it was a mix-up with the old car.
V12 is offline
Old 04-12-2004 | 08:11 AM
  #1766
Kenneth Tan's Avatar
49341 TRF415 STRAIGHT PACK TYPE LOWER DECK 8800YEN 27TH (May)
New item seen on rainbowten.
Kenneth Tan is offline
Old 04-12-2004 | 09:33 AM
  #1767
Hebiki's Avatar
Default Re: Re: Photo
ill get you one in the next day or so.. PM me and ill email it to you directly.
Hebiki is offline
Old 04-12-2004 | 09:43 AM
  #1768
whats so good about the trf 415
HEWITT is offline
Old 04-12-2004 | 10:36 AM
  #1769
Holmenkollen's Avatar
It`s an easy car to drive fast with.
And you won´t break any one way gears.
Holmenkollen is offline
Old 04-12-2004 | 10:38 AM
  #1770
rc-zombies's Avatar
what's all included in the kit? and what other option/tuning parts are needed? springs, swaybars sets, toe-in blocks?
rc-zombies is offline
