Tamiya TRF415
#1906
Originally posted by Difuser
Chris I looked back at it I had initially set tension at 2 so I am going to 3 now.
heheill do some testing on sat if i get all the parts in time... and i might even go to 4 clicks? did u try the every other tooth yet? i have the belts ready.. but havent tried it yet.
#1908
After running both this past weekend... EVO3 in 19t and 415 in Mod for the first time... I felt the two cars are "almost" identical in terms of handling... I swear I felt I was driving 1 kind of car the whole day... Interesting enough though, I tq'ed in 19t(evo) and ended up with a time faster than my best in mod class...
#1909
Originally posted by madjack
I would be interested in polling the 415 owners/racers that have switched from an EVO3 to the new car...faster... slower... the same?
#1910
Originally posted by FUK_WRX
After sitting in my cabinet for nearly a month and a bit i finally finished and ready to rumble on friday.
Thanks Jun
#1911
Originally posted by JRRobiso
Interesting front graphite bumper brace you got there. May I ask who made it and where can you purchase one?
Thanks Jun
Thanks Jun
#1914
three years in mod and tonight at the track the first time I lay the 415 I really notice a BIG difference.
the 415 was easy to point where you want it to go.
Considering a had the tc3 for 3yrs I knew this car inside out.
Imagine the potential on the 415!
Guess need to find a new owner for the tc3
#1918
I have been running cooler surfaces with med bite up here in the NW and to minimise the push I have removed the 4mm under the link. I also added some sweep to the rear arms 1mm at the alum hub
#1919
Guys i noticed there is not much spur gear choices available for the 415, im going to need to sell most my 48pitch gears
Anyway i was wondering if the original spur gear is 64 pitch?
And whats the biggest 48pitch spur gear you fitted in the 415?
#1920
3Likes
