Like Tree2Likes
Tamiya TRF415
Old 04-09-2004, 11:38 AM
  #1726
rayhuang's Avatar
Hi Difuser-hope you and your family are doing Great!! I sent you some mail!!
Ray
rayhuang is offline
Old 04-09-2004, 11:50 AM
  #1727
Yeah I am hoping to be out of the chair next week
Difuser is offline
Old 04-09-2004, 12:28 PM
  #1728
eeyan's Avatar
Originally posted by TRF_StEvE
what the big deal with trying to make up a different diff for the 415 ?
A lot of guys here are hoping to enter and run the 415 at the upcoming Reedy Race which calls for a "no oneway" rule. Thus a few here are trying different stuff to get their cars legal... hence you got the spool setups and different diff setups... Hope this helps clarify why there is a "hunt for the perfect 415 diff alternative..." ***(OOPS, somebody already answered this... sorry for double posting...)
eeyan is offline
Old 04-09-2004, 12:33 PM
  #1729
Just like eeyan late to the game. I am hoping to see you guys down there for Reedy not sure on the medical side yet.
Difuser is offline
Old 04-09-2004, 12:41 PM
  #1730
Hebiki's Avatar
Trader Rating: 26 (100%+)
eeyan IS FILIPINO..and they are known for being late... i shouldnt be talking i said i was gonna be at the track at 530am to help set up and i didnt get there until 7am. hahahahahaha
its gonna be weird driving with a spool. im so used to a oneway.
Hebiki is offline
Old 04-09-2004, 12:42 PM
  #1731
eeyan's Avatar
Hahaha... yup, I type too slow!
Regarding Reedy, I sure do hope we get in... Well at least you're already in Dan! Just take care of your health and come down here will ya?! Hope you guys have better luck with the 415 this year...
eeyan is offline
  #1732
Are you trying one of Troy's? or the 2 half idea?
Difuser is offline
Old 04-09-2004, 01:03 PM
  #1733
Hebiki's Avatar
got a prototype from troy via steve at speedtech. dont know about the center though. i dont wanna chop off from my spur gear holder.. id rather chop off a center pulley.. but pinning it might be difficult.. i wonder if i can just JB weld them together? any ideas?
Hebiki is offline
Old 04-09-2004, 03:49 PM
  #1734
JimmyMac's Avatar
I would just buy an extra shaft and 2 extra pulleys. Cut one end of the pulley's off and then JB weld everything to the shaft. Just be sure to center the pulley first on the car with one of the locked pulleys before you do so.
JimmyMac is offline
Old 04-09-2004, 05:11 PM
  #1735
Doing the JB will make it so you have to pull off one side of the bulkheads. The pinning is going to be a pain without a jig to make sure all is straight. I like Beale's idea but I am not sure it will be available to the public.
As far as hacking the spur holder it is easily done with a dremel should take about 5 min max. 2-3mm is not much to remove from the holder. the only part is figuring out a shim when using the 1-way in the future a shock spacer or.... should do the trick.
Just think you can buy the super duper Ti version to replace it.
Difuser is offline
Old 04-09-2004, 05:17 PM
  #1736
Ran my 2nd car today indoor on carpet with the 6 deg ta04 caster blocks on and it held the line 100% better in the middle of the turn where as without them it would push mid corner round the fast ones. Also this one has cut belts on and its bloody free!
Rick
Rick Draper is offline
Old 04-09-2004, 07:05 PM
  #1737
Paul_Kultcha's Avatar
How many different castor blocks are there to order for the TRF415? 4, 6, and 8 degree?
Does anyone have the part numbers?
thx
Paul_Kultcha is offline
Old 04-09-2004, 09:51 PM
  #1738
JimmyMac's Avatar
As for pulling off one side of the bulk heads... I think that's the least of your worries. I mean if we are converting oneway setup to diff/spool setup... you'd have to take the front apart anyways to replace the oneway with a diff... or visa versa. Of course the point of replacing the spur would be harder..
The pin idea would be easy. Just mount the 2 pulleys on the shaft. Lock them down and then drill the 2 holes. This way they are already aligned. Drill one hole. Slide in the pin. Drill the next. Slide in the pin. Pull the pulleys off the shaft. Then cut one down to size. Done.
JimmyMac is offline
Old 04-09-2004, 09:55 PM
  #1739
over gear's Avatar
Trader Rating: 16 (100%+)
thx
There are 4,6 and 8deg? what's on the stock 415?
over gear is offline
Old 04-09-2004, 10:05 PM
  #1740
JimmyMac's Avatar
4 is on the 414, Evo3 and 415. 6 I beleive are the newer TA04's. The 8 I'm not sure. I think they are the older ones from the earlier TA04's. They have the uhhh ears ontop for the camber link. You'd have to cut them off to allow you to put a ball connector/kingpin ontop and not interfere with the camber link. Let me search for part numbers real quick......
JimmyMac is offline
