Old 10-20-2006, 01:53 AM   #16126
TryHard's Avatar
Originally Posted by Tek Nickal
I believe people use the HPI steering blocks because it allows the use of foam tires.
Also, has anyone noticed that when running rubber tires on the MSX, when the suspension is compressed, the inside of the tire rim hits part of the suspension arm. I shaved the plastic on the arm where the rim contacts, it doesn't seem to affect the stiffness of the arm.
I was just wondering if this is the case for anyone else. I'm using RP-30 tires.
Correct on the foam thing. It also lowers the front axle by about 1mm, which iirc helps traction. Also changes the ackerman, in general I find it gives more steering when using the HPI hubs... but given the MRE has loads anyway I don't run them anymore. Plus I do know of numerous people who find them to be a bit brittle, personally only ever broke one.
The tyre thing... yeah it happens. It does seem to be worse on the new soft CS/RP wheel, although I did also get it on the old style. best thing to do is as you say, shave it off the arm... I'm pretty sure Tamiya know about this as well, as the new short arms don't have that bit of plastic on them.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-20-2006, 01:55 AM   #16127
TryHard's Avatar
Not completely, you still have to buy the LW (Lightweight) reversable suspension arm conversion set. Which uses suspension parts from the EVO4.
RC Reversible LW Sus Set - TA05/TB02/TA04
Part #53899 for the LW suspension conversion set.
Also the conversion kit is missing the center post.
I believe you can get a center post here: Center post
It is Tamiya part #3454351.
Actually, if he's got an MS, it'll already have the LWT arms. The centre post piece is correct... and the other main bit is the alloy with blades rear diff (again you can get the parts for this as well).
HiH
Ed
Old 10-20-2006, 01:55 AM   #16128
Stein Tumert's Avatar
Originally Posted by CRASH
TryHard
What are the steps and parts needed to use the TA05 center pulley on the 415?
Thanks,
About TA-05-parts-listing, here it is:
- 51214 Centershaft
- 9808019 Centershaft-C-rings
- 9808018 Centershaft-Spacer (alu 2,8mm breit)
- 51213 Centerpullys (2pcs.)
- 3455870 Spurgear-holder
- 53874 precision-bushing (1pcs.)
- 9805672 BB 840 (2pcs.)
- 51211 Spurgear-screws
- 53586 spacer for centershaft (Durchmesser 4mm - breite 0,3mm)
Stein Tumert is offline   Reply With Quote
Old 10-20-2006, 02:19 AM   #16129
JoelNavarro's Avatar
Anyone wanna buy my 415? Its first generation i believe. I havent ran it much. One race day at SoCal, all weekend at 2006 Tamiya Nationals (i won the B-main), and a couple times on carpet. Only thing it needs is the front belt (i knicked it with the scissors cutting a zip-tie and it broke on the next run - DOH! ), otherwise it is in excellent condition. Ive been my xray T2 mostly. Any takers?? If ya are message me with a private massage.
Radio Control Car Action Magazine West Coast Editor - www.rccaraction.com
I race at - SDRC Raceway, CVRC Raceway and SoCal-RC Onroad
My Painters: Fatty Grafx -https://www.facebook.com/pages/Fatty-Grafx/138256833000949
JoelNavarro is offline   Reply With Quote
Old 10-20-2006, 02:58 AM   #16130
- 51214 Centershaft
Actually you don't need all that. Here is the link:
http://www.rctech.net/forum/showthread.php?t=119997
The shaft is on the short side, but it can be used. Works fine.
Finnitro is offline   Reply With Quote
Old 10-20-2006, 04:30 AM   #16131
CRASH's Avatar
Trader Rating: 26 (100%+)
Thanks for the info.
Later,
CRASH is offline   Reply With Quote
Old 10-20-2006, 07:37 AM   #16132
Trader Rating: 21 (100%+)
Default ALMOST DONE
Another one...The blades on the cvd's...do we not use them in the front?They don't fit so it seems so,just want to be sure I don't have anything misbuilt.Otherwise...awesome kit.Everything else is going great.Mario
lotus1 is offline   Reply With Quote
Old 10-20-2006, 08:39 AM   #16133
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
nope, the blades arent used in the delrin outdrives on the spool...
i was gonna machine the oneway outdrives to use them, but havent yet. so far they are only used in the alloy diffs, either front or rear.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-20-2006, 08:51 AM   #16134
Thanks.Thought so.lol.Mario.
Old 10-20-2006, 11:21 AM   #16135
Default One final Q
Are my shocks too short?At full extension the arms are just a hair,just a hair,below level.That's downward from the chassis to the outside of the arm.Should'nt the outside edge fall a bit further than essentially level?Mario.
Old 10-20-2006, 11:56 AM   #16136
TryHard's Avatar
I find you need to unwind the shock bottoms a bit to get good droop. I find setting the shocks to 62.5mm or 63mm is a good start (measured from the top of the shock cap, to the bottom of the end joint).
And don't worry, it doesn't affect the strength of the shock bottoms.
HiH
Ed
Old 10-20-2006, 12:10 PM   #16137
Default aaahh
HiH
Ed
Once again...Thanks.I had to do that on the TC4 rear shocks too.Will do.Almost done!Hoping to try it out at our practice session on sunday.Finish this,then it's just electrics and trims.Mario.
Old 10-20-2006, 12:16 PM   #16138
TryHard's Avatar
Excellent Good Luck... you'll find the car has LOADS more steering than your TC4
Old 10-20-2006, 03:42 PM   #16139
WRXTC's Avatar
What is the beneifit of the centre post mentioned?
Also when I put the kit together last night as per the instructions the screws that hold the steering assembly together (hold the bearings etc in place) will not pass under the front bulkheads They hit the bulkheads and thus no steering. I have had to raise the front bulkheads 1mm with a shim or two just to get enough clearance for the steering assembly to work.
Anyone have a simlar problem or a solution?
WRXTC is offline   Reply With Quote
Old 10-20-2006, 04:00 PM   #16140
Trader Rating: 24 (100%+)
Default MSX RE Help
I'm not familar with spool diff. as in what effect it has on steering. I can't get another RE rear diff pully to run a diff in the front but I want to run this car. The local track runs 19t rubber tire on carpet. I'm not sure what to expect if i run a spool in the front.
Thanks,
John
www.evo-grafix.com
redbaron is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
