Like Tree2Likes
Tamiya TRF415
Old 10-08-2006, 08:07 PM
  #15976
Originally Posted by Ben.C
The 10X1 V2 is a good motor to start with. Kawada makes very top notch gears.Good choice.
I'll say start with a ratio of 8.5,which can be done using 102/27. Then if you're not happy with the top speed, you can either go up on the pinon or go lower on the spur.
Thanks for the help!
halayli is offline
Old 10-08-2006, 08:36 PM
  #15977
Trader Rating: 21 (100%+)
Default oopps.
Originally Posted by Difuser
Lotus, small clarification, Troy=tamiyarcracer (2006 Mini nat'l champ)
Doug=rchoudini-- SIR shop owner
Both great guys. Enjoy the chassis.
Thanks,Sorry.Tamiyarcracer told me abiut the kit/shop etc.Just assumed it was Doug.Spoke and dealt with Doug tho.Great all around.Mario
lotus1 is offline
Old 10-09-2006, 07:17 PM
  #15978
tamiyarcracer's Avatar
Mario I spoke to you, I was the one that took the Order. Doug was in the background calling the race.
But on Another Note, The kit is on it's way Doug was getting it ready to go when I spoke to him this afternoon.
How about the F1 race?? Was that worth staying up for or what?
tamiyarcracer is offline
Old 10-09-2006, 10:50 PM
  #15979
Default Double oops.
Ah jeez...That's what happens when it's late here and I've been up since 6 am.lol.Sorry.Thanks again for this.Looking forward to running it.Gonna be foams till the new year,then rubber.Lots of testing.The race was worth it.Schumi and his bid for his last championship went up in smoke. Oh well.Been trying to recuperate since.How was the 24 hour race/results?Cool idea.Going to try to get one going at my local track.Sounds like lots of fun.Were you guys running TC's or something like mini coopers?Hopefully the guys/track owner will go for it.Again thanks for this,Mario.
lotus1 is offline
Old 10-09-2006, 11:09 PM
  #15980
As for the race there was a great chase in the last 2 hours.
As for the cars, 1/10 scale was the requirement, there were 2 pan cars, and 6 sedans.
Old 10-10-2006, 05:32 AM
  #15981
buboy28's Avatar
guys, will Tamiya be releasing a front one-way for the MRE
buboy28 is offline
Old 10-10-2006, 07:35 AM
  #15982
Jam-ehz's Avatar
Yup, it's-a-coming...
http://www.tamiyausa.com/product/ite...oduct-id=53947
Jam-ehz is offline
Old 10-10-2006, 08:15 AM
  #15983
Whats the internal ratio of the MRE ?
Whats biggest spur you can fit in 64dpi ?
I have just looked through my manual and found MSX ratio but not MRE , just trying to sort out what size spurs i need to get.
Thanks in advance.
weekendracer_uk is offline
Old 10-10-2006, 08:16 AM
  #15984
Default Foams
Can anyone tell me which suspension mounts come with the MRE.Going to be using the IIC 2005 setup to start.Need to know which ones,if any,I need to get for this.Thanks,Mario.
lotus1 is offline
Old 10-10-2006, 08:34 AM
  #15985
TryHard's Avatar
MRE comes with B/A for the front, and XB/D for the rear... You'll need an extra D block, and a D-Bridge block, and thats it for the IIC setup (D/D-bridge front, B/D rear)
HiH
Ed
TryHard is offline
Old 10-10-2006, 08:37 AM
  #15986
TryHard's Avatar
Thanks in advance.
I think about 108/110 is the largest with the layshaft in the low position... not sure about it in the high, would guess around 120??
Internal ratio is 2.25 for the MRE I beleive.
HiH
Ed
TryHard is offline
Old 10-10-2006, 09:15 AM
  #15987
Just got a brand new 415MSX MRE. I'm building the rear diff. I see there is a spacer bewteen 2 bearings. But I couldn't find it anywhere in the kit. Is that the spacer is in the shims package which has a lot blue and silver shims? I found one metal shim in that pakcage but the size is not 5x0.5mm but it fits in the rear diff. Is this the correct one or it is in other pakcage? Is it a metal shim or plastic? Thanks!
ioxqq is offline
Old 10-10-2006, 09:50 AM
  #15988
The MRE edition comes with an MRE specific manual that contains replacement steps to the original manual. Make sure you are following the step in the MRE edition and not the original manual if there was a replacement step for it.
halayli is offline
Old 10-10-2006, 11:27 AM
  #15989
TryHard's Avatar
The shim your looking for is the same as the 4 used in the steering posts (going above and below the bell cranks). There should be 5 in total with the kit, check that bag if you can't find it.
HiH
Ed
TryHard is offline
Old 10-10-2006, 11:31 AM
  #15990
Default otay
Thanks,Mario
lotus1 is offline
