Old 10-20-2006, 06:48 PM   #16141
Sean T Guy's Avatar
If I was to use the new short wishbones (53928) would it be better to change the blocks as to regain track width? If so what blocks would work on the MRE , Thank you to anybody who can advise.
Schumacher Racing UK
Team Scream UK
eXpress Motorsports UK
FTQ Models
Sean T Guy is offline   Reply With Quote
Old 10-20-2006, 07:19 PM   #16142
LBSR415's Avatar
you would want to use the larger blocks in a combination to restore your toe in or out,,,for example,,,,,,,with the long suspension you could use an A block and a B block to achieve 1 degree of toe,,,with the short arms you could us a d and and e to maintain track width,,,,,,,you may have to switch to 42mm driveshafts
Team OHP
Razor Graphix
East Coast R/C
Pantheon Motorsports
These fish,,,are frozen.
LBSR415 is offline   Reply With Quote
Old 10-20-2006, 08:10 PM   #16143
Tek Nickal's Avatar
Originally Posted by WRXTC
What is the beneifit of the centre post mentioned?
Also when I put the kit together last night as per the instructions the screws that hold the steering assembly together (hold the bearings etc in place) will not pass under the front bulkheads They hit the bulkheads and thus no steering. I have had to raise the front bulkheads 1mm with a shim or two just to get enough clearance for the steering assembly to work.
Anyone have a simlar problem or a solution?
Make sure you are using the counter-sunk screws, and that the flanged bearings are completely flush on both sides of the graphite steering plate. Don't raise the bulkheads, it changes the suspension geometry and everything else.
Tek Nickal is offline   Reply With Quote
Old 10-20-2006, 08:32 PM   #16144
WRXTC's Avatar
Thanks mate, I actually worked out the shims that I had on the flanged bearing assembly was wrong.
WRXTC is offline   Reply With Quote
Old 10-20-2006, 10:04 PM   #16145
Trader Rating: 24 (100%+)
Originally Posted by redbaron
I'm not familar with spool diff. as in what effect it has on steering. I can't get another RE rear diff pully to run a diff in the front but I want to run this car. The local track runs 19t rubber tire on carpet. I'm not sure what to expect if i run a spool in the front.
Thanks,
John
www.evo-grafix.com
Anyone?
redbaron is offline   Reply With Quote
Old 10-20-2006, 10:41 PM   #16146
Tek Nickal's Avatar
If your going to be running carpet, get the front diff.
Tamiya item #53921
TRF415 Front Alum Diff Joints
Old 10-20-2006, 11:04 PM   #16147
Tamiya item #53921
I plan on getting the front diff but I'm waiting on the pulley. I already have the 53921 but I need 53935 pully as the pulley for the spool won't work.
I'm looking for some insight as what to expect with the spool as I will be forced to run with this until Tamiya can get the 53935 to me.
Old 10-20-2006, 11:34 PM   #16148
kewdawg's Avatar
A spool will make the car push. You'll have to set the front suspension up to be softer and exhibit more roll. This will help you get into the corners better. Play with the caster to achieve the right amount of on or off-power steering. Also, increase your front camber by 1 degree. This should put you in the ball park and then you can fine tune it for the track conditions.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 10-20-2006, 11:50 PM   #16149
Tek Nickal's Avatar
I'm not familiar with the MRE, if it did come with one-way center pulley you should consider getting this
TRF415 Direct Center Pulley
Actually you don't need all that. Here is the link:
http://www.rctech.net/forum/showthread.php?t=119997
The shaft is on the short side, but it can be used. Works fine.
Old 10-21-2006, 06:07 AM   #16150
HarshGuy's Avatar
If you're running carpet rubber ...I think most (including me) people use a front oneway ..diff for foams.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 10-21-2006, 11:21 AM   #16151
CRASH's Avatar
Trader Rating: 26 (100%+)
Does anyone use a battery strap or does everyone just tape in your batteries?
If you do use a battery strap who is it made by?
Thanks,
CRASH is offline   Reply With Quote
Old 10-21-2006, 11:33 AM   #16152
Charles Godwin's Avatar
I use tape, either the normal tape (no colour) or the stuff with a backing on it (coloured tape, but more expensive). Seems to be less chance of getting tweak if you hit a board as the cells can very slightly move instead of being clamped down and not able to move.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 10-21-2006, 12:12 PM   #16153
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Charles
Me as well, I use strapping tape. Just as Charles said any type of strapping tape would work fine (branded or not branded). For your first time of using it & putting it on, it may take a couple of times to get use to it. But once you get a hang of it, it only takes under a minute to install.
I only use one strip for 3 heats everytime I race in a day. One tip when using tape for your batteries, make sure you have enough length of tape to cover the batt pack from one side to the other.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 10-21-2006, 12:35 PM   #16154
JRRobiso's Avatar
Post Bearing Set Replacement - Ceramic or Regular Bearing Set
Quick question in regards when replacing the bearings. Is it really worth getting ceramic bearing set or just the regular set? Or am I better off just putting ceramic bearings (total of 8 pcs) for the wheel hubs F/R?
What's my best option/s?
Old 10-21-2006, 02:38 PM   #16155
Tek Nickal's Avatar
Thanks,
I switched from the 3M brand of tape, the colorless one, to the one backed with an extra layer (mine is black color) and it lasts so much longer, and the batteries don't move at all.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
