Old 10-19-2006, 11:51 AM   #16111
JAY_UK's Avatar
Send a message via MSN to JAY_UK
Originally Posted by robsxxxs
anyone know where i can find a blank setup sheet for the msx online?
www.thard.co.uk or tamiya usa website!
JAY_UK is offline   Reply With Quote
Old 10-19-2006, 11:54 AM   #16112
Trader Rating: 21 (100%+)
Default Hey,
Thanks guys.I thought they were for the steering,especially since I installed the steering assembly already.lol.Also for the ballstud info.Tryhard, are you by any chance refering to the 2 piece ballstuds in your answer?The MRE addendum sheet shows using the one piece ballstuds.I think I will use the 2 piece ones anyway tho.Couple more Q's...How is the included servo saver?Use it or should I just upgrade?The big one for me tho.....The suspension arms are a tight fit on the hinge pins.Should they be left that way so it all hinges in the block or should I ream them for free movement on the hinge pins?Thanks again all,Mario.
lotus1 is offline   Reply With Quote
Old 10-19-2006, 12:00 PM   #16113
Charles Godwin's Avatar
Leave the hinge-pins as they are because they don't need to move like other cars. They have flourine ball type thingys on the end which move when inside the alum blocks. Change the servo saver to a Kimbro servo saver or just use a std servo arm.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 10-19-2006, 01:17 PM   #16114
Charles
I was kinda thinking that might be the case.Wanted to be sure.Thanks.They do seem kind of "stiff"when using the grease on the ball thingys.Should I not grease them?Or will they"loosen' in a couple of runs?Mario.
Old 10-19-2006, 01:26 PM   #16115
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
They should be loose from the start.. just make sure there's just a tick of play for the arms to be free to move.. if not, you need smaller spacers. You should feel it just barely shift when you try to slide the arm forward and back along the shaft..
I'd use just an extremely light grease..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 10-19-2006, 02:41 PM   #16116
TryHard's Avatar
Pic of the adendum sheet I was on about. The MRE instructions show to use BC2 (the normal size), you should follow the adendum sheet which uses BB9 (the short type).
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-19-2006, 02:57 PM   #16117
Default aha.
HiH
Ed
I have the addendum sheet but the BC2/BB9 instruction part is missing.I guess it didn't print.Thanks,Mario.
Old 10-19-2006, 03:21 PM   #16118
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
HiH
Ed
Only ever slight problem ive seen on the MRE, the BB2's have been coming loose on mine, and i didnt want to loctite them. Does everyone else loctite em?
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 10-19-2006, 03:25 PM   #16119
TryHard's Avatar
I do actually use the hexheaded ones.. but yes, I do loctite them anyway.
Old 10-19-2006, 08:39 PM   #16120
CRASH's Avatar
Trader Rating: 26 (100%+)
TryHard
What are the steps and parts needed to use the TA05 center pulley on the 415?
Also, what benefit due you get from using the HPI steering blocks?
Thanks,
CRASH is offline   Reply With Quote
Old 10-19-2006, 08:55 PM   #16121
Tek Nickal's Avatar
I believe people use the HPI steering blocks because it allows the use of foam tires.
Also, has anyone noticed that when running rubber tires on the MSX, when the suspension is compressed, the inside of the tire rim hits part of the suspension arm. I shaved the plastic on the arm where the rim contacts, it doesn't seem to affect the stiffness of the arm.
I was just wondering if this is the case for anyone else. I'm using RP-30 tires.
Tek Nickal is offline   Reply With Quote
Old 10-19-2006, 09:05 PM   #16122
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
HiH
Ed
How come my adendum didn't have that correction. Now I have to disassemble the steering rack.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 10-19-2006, 09:36 PM   #16123
WRXTC's Avatar
I know I am a little behind with the release of the MRE but I just purchased Tamiya Part #49378, the MS upgrade Parts Set. Will that effectively make my MS an MSX?
WRXTC is offline   Reply With Quote
Old 10-19-2006, 11:57 PM   #16124
Tek Nickal's Avatar
Not completely, you still have to buy the LW (Lightweight) reversable suspension arm conversion set. Which uses suspension parts from the EVO4.
RC Reversible LW Sus Set - TA05/TB02/TA04
Part #53899 for the LW suspension conversion set.
Also the conversion kit is missing the center post.
I believe you can get a center post here: Center post
It is Tamiya part #3454351.
Old 10-20-2006, 01:51 AM   #16125
Stein Tumert's Avatar
It is a small piece of paper (8x8 cm or so) lying inside the addendum for the MRE.
Stein Tumert is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
