Tamiya TRF415
#1531
Originally posted by Cobra81li200
you should try to get Kawada diff outdrives. They're a perfect fit on Tamiya diff gears and plates. If you can make 10mm diameter spacers to prevent the play (as they're made for a car that's only 15mm wide on the bulkheads) they'll be perfect.
#1532
Originally posted by Pyramid
Great tip
Great tip
#1533
indeed, but you'll have to use longer dogbones, as the stock ones are too short with these outdrives. I suggest trying the MIP CVDs from the Assassin
#1534
Originally posted by Hebiki
i think a tighter belt has more rip out of a corner? am i right? i dont remember what the earlier post stated.
Sorry, I'm not often been here lately.. but where do you guys have that ide of clipped belt? what cause the problem so that you try clipping the belt?
Also, in case have not been mention, do not use R side (see setting sheet) on front knucle (C1/C2) as you wont get full steering throw on TRF415. It's a whole different story with 414.
#1535
Clipped belts (or clipping every other tooth off) is a trick that alot of the Losi guys are doin in Stock. It helps make things smoother and more efficient, less drag.. blah blah blah....so they say. So since some of us have a couple spare belts laying around... it's something to try out. I wouldn't recommend it for mod though. I guess it's just part of the hobby of trying out different things. Modify this... modify that. Stuff like that.
As for belt tightening, I decided not to go past 3 clicks for the rear. I found that my diff had loosened a tad causing it to slip too much. So I'm hopping thats where I lost my acceleration off the line. We'll see later on this week or this weekend.
#1536
I think the reason clipping the belt works in the losi is because of the path of the belt. In the losi the belt tensioner pulls the belt back on itself and so the drive train is not as free as it would be if the belt was in line.
The 415, MY02, MI2 style of cars have the belts in line and would have less friction because of this, I think you could get the same effect by adjusting the tension on the belts.
From memory also the Losi belts tend to be much stiffer then the others which would also affect how well they work. I don't know if this is true of the new black belt.
just my 2c
Tony
just my 2c
Tony
#1537
Belt clipping is used by Losi team drivers because they're using a different internal ratio that needs cutting every other tooth in order not to catch. It's been take by other drivers because they thought it was to have afreer drive train.
I woulnd't clip them on any car.
My 2cents
My 2cents
#1538
My 2cents
My 2cents
half of the 415 guys already clipped their belts.. including me thats $14 down the drain if it doesnt work as planned.
#1541
Originally posted by over gear
i'm building my 415... What gearing should i use for a Monster stock and Reedy quad magnet 19T ? i'll be using 48pitch gears...
#1542
I'm joining in too !!
Hey,
I'll be running a 415 as of next week hopefully. Can't wait.
Any hints and tips etc for building the car???
Also can someone tell me what size hex wrenches and nut drivers this kit uses? Just need to know what to order.
Thanks,
Thanks,
#1543
Re: I'm joining in too !!
Originally posted by Glue-Stick
Hey,
Thanks,
Hey,
Thanks,
#1544
Jeff, when are you going to be back?
#1545
