LRP Vector x12 Brushless Motors
#226
yeh we put a 'brushed creep' in it, but it took a lot to keep it from locking. and locking on a 2wd on chalky clay sux.
buy the fantom equivalents. at least u can have the same performance and BS urself that they are not trinity lol
R
R
#227
I have an X-12 17.5 on order and have a couple questions before it gets here. First, are these stock-spec motors ok at temps up to 100c like the mod ones are? Second, how well do they respond to sensorless timing advance? I'll be running it on a Tekin RS speedo, so it will switch over to sensorless mode once it gets spinning. I know most high-wind motors like this want a lot of timing advance, so just wondering if these are any different.
#228
i find that my 21.5t X12 runs best at around 85-90c, if it gets hotter i loose power.
#229
I have a x11 5.5t in perfect working condition...it's just too FAST for my purposes. If you have a x11 or x12 from 13.5-17.5T in great working condition and want to trade it for a 5.5t, please PM me! Thanks and happy holidays
#230
if you are running the RS speedo with a 17.5t you should run it sensored only. and download version 203 also called hotwire 4.0 its on their site somewhere or else you can find it in the RS thread. and you will be flying..
The track I run on is small, barely any time at full throttle, so I'd rather have the reliability/efficiency of the dual-drive mode than the timing boost feature in the sensored only mode.
My question is related to earlier posts in this thread saying that the low-turn mod motors should only be run at the lowest timing, and advancing that only adds heat, not speed. I'm wondering if the same is true of the high-turn stock winds when advancing the timing on the esc for sensorless mode.
#231
x12 13.5
just got my x12 an noticed I only had the 2 dot that is stock then in a package i they only gave me a 3 dot and 4 dot. I didn't get the 1 dot. did they just mess up
#233
Octa wind
What are the benefits of the octa wind series? Do you get a less aggressive punch, like, say, a quad wind Vs. a double one on a brushed? Or, hem... a Novak "L"?
#234
Will the octawind be available in a 4.5T or 5T?
#237
Guys,
What is a good gearing for a 6.5 motor (with 12mm rotor) in 4wd offroad, or any other class?
I am running 10.4, and the motor seems to get really hot, will measure temps when possible!
#238
Racers.
What temp would you say the X12 starts to loose its efficiency?
Mine is peaking at 155F, after a 5min race.
Can i go higher???
Cheers
Brendan S
Can i go higher???
Cheers
Brendan S
#239
#240
155F is just getting warmed up. I do not recommend it but we have seen under certain conditions the motors running at 235F with no ill effects. That being said I do not think that a motor will tolerate that type of temperature on a consistent basis. Also bearings require frequent oiling if motors are running that hot.
