TAMIYA F103 RM
Old 03-21-2009, 02:50 PM
  #1786
silverhkswrx's Avatar
Originally Posted by 414MPH
I did the same thing a few weeks ago on our carpet track....SNAP!
di your axle snap?
silverhkswrx is offline
Old 03-21-2009, 02:53 PM
  #1787
edhchoe's Avatar
Trader Rating: 41 (100%+)
I wonder if the newer motor box is weaker than the old f103 motor box. The long thin spacer on the left can easily take out the bearing in a side impact.
A fix would be a pair of spacers on the inside of the box on both sides. And the load from the outer spacer on a side impact will be halved.
edhchoe is offline
Old 03-21-2009, 02:54 PM
  #1788
vzereeys's Avatar
Hey guys, what size pinion (pitch and module) do these
speed demons use?
Thanks in advance,
-Steve
vzereeys is offline
Old 03-21-2009, 04:17 PM
  #1789
idwurks's Avatar
Just snapped my axle today. Time to stock up on aluminum ones.
idwurks is offline
Old 03-21-2009, 07:03 PM
  #1790
alum ones bend. i have the square rc one and it survived that wreck with absolutely no scratches at all.
Old 03-21-2009, 07:33 PM
  #1791
TFR
TFR's Avatar
Any chassis pictures? Any modifications to fit the Mulsanne body? Thanks.
Originally Posted by rtypec
This is sorta related but. here are a few recent photos of my F103-R 15th Anniversary chassis with an LMP body.
Chassis: F103R 15th Anniversary
Body: Protoform Mulsanne
Tires: Kit Rear / HBR Soft Front
Motor: Straight out of the box Johnson 540
And here's a noobtube video of the car doing some laps. Enjoy.
+ YouTube Video
TFR is offline
Old 03-21-2009, 08:29 PM
  #1792
who has used the nifferent types of diffusers? i ahve used the TRG claer one and the ABC typeE and the trg was more stable overall, and the ABC was much more stable on the straight aways but the turns were harder to manuver.the weather difference betweent he 2 days was 30 degrees which i think played a MAJOR role.
anyone tested any others? anyone ahve a prefrence?
Old 03-22-2009, 09:14 PM
  #1793
upon searching for my motor mount, i came across this:
for $200 you can have a fully hopped up f1 rc. this comes with alum upper arms, knuckles, toe links, castor adjuster, alum motor mount with 3 fans, rear t bar, lower deck, upper deck, hex wheel adapters, upper deck to servo mount bars, titanium screw kit and titanium friction plate. that is alot of hopups for only $200...
http://store.hkshobby.com/product_in...oducts_id=4901
what really caught my eye was the front arms... why would you have them reverse like that?
i really like the lower deck, thicker(3mm as opposed to 2.5) plus its thinner in the front, and has the extra hole for the f1 front wing. im goingt to school for my masters in physics and tone see how this is beneficial from a physical standpoint. the only thing that comes to mind is thier steering knucles are long. this may be positioned to make for that difference in distance. any insights?
Old 03-23-2009, 07:14 AM
  #1794
cheROK1212's Avatar
Originally Posted by RC MARKET
again !
Are those one-off Red Bull stickers (stripes and numbers) and Ferrari wheel caps or is that sticker set available? I REALLY would like those wheel stickers to complete my Ferrari.
Attached Thumbnails TAMIYA F103 RM-20090310_872452326d25170f71e88ixddfwozt8v.jpg   TAMIYA F103 RM-20090310_aed2828a404f0e1a430bjgcpn1w2qlig_jpg_thumb.jpg
cheROK1212 is offline
Old 03-23-2009, 11:17 AM
  #1795
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I keep an extra with all the time. RCP has seen this more than a few times. These cars don't like PVC at all!
liljohn1064 is offline
Old 03-23-2009, 01:52 PM
  #1796
rtypec's Avatar
Hi TFR. There weren't any modifications done to the car other than body mounts. For the front, I used the F103LM front bumper with F103LM aluminum body mounts. For the rear, I used F103LM body mounts as well. I adjusted the height using spacers and that was it. I'll go to the garage and take pics with the body off.
rtypec is offline
  #1797
SRBMOJO's Avatar
Trader Rating: 67 (100%+)
I am pretty sure thats what I am running too. I am running medium fronts. I ordered 3 sets of F and R. My set was supposed to be hard fronts, but they sent medium.
Im excited to try these on friday!
How did the car feel with the Superion tires at OCRC? I just got a set for mine, gonna run it at the Tamiya track this sat.
Steve
SRBMOJO is offline
Old 03-23-2009, 02:33 PM
  #1798
rtypec's Avatar
To follow up my previous post, there was a small modification to the front wheels so that they would fit nicely under the body. In hindsight, they may not have needed to be cut down...however, I did narrow them by removing approximately 2.5mm from the lip. This was accomplished with an exacto blade and a tire lathe kinda freaky and not something I enjoyed doing lol.
As for pics with the body off, here they are. These images should illustrate how the body mounts from the F103lm work.
Attached Thumbnails TAMIYA F103 RM-f103lmp4.jpg   TAMIYA F103 RM-f103lmp5.jpg   TAMIYA F103 RM-frontmount.jpg   TAMIYA F103 RM-rearmount.jpg
rtypec is offline
Old 03-23-2009, 03:48 PM
  #1799
idwurks's Avatar
Absolutely beautiful car. And great job on the body mounting. I love the F1 style bodies, but there is something really enjoyable about that style body too. I almost want two cars
I saw those forward swept front arms too, I think you can swap the direction of the arms no problem on the LM car from what I can tell. I think its just done for styling. The real F1 cars have that forward swept style too.
idwurks is offline
Old 03-23-2009, 06:49 PM
  #1800
killingtime's Avatar
Does anyone have a recommendation for a servo for these cars?
At least ____ oz. of torque @ ___ sec. ?????
Any help would be appreciated as I just got my F103r together and trying to get the electronics done right.
killingtime is offline
